  3. Is ARM the future of MySensors?
31 Posts 12 Posters 9.9k Views 15 Watching
  • AnticimexA Anticimex
    @alowhum the simple password option is the simplest way of enabling security. At the same time it is the most expensive as it does not require personalization and therefore is pure software based (except for rfm69 encryption). So you need to trade simplicity for code size.
    That said, once you have figured out personalization (and there is plenty documentation on the matter) it can easily be repeated, as long as you keep the sketch used to program the personalization data.
    alowhumA
    alowhumA
    alowhum
    @anticimex Hmm, I didn't realise that. Could it be an idea to create a MY_ENCRYPTION_SIMPLE_PASSWD feature as well, without the signing? Would that fit the "opportunistic curious neighbour" scenario?
    AnticimexA 1 Reply Last reply
    • alowhumA alowhum
      AnticimexA
      AnticimexA
      Anticimex
      @alowhum give personalization a shot. Since you use the simple flag, you are already on the development branch, so you have a simplified personalization flow. It is documented in doxygen (see the pinned signing post for a link)
        @alowhum I bet there are hundreds of people interested in your house temperature :sweat_smile:
        Btw, yes that is encryption
        alowhumA
        alowhumA
        alowhum
        @gohan said in Is ARM the future of MySensors?:
        Actually, just my temperature would already indicate
        • Whether I am home or not. "He'll never know we took the jewelry".
        • if I go on holidays a lot. "How is he paying for all that".
        • Whether I am feeling ill (set it a bit higher). "Got a fever last week? Or did your grandma visit"?
        • If I am environmentally conscious. Something I don't want to talk about at the neighbourhood BBQ..
        • Etc.
        Now add to that my other sensors.
        Now add to that all the actuators (yikes!).
          Don't your neighbors have better things to do?
          gohanG 1 Reply Last reply
            wrote on last edited by gohan
            #22
            @neverdie I was about to say the same... it must be a very boring town :D
            • G
              G
              ghiglie
              Well, last week I couldn't realize how my garage temp was so high.... I noticed my neighboor started autoproducing some sensors too... :D So it's time for signing/encryption.
              atmega328p serial killer
              HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
              • Nca78N Nca78
                @davidzh said in Is ARM the future of MySensors?:
                But in Urban areas with lots of high rises the 2.4GHz band is a bit congested.
                That's my case , there are 350 appartments in my building alone and my nrf24 network runs well, while my old 433MHz system regularly miss messages, that's why it will soon be replaced.
                dakipro
                @nca78 said in Is ARM the future of MySensors?:
                If nrf24 working on same/similar frequency as wifi, is it not being disturbed by other wifi networks? (I guess that in 350 apartments there are a minimum of 350 wifi networks).
                I never quite understood how exactly nrf24 and wifi go along.
                Nca78N gohanG YveauxY 3 Replies Last reply
                • D dakipro
                  @dakipro said in Is ARM the future of MySensors?:
                  It depends on the channels used by NRF24 and wifi networks, so far I've been lucky it seems :)
                  Also, high rise is in fact probably helping by having thick concrete walls with lots of rebars inside, attenuating radio signals. I see many networks but most of them have week signal.
                  • D dakipro
                    @dakipro wifi only overlaps the nrf24 range for a number of channels, so usually if you choose channels at the margins of the spectrum you should be good
                    • D dakipro
                      The frequency band of nrf24 is wider than used by wifi. If you select a frequency just outside the wifi band it should help in reducing interference.
                      D 1 Reply Last reply
                      • skywatchS
                        skywatchS
                        skywatch
                        The current NRF24 set up is more secure than bluetooth or wifi from attack.
                        I say this based on the fact that anyone with a laptop, mobile etc can have software to crack/hack/spoof/inject into bluetooth or wifi. It is not that difficult for kids to do.
                        The NRF is another matter as to achieve this on that radio module would require acquiring a module, setting it up with a pc/phone and then getting software to attack it.
                        People often go the easiest route and I am less worried about nrf24 than I would be if the system used bluetooth/wifi or cloud.
                        Just my thoughts on a dark and wet Monday morning.....
                        • YveauxY Yveaux
                          dakipro
                          @yveaux said in Is ARM the future of MySensors?:
                          Thanks, that is what I thought. Btw, I am using default channel for mysensors (79 or whatnot), is that "just outside" enough?
                          I never had (connection) problems with mysensors, so I never researched fine-tuning options.
                          Can some android wifi analyzer help with the showing what is best to use, is there some guide available regarding nrf24? (should we write a guide? :) )
                          NeverDieN YveauxY 2 Replies Last reply
                          • D dakipro
                            #30
                            I don't believe so. Channel 123 is though. Easy to remember.
                            • D dakipro
                              @dakipro see here for a mapping of wifi and nrf24 channels: https://forum.mysensors.org/topic/4721/nrf-frequency-and-channels/5
                              NRF24 Channels 2..96 overlap with wifi. I personally would stay away from the high nrf24 channels (110+) as I've seen troublesome performance with clones.
                              Channel 100 performs well at my place.
