  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • tbowmoT tbowmo
    @stefaanv
    No, it doesn't need a driver..
    I get the same for mine, if I use setserial:
    thomas at jarvis in ~
    >sudo setserial /dev/ttyNRF24
    /dev/ttyNRF24, UART: unknown, Port: 0x0000, IRQ: 0, Flags: low_latency
    >ll /dev/ttyNRF24
    lrwxrwxrwx 1 root root 7 nov 11 13:39 /dev/ttyNRF24 -> ttyACM1
    Btw. the permission problem.. You are logged in using your normal user (stefaan) and then you set permissions for openhab user? (see below). Have you tried setting the permissions for your user, and then cat /dev/ttyACM0?
    @stefaanv said in 💬 Sensebender Gateway:
    There seems to be a premissions problem om the port :
    stefaan@home:~$ cat /dev/ttyACM0
    cat: /dev/ttyACM0: Permission denied
    doing 'sudo usermod -a -G dialout openhab' doesn't help
    Anyone any ideas ?
    stefaanvS
    stefaanvS
    stefaanv
    @tbowmo OK, is working now after restarting the bundle in OH.
    Must have been the permission problem after all.
    Thanks for your help !!
    • rzyliusR
      rzyliusR
      rzylius
      When I try to compile SensebenderGW sketch with signing features, I receive a bunch of errors. What am I missing?
      Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Sensebender Gateway"
      In file included from C:\Users\rzylius\AppData\Local\Temp\arduino_modified_sketch_737033\SensebenderGatewaySerial.ino:88:0:
      C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: redefinition of 'uint8_t device_pin'
      static uint8_t device_pin;
      In file included from C:\Users\rzylius\Documents\Arduino\libraries\MySensors/MySensors.h:131:0,
                   from C:\Users\rzylius\AppData\Local\Temp\arduino_modified_sketch_737033\SensebenderGatewaySerial.ino:86:
      C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: 'uint8_t device_pin' previously declared here
      C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void swi_set_signal_pin(uint8_t)':
      C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:24:13: error: redefinition of 'void swi_set_signal_pin(uint8_t)'
      static void swi_set_signal_pin(uint8_t is_high)
      C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:24:13: error: 'void swi_set_signal_pin(uint8_t)' previously defined here
      and the same type of errors reoccurs multiple times.
      AnticimexA 1 Reply Last reply
      • rzyliusR rzylius
        AnticimexA
        AnticimexA
        Anticimex
        @rzylius I think you have an #include in the sketch for the atsha driver. Try to remove that #include from the sketch.
        • rzyliusR
          rzyliusR
          rzylius
          @Anticimex yes, when I delete #include atsha driver line, it compiles well. thanks.
          • tbowmoT tbowmo
            @Fabien legacy, unless you would reflash all your nodes with the new driver as well. (they are not compatible)
            F
            F
            Fabien
            @tbowmo After 2 month on the dev version, no more problem with the gateway. Perhaps it's time to made a new stable release ?
            • tbowmoT
              tbowmoT
              tbowmo
              @Fabien
              It's on the todo list.. :)
                I am looking for Gateway that will get me the results to MQTT but will support encryption + signing. That mean it should be easy to add new signatures (recompile/reflash) the module
                I suppose if I use Sensebender with LAN module it will be a pain to do that
                Is this doable if I use Orange zero as USB host for the Sensbender and let it act as serial gateway, then convert serial to mqtt with software on the Linux side? Also is it possible to reflash it easily this way? I do not want to rewire the hardware each time a add new node.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @8667
                  Is it over the air encryption / signing that you are aiming after? Then that is possible with the gateway, it has the ATSHA204 onboard for signing capabilities. And it also works with the W5100 module attached. The Gateway have 256Kb of flash onboard, so it has "enough" room for both network stack, and signing.
                  • rzyliusR
                    rzyliusR
                    rzylius
                    Are there performance limitations to be considered for mysensors and SensebenderGW specifically. Will the gateway handle the load of signed communications if rules will be firing messages to different sensors like 1-2-5-10 per second?
                    • rzyliusR rzylius
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @rzylius if you use the atsha204a chip, it is the single wire interface that limits your throughput. I have no figures, so best is to just test how fast you can push messages through. Of course there is overhead in the OTA handshaking as well. That would probably be the bottleneck if you use software based signing.
                      • rzyliusR
                        rzyliusR
                        rzylius
                        I see in logs, that the whole process of signing and communicating to the node takes a bit more than one second. I do not know how to make a stress test properly, so I hoped that somebody else did it :) my question is if gateway will handle load by putting messages in some pipeline, or I should try to make sure that messages are fired with some spaces.
                        • rzyliusR rzylius
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @rzylius The signing process is blocking, so it should not accept messages if a signed message exchange is in progress. But I have not tested that extensively with "aggressive" controllers.
                          • Mitja BlazinsekM
                            Mitja BlazinsekM
                            Mitja Blazinsek
                            im trying to program in arduino ide, installed board... bu when compiling it write mi an error 'The current selected board needs the core 'arduino:arduino' that is not installed.'
                            • Mitja BlazinsekM Mitja Blazinsek
                              #348
                              @mitja-blazinsek You'll need to install the Arduino SAMD board as well. I have just now updated the readme.
                              • D
                                dklinkman
                                wrote on last edited by dklinkman
                                #349
                                Just got my Sensebender GW and soldered it up. Adapted the serial sketch to Ethernet and it almost worked. Found some posts on this topic that helped me locate and fix my config error. Now all is well. Thanks! --edit-- added photo
                                -d
                                • D
                                  dklinkman
                                  #350
                                  @dklinkman said in 💬 Sensebender Gateway:
                                  Sensebender
                                  And I got a Sensebender Micro soldered up and running also!! Just temp and humid so far. Too cool
                                  --edit-- picture
                                  • SoloamS
                                    SoloamS
                                    Soloam
                                      Is it possible to use the sensebender board as MQTT gateway? Not Ethernet?
                                      • SoloamS
                                        SoloamS
                                        Soloam
                                        Yes it is! I use I'm using it as a MQTT gateway for some time
                                        • C
                                          C
                                          Christian Schulte genannt Trux
                                          First: Great work! My GW is working very well!
                                          I wanted to know for what I can use the SD-Card.
                                          My idea is to fetch the logs in the serial and write them to the SD-Card.
                                          But I don't know where. Is there a point in the mySensors core where I can fetch all logs?
