  3. Send time request over arduino "monitor serial"
14 Posts 3 Posters 5.0k Views 2 Watching
    yes, you can
    • ch3b7C
      ch3b7C
      ch3b7
      how, who need send?? or an example
        Something like:
        <node-id>;255;3;0;1;<seconds since 1970>\n
        • ch3b7C
          ch3b7C
          ch3b7
          thanks, the problem is i dont know who is "<seconds since 1970> any example? im use a custom controller.
            Depends on your programming language. Normally you would have a function returning milliseconds since 1970. Just divide this with 1000.
            • ch3b7C
              ch3b7C
              ch3b7
              wrote on last edited by ch3b7
              WORK! im get "1420578901" ^^ thanks HEK!
              im have other question about the light actuator with a button, i send the command to tun on/off its works, but can the node can send again the new state when received the turn on/off command? sorry for my bad english im from argentina^^ im needed to update the state in my controller and know if the command sended work.
              this work but when i press the button the controller send 2 sets commands
              **void incomingMessage(const MyMessage &message) {
              if (message.isAck()) {
              // Change relay state
              state = message.getBool();
              // Store state in eeprom
              gw.saveState(CHILD_ID, state);
              gw.send(msg.set(state), false); // Send new state and request ack back
                Just request ack from the node by setting ack parameter to 1.
                <node-id>;<child-sensor-id>;<message-type>;<ack>;<sub-type>;<payload>\n
                The node will then respond back with the same message in return. (You don't need to update sketch code)
                • ch3b7C
                  ch3b7C
                  ch3b7
                  THANKS for your help!!
                  E 1 Reply Last reply
                  • ch3b7C ch3b7
                    E
                    E
                    ericvdb
                    @ch3b7 do you mind sharing your .net code?
                    • ch3b7C
                      ch3b7C
                      ch3b7
                      HERE my source code my-sensors-controller-net
