  3. Heatpump controller
Heatpump controller
55 Posts 15 Posters 32.7k Views 11 Watching
  • F
    F
    Fredrik Carlsson
    wrote on last edited by Fredrik Carlsson
    Hello
    I have made the following code (actually not, made i have combined the heatpump example sketch and the ir mysensor sketch to make a controller that can turn ON/OFF the heatpump. But... It doesnt work. I am not sure which node id the controller gets **(how to check that??) **
    How is the MQTT message structured?
    I have tried to send the following with an android app (who is connected to the gateway off course)
    Topic: MyMQTT/22/1/V_LIGHT
    Message:1
    Have also tried node id 23-28 without result.
    I have a couple of temperature nodes working with MQTT and Openhab so the "system" is working for sure.
    But its easier to just find a published message. Harder to publish i maybe??
    Any ideas/suggestions?
    One thing I have noticed is that I dont get the "Starting" message in the serial monitor.
    Is maybe something happening which stalls the code before that?
    All help I can get is highly appreciated!!
    ps, the code inside the do loops is already tested and confirmed working in a simpler sketch without mysensors library.
                  // Example sketch showing how to control ir devices
                  // An IR LED must be connected to Arduino PWM pin 3.
                  // When binary light on is clicked - sketch will send heatpump command with on
                  // When binary light off is clicked - sketch will send heatpump command with off
                  #include <Arduino.h>
                  #include <FujitsuHeatpumpIR.h>
                  #include <PanasonicCKPHeatpumpIR.h>
                  #include <PanasonicHeatpumpIR.h>
                  #include <CarrierHeatpumpIR.h>
                  #include <MideaHeatpumpIR.h>
                  #include <MitsubishiHeatpumpIR.h>
                  #include <SamsungHeatpumpIR.h>
                  #define CHILD_1  1  // childId
                  IRSender irSender(3); // pin where ir diode is sitting
                  MyMessage msg(CHILD_1, V_VAR1);
                  HeatpumpIR *heatpumpIR[] = {new PanasonicCKPHeatpumpIR(), new PanasonicDKEHeatpumpIR(), new PanasonicJKEHeatpumpIR(),
                                              new PanasonicNKEHeatpumpIR(), new CarrierHeatpumpIR(), new MideaHeatpumpIR(),
                                              new FujitsuHeatpumpIR(), new MitsubishiFDHeatpumpIR(), new MitsubishiFEHeatpumpIR(),
                                              new SamsungHeatpumpIR(), NULL};
                    // will take away everything except PanasonicJKE when everything ready to reduce sketch size
                    gw.begin(incomingMessage); // Start listening
                    gw.sendSketchInfo("IR Sensor", "1.0");
                    // Register a sensors to gw. Use binary light for test purposes.
                    gw.present(CHILD_1, S_LIGHT);
                    Serial.begin(9600); // Start serial only for debugging. Will be taken away when development is finished
                    delay(500);
                    Serial.println(F("Starting"));
                    if (message.type==V_LIGHT) {
                       int incomingRelayStatus = message.getInt();
                       if (incomingRelayStatus == 1) {
                            int i = 0; //counter
                            prog_char* buf;
                          do {
                         // Send the same IR command to all supported heatpumps
                                  Serial.print(F("Sending IR to "));
                                  buf = (prog_char*)heatpumpIR[i]->model();
                                  // 'model' is a PROGMEM pointer, so need to write a byte at a time
                                  while (char modelChar = pgm_read_byte(buf++))
                                    Serial.print(modelChar);
                                  Serial.print(F(", info: "));
                                  buf = (prog_char*)heatpumpIR[i]->info();
                                  // 'info' is a PROGMEM pointer, so need to write a byte at a time
                                  while (char infoChar = pgm_read_byte(buf++))
                                    Serial.print(infoChar);
                                  Serial.println();
                                  // Send the IR command
                                  heatpumpIR[i]->send(irSender, POWER_ON, MODE_HEAT, FAN_2, 24, VDIR_UP, HDIR_AUTO);
                                  delay(500);
                                  while (heatpumpIR[++i] != NULL);
                      } else if (incomingRelayStatus == 1) {
                            prog_char* buf;
                        do {
                                  Serial.println();
                                  heatpumpIR[i]->send(irSender, POWER_OFF, MODE_HEAT, FAN_2, 24, VDIR_UP, HDIR_AUTO);
                                  delay(500);
    F 1 Reply Last reply
    • F Fredrik Carlsson
      Hello
      Message:1
                      delay(500);
                              prog_char* buf;
                            do {
                                    Serial.println();
                                    delay(500);
                              prog_char* buf;
                          do {
                                    Serial.println();
                                    delay(500);
      F
      F
      Fredrik Carlsson
      @Fredrik-Carlsson no ideas?
      How can i see which node id the sensor gets?
        wrote on last edited by hek
        Which controller? Do you mean the node?
        @Damme might be able to help with the MQTT stuff.
        You should see a "starting" message. If not there might be a code problem.
        loop() should at least contain gw.process() to pick up incoming messages.
        • F
          F
          Fredrik Carlsson
          Haha yes i have forgotten gw process in the loop. that is corrected now.
          Yes i want to know which mqtt address the node has (for example i have 2 temperatures nodes with id MyMQTT/20/ and MyMQTT/21/
            It is usually printed in serial monitor at startup .
            ...or by calling gw.getNodeId();
            • F
              F
              Fredrik Carlsson
              TOUCHDOWN!
              Here is working code. Whit this i can with mymqtt android app publish topic MyMQTT/20/1/V_LIGHT with message "1" for heatpump on (with 24 degrees etc etc) and "0" for heatpump off. I have tried it with my Panasonic heatpump and it works.
              I also added a little serial string in order to find out node Id (mine was 20 then)
              Next step is to increase the different modes.
              I was thinking from beginning of only having 5 different "hardcoded" modes that would actually be more then enough for my use, but it would be really nice to send over variables some how instead so you have complete control of the heatpump from OpenHAB (temp, heatingmode etc). I am just not sure about how long messages you can send with the nrf protocol. Must dig into that
              Thanks for all the help, as I said I have almost no programming nor Arduino knowledge since before. Just starting out.
              // Example sketch showing how to control ir Heatpumps
                      Serial.begin(9600);
                      delay(500);
                      Serial.print("Node Id is set to: ");
                      Serial.println(gw.getNodeId());
                              prog_char* buf;
                            do {
                                    Serial.println();
                                    delay(500);
                        } else if (incomingRelayStatus == 0) {
                              prog_char* buf;
                          do {
                                    Serial.println();
                                    delay(500);
              RJ_MakeR 1 Reply Last reply
                TOUCHDOWN!
                        Serial.begin(9600);
                        delay(500);
                                prog_char* buf;
                              do {
                                      Serial.println();
                                      delay(500);
                                prog_char* buf;
                            do {
                                      Serial.println();
                                      delay(500);
                RJ_MakeR
                RJ_MakeR
                RJ_Make
                @Fredrik-Carlsson
                Nice Job!
                RJ_Make
                • F
                  F
                  Fredrik Carlsson
                  well, i have run into some problems. It doesnt have anything to do with the sketch though. Its either OpenHab or the gateway that is causing headache.
                  First of all, I have changed the code into this:
                              HeatpumpIR *heatpumpIR[] = {new PanasonicJKEHeatpumpIR(), NULL};
                                gw.present(CHILD_1, S_HEATER);
                                Serial.begin(9600);
                                delay(500);
                                if (message.type==V_HEATER) {
                                   int incomingHeatingStatus = message.getInt();
                                   if (incomingHeatingStatus == 0) {
                                              heatpumpIR[0]->send(irSender, POWER_OFF, MODE_HEAT, FAN_AUTO, 22, VDIR_AUTO, HDIR_AUTO);
                                              delay(500);
                                              Serial.println("Setting mode to ");
                                              Serial.println(incomingHeatingStatus);
                                      } else if (incomingHeatingStatus == 1) {
                                              heatpumpIR[0]->send(irSender, POWER_ON, MODE_HEAT, FAN_AUTO, 21, VDIR_AUTO, HDIR_AUTO);
                                              delay(500);
                                            } else if (incomingHeatingStatus == 2) {
                                              heatpumpIR[0]->send(irSender, POWER_ON, MODE_HEAT, FAN_AUTO, 22, VDIR_AUTO, HDIR_AUTO);
                                              delay(500);
                                            } else if (incomingHeatingStatus == 3) {
                                              heatpumpIR[0]->send(irSender, POWER_ON, MODE_HEAT, FAN_AUTO, 23, VDIR_AUTO, HDIR_AUTO);
                                              delay(500);
                                            } else if (incomingHeatingStatus == 4) {
                                              heatpumpIR[0]->send(irSender, POWER_ON, MODE_HEAT, FAN_AUTO, 24, VDIR_AUTO, HDIR_AUTO);
                                              delay(500);
                                            } else if (incomingHeatingStatus == 5) {
                                              heatpumpIR[0]->send(irSender, POWER_ON, MODE_HEAT, FAN_AUTO, 25, VDIR_AUTO, HDIR_AUTO);
                                              delay(500);
                                            } else if (incomingHeatingStatus == 6) {
                                              heatpumpIR[0]->send(irSender, POWER_ON, MODE_HEAT, FAN_AUTO, 22, VDIR_UP, HDIR_AUTO);
                                              delay(500);
                                            } else if (incomingHeatingStatus == 7) {
                                              heatpumpIR[0]->send(irSender, POWER_ON, MODE_HEAT, FAN_1, 22, VDIR_UP, HDIR_AUTO);
                                              delay(500);
                                            } else if (incomingHeatingStatus == 8) {
                                              heatpumpIR[0]->send(irSender, POWER_ON, MODE_HEAT, FAN_3, 22, VDIR_UP, HDIR_AUTO);
                                              delay(500);
                                            } else if (incomingHeatingStatus == 9) {
                                              heatpumpIR[0]->send(irSender, POWER_ON, MODE_HEAT, FAN_4, 22, VDIR_UP, HDIR_AUTO);
                                              delay(500);
                                            } else if (incomingHeatingStatus == 10) {
                                              heatpumpIR[0]->send(irSender, POWER_ON, MODE_COOL, FAN_AUTO, 18, VDIR_UP, HDIR_AUTO);
                                              delay(500);
                                            } else if (incomingHeatingStatus == 11) {
                                              heatpumpIR[0]->send(irSender, POWER_ON, MODE_COOL, FAN_AUTO, 20, VDIR_UP, HDIR_AUTO);
                                              delay(500);
                                            } else if (incomingHeatingStatus == 12) {
                                              heatpumpIR[0]->send(irSender, POWER_ON, MODE_COOL, FAN_AUTO, 22, VDIR_UP, HDIR_AUTO);
                                              delay(500);
                  With the Android app MyMQTT I have tried the different modes and all works, Currently the scetch has been up running a couple of days without problems.
                  The problem is when i try to do this from OpenHAB.
                  First of all, the Mqtt binding IS working, at least with inbound messages because I have also a couple of temperature sensors and that works fine. But when i try with the following setup the command line of openhab shows: "Heatpump received command ON", but nothing is happening with the arduino. Very strange. Any ideas?
                  Openhab Item:
                         Switch Heatpump (varmesystem,All)      {mqtt=">[mysensor:MyMQTT/20/1/V_HEATER:command:ON:1],>      [mysensor:MyMQTT/20/1/V_HEATER:command:OFF:0]"}
                  OpenHAB Sitemap:
                       Switch item=Heatpump label="Värmepump"
                  Any ideas what is going wrong?
                  • F
                    F
                    Fredrik Carlsson
                    Well, after a few restarts of both the node, the gateway and openhab it suddenly works.
                    • J
                      J
                      johnr
                      Thank you for the inspiration. I skuld like to use this to control my Daikin heatpump in my cabin. Unfortunatley I am not able to travel there for I while to access the remote. I think I need it to analyze the signal since Daikin is not supported by the library you used.
                      I am thinking just two buttons (on 22 degrees/ on 10 degrees)
                      Did you stumble over any Daikin codes while working on this project?
                      Maybe it is possible to use the code these guys decoded http://www.hifi-remote.com/forums/viewtopic.php?t=11769
                      D 1 Reply Last reply
                      • F
                        F
                        Fredrik Carlsson
                        Hello
                        nice that you cna use it for something :)
                        Sorry, I have no idea regarding Daikin, but if you build sometihng to record the codes with maybe you can figure it out and just add that to the library somehow?
                        Anyway, i have thought more about this and i do actually want to be able to make it a little smarter than the code above.
                        It would be nice if its possible to send a whole string direct from the controller. ie "send(irSender, POWER_ON, MODE_HEAT, FAN_AUTO, 21, VDIR_AUTO, HDIR_AUTO)" Then I can on the controller side make all the logic and that way have complete control of how the heatpump behaves.
                        I have tried to search a little, but can not find any concrete answer. How big is the maximum size of the payload you can send with this library?
                          Answer in big blue box here:
                          http://www.mysensors.org/build/serial_api
                          25 bytes.
                          • J johnr
                            DirkB19
                            @johnr
                            I'm taking my first steps with IR sender/receiver because I'm also looking for controlling my DAIKIN heatpump.
                            I assembled IR receiver, IR sender and nano and loaded From the examples IR Sender/Receiver sketch.
                            It works with the remote of my Samsung TV, which it recognises as NEC.
                            Daikin is not recognized.
                            My Panasonic TV remote is not recognized.
                            My Telenet Set-Top box remote is not recognized.
                            I guess there is a IRlib for Panasonic, right ?
                            Thx, guys !
                            • T
                              ToniA
                              Nice to see that my little HeatpumpIR library made it all the way here :)
                              I'm also quite new to MySensors, I actually just started today, I've had all the necessary hardware on my table for some weeks now... My goal is to power a (physically) small MySensors device directly from the Panasonic heatpump, and hide everything within the indoor unit's covers, and have it fully controlled by Domoticz. There's quite a bit of work to do, as for example Domoticz does not have a suitable devuce type yet.
                              And how about MySensors, I'm still quite a newbie on the messaging schema... Is there a schema which could be used to communicate all of these within the same message:
                              • ON/OFF information (0 or 1)
                              • Temperature information (integer from 8 to 30)
                              • Fan speed information (integer from 0 to 5)
                              • Mode information (COOL, HEAT etc. i.e. integer from 0 to 6)
                              What comes to Daikin, it would probably be quite easy to add it into the HeatpumpIR code, provided that I could borrow the remote controller for a while. Or, if somebody else could decode the protocol.
                              • J
                                J
                                johnr
                                ToniA,
                                Where are you based? I maybe can send you my remote, if I am sure to get it back ;)
                                I think it will be a challenge to send all the information with only 25 bytes.
                                • T
                                  ToniA
                                  In live in Finland...
                                  I now have the HeatpumpIR working together with Domoticz, so that I can also define which commands to send from Domoticz. And yes, 24 bits is plenty enough :)
                                  https://github.com/ToniA/arduino-heatpumpir/tree/master/examples/MySensorsNode
                                  @johnr, do you happen to have an infrared receiver module? If you do, I could assist you in decoding the protocol. This is how I for example got the Mitsubishi protocol decoded, I've never had a Mitsubishi remote controller myself...
                                  SGiS 1 Reply Last reply
                                    Wow, great job @ToniA
                                    Would you consider creating a pull request with the example and HeatpumpIR library when you feel finished?
                                    • T
                                      ToniA
                                      @hek, I created pull request #211. I think it's good enough, the challenges are really on the Domoticz side.
                                        Thanks, I'll take a look!
                                        • T
                                          ToniA
                                          I finally managed to get rid of all compiler warnings :) I must say I like your CI build system, I'm also running Jenkins at work, actually running the build system on Jenkins is my primary job at the moment...
                                          So the heatpump IR sender node is now one of the examples on the MySensors 'development' branch.
