  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
    #1386
    Anyone heard anything about when the nrf52840 might be released? I had thought we'd have heard something by now. Surely sometime in 2018 at least? What's the nearest competing chip?
      #1387
      afaik (and I got a confirmation from Nordic too), there is no plan for other nrf52840 package than AQFN.
      If you're searching for the ic, you'll have to use this footprint, which needs premium pcbs (micros vias, and multilayers for escaping routes and better plane).
      It's also more tricky to solder than a fanstel BT840s and its bottom pins. BT840s edge pins are easy to solder sure but there are not so many. All others pins are on bottom as you know. Of course, it's the same for BT840, easier&better perf when using 4layers, but that can be done with 2layers (also explained in datasheet though).
      From what I saw, others nrf52840 module sellers are going on same road, lot of tiny pads on bottom of the module, yes you can't do small things with big things, and there are lot of pins!
      There is another thing to know. no arduino core for nrf52840 yet. Yes, it's possible to use radio, some pins too, but no spi, i2c etc. that's because it needs some code refactoring to handle multiple io ports (nrf52832 one io port, whereas 840 has two).
      imho there are better mcu ;) some silabs mcu for example.. but not arduino compatible, out of scope here, and lot of people would say, "not interested, it's two bucks more expensive", way of talking (not mine) as i don't remember the exact price .
      • scalzS scalz
        #1388
        @scalz To get smaller size, I expect we'll see modules with reduced pin counts for the 52840, just as we already do for the 52832. Have you heard anything about when final silicon for the 840 will be shipping?
        scalzS 1 Reply Last reply
          #1389
          @neverdie said in nRF5 Bluetooth action!:
          yes sure. reduced IO pin counts.. and maybe even more reduced if they try to fit new features instead of IO (like usb etc). The above holyiot module example:
          1. replace two IOs by USB pins.
          2. keep same pinouts, but no USB, pity for a new interesting feature, but i can imagine not all people interested in it
          3. need to enlarge the module for same pinout + usb pins
          4. same module size and pinout, +usb, -> add bottom pads
          I still don't get the point of a holyiot module, and chip antenna modules, when it's not for wearables though!
          Complete waste of specs :) a 840 like that would be "funny", not much pins, with a chip ant..what would be the point then to buy a 840?? short ble5 range, no usb or just a few ios etc, yuk!
          If you're after range, then take a look at the range comparison fanstel made. it's explicit how their different module design impact range. But if you don't need all the new bells&whistles of 840, then it may be smarter to use 832 or nrf24pa, and a good module, too bad to buy a module with degraded RF..
          I asked Nordic two months ago, I don't think their eta changed. should be soon I imagine.
          • scalzS scalz
            #1390
            Not really disagreeing with you, but it's nonetheless interesting that if you do a search on Aliexpress for nrf52832 and sort the results by number of orders, the HolyIOT has gotten by far the biggest number of orders: https://www.aliexpress.com/premium/nrf52832.html?spm=2114.search0204.0.0.631303423oXjxi&site=glo&groupsort=1&SortType=total_tranpro_desc&g=y&SearchText=nrf52832&tc=ppc&initiative_id=SB_20180117073832&needQuery=n&filterCat=100000201,200010206,200084026
            [Edit: I'm wrong. The Ebyte module got the most orders.]
              #1391
              I measured the Fanstel BTC832X at maximum Tx, and it draws more current than I had thought: around 330ma. As you would expect, though, the range and coverage is excellent, even at 2mbps, and even for diminutive receivers like the HolyIOT. :)
              For that reason, I think it generally beats the RFM69's performance, which IIRC consumes around 100ma at max Tx power, but has a max transmit speed of 300kbps. i.e. Total mah to transmit a payload should be less with the Fanstel BT832X.
                #1392
                Since the Fanstel's don't come with the low frequency crystal oscillators already installed, when it is worthwhile to install them? I'm blithely running off the built-in RC oscillator, and I'm not noticing problems.
                JokgiJ 1 Reply Last reply
                  #1393
                  Even with two CR2032's in series, I can't get 330ma out of them for very long, if at all, before internal resistance becomes severe and it plummets to 110ma or less. Nonetheless, at least some of the preliminary testing suggests that the initial burst may be good enough to extend the Tx range for long enough (100ms) to reliably wake a sleeping receiver node that sits outside the range of a non-amplified transmitter.
                    JokgiJ
                    JokgiJ
                    Jokgi
                    @neverdie The internal RC Osc will allow you to keep your BOM costs lower. However when using the Bluetooth Softdevice the Crystal will lower the power consumption as the BT window will be narrower.
                    • JokgiJ Jokgi
                      #1395
                      @jokgi said in nRF5 Bluetooth action!:
                      Is the choice of RC osc or crystal of any consequence at all for Nordic's proprietary radio modes? For instance, I wasn't sure whether or not the cyrstal's greater accuracy might achieve a lower bit error rate at 2mbps.
                      Nca78N 1 Reply Last reply
                        @neverdie I suppose the radio is using the high frequency clock, so it doesn't have any influence ?
                        d00616D 1 Reply Last reply
                        • Nca78N Nca78
                          d00616D
                          d00616D
                          d00616
                          @nca78 said in nRF5 Bluetooth action!:
                          The LFCLK is required for BLE timing. Without the MCU required more energy to generate (synthetic) or calibrate (RC) the 32kHz signal.
                          • d00616D d00616
                            Since Mysensors isn't using BLE, then it doesn't matter?
                            • T
                              Toyman
                              Where can i get a Kicad component for Ebyte nrf52832?
                              mtiutiuM 1 Reply Last reply
                              • T Toyman
                                mtiutiuM
                                mtiutiuM
                                mtiutiu
                                @toyman
                                You can find it in my kicad repo: symbol and footprint
                                I didn't used it in any design so please double check.
                                • nagelcN
                                  nagelcN
                                  nagelc
                                  wrote on last edited by nagelc
                                  #1401
                                  Any suggestions how can I get serial debug messages out of the NRF52832 (Fanstel BT832)? I can upload the program over the SWD interface. I'm using a black magic probe with the Arduino NRF5 package on Windows 10. I know it works because the node shows up in my controller.
                                  • nagelcN nagelc
                                    #1402
                                    @nagelc said in nRF5 Bluetooth action!:
                                    Define one of the pins as serial TXO. Then connect it to RXI on an FTDI TTL-USB converter and read it that way. That's what I do, and it works.
                                    nagelcN 1 Reply Last reply
                                      nagelcN
                                      nagelcN
                                      nagelc
                                      @neverdie
                                      Do you define the pins in MyBoardNRF5? In MyBoadNRF5.cpp, I replaced the 0 in the first line with10, thinking this will map Arduino TX0 to P010. This did not seem to work. How do you map the TX0 pin?
                                      • nagelcN nagelc
                                        @neverdie
                                        #1404
                                        @nagelc No, you want to change the values in the MyBoardNRF5.h file instead. For an example, see the source code in: https://www.openhardware.io/view/499/10-years-wireless-PIR-Sensor-on-just-one-set-of-3-AAs#tabs-source
                                        So, in your case, you'd want:
                                        #define PIN_SERIAL_TX       (10)
                                        and, to avoid conflicts, make sure that pin P0.10 isn't defined anywhere in the same .h file as something else already. If it is, you may need to change that as well.
                                        • nagelcN
                                          nagelcN
                                          nagelc
                                          Thanks. I'll give that a try.
