  3. Is ARM the future of MySensors?
31 Posts 12 Posters 9.9k Views 15 Watching
  • alowhumA alowhum
    @anticimex Hmm, I didn't realise that. Could it be an idea to create a MY_ENCRYPTION_SIMPLE_PASSWD feature as well, without the signing? Would that fit the "opportunistic curious neighbour" scenario?
    AnticimexA
    AnticimexA
    Anticimex
    @alowhum give personalization a shot. Since you use the simple flag, you are already on the development branch, so you have a simplified personalization flow. It is documented in doxygen (see the pinned signing post for a link)
      @alowhum I bet there are hundreds of people interested in your house temperature :sweat_smile:
      Btw, yes that is encryption
      alowhumA
      alowhumA
      alowhum
      @gohan said in Is ARM the future of MySensors?:
      Actually, just my temperature would already indicate
      • Whether I am home or not. "He'll never know we took the jewelry".
      • if I go on holidays a lot. "How is he paying for all that".
      • Whether I am feeling ill (set it a bit higher). "Got a fever last week? Or did your grandma visit"?
      • If I am environmentally conscious. Something I don't want to talk about at the neighbourhood BBQ..
      • Etc.
      Now add to that my other sensors.
      Now add to that all the actuators (yikes!).
        Don't your neighbors have better things to do?
        gohanG 1 Reply Last reply
          wrote on last edited by gohan
          #22
          @neverdie I was about to say the same... it must be a very boring town :D
          • G
            G
            ghiglie
            Well, last week I couldn't realize how my garage temp was so high.... I noticed my neighboor started autoproducing some sensors too... :D So it's time for signing/encryption.
            atmega328p serial killer
            HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
            • Nca78N Nca78
              @davidzh said in Is ARM the future of MySensors?:
              But in Urban areas with lots of high rises the 2.4GHz band is a bit congested.
              That's my case , there are 350 appartments in my building alone and my nrf24 network runs well, while my old 433MHz system regularly miss messages, that's why it will soon be replaced.
              dakipro
              @nca78 said in Is ARM the future of MySensors?:
              If nrf24 working on same/similar frequency as wifi, is it not being disturbed by other wifi networks? (I guess that in 350 apartments there are a minimum of 350 wifi networks).
              I never quite understood how exactly nrf24 and wifi go along.
              Nca78N gohanG YveauxY 3 Replies Last reply
              • D dakipro
                @dakipro said in Is ARM the future of MySensors?:
                It depends on the channels used by NRF24 and wifi networks, so far I've been lucky it seems :)
                Also, high rise is in fact probably helping by having thick concrete walls with lots of rebars inside, attenuating radio signals. I see many networks but most of them have week signal.
                • D dakipro
                  @dakipro wifi only overlaps the nrf24 range for a number of channels, so usually if you choose channels at the margins of the spectrum you should be good
                  • D dakipro
                    The frequency band of nrf24 is wider than used by wifi. If you select a frequency just outside the wifi band it should help in reducing interference.
                    D 1 Reply Last reply
                    • skywatchS
                      skywatchS
                      skywatch
                      The current NRF24 set up is more secure than bluetooth or wifi from attack.
                      I say this based on the fact that anyone with a laptop, mobile etc can have software to crack/hack/spoof/inject into bluetooth or wifi. It is not that difficult for kids to do.
                      The NRF is another matter as to achieve this on that radio module would require acquiring a module, setting it up with a pc/phone and then getting software to attack it.
                      People often go the easiest route and I am less worried about nrf24 than I would be if the system used bluetooth/wifi or cloud.
                      Just my thoughts on a dark and wet Monday morning.....
                      • YveauxY Yveaux
                        dakipro
                        @yveaux said in Is ARM the future of MySensors?:
                        Thanks, that is what I thought. Btw, I am using default channel for mysensors (79 or whatnot), is that "just outside" enough?
                        I never had (connection) problems with mysensors, so I never researched fine-tuning options.
                        Can some android wifi analyzer help with the showing what is best to use, is there some guide available regarding nrf24? (should we write a guide? :) )
                        NeverDieN YveauxY 2 Replies Last reply
                        • D dakipro
                          #30
                          I don't believe so. Channel 123 is though. Easy to remember.
                          • D dakipro
                            @dakipro see here for a mapping of wifi and nrf24 channels: https://forum.mysensors.org/topic/4721/nrf-frequency-and-channels/5
                            NRF24 Channels 2..96 overlap with wifi. I personally would stay away from the high nrf24 channels (110+) as I've seen troublesome performance with clones.
                            Channel 100 performs well at my place.
