  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
    Since the Fanstel's don't come with the low frequency crystal oscillators already installed, when it is worthwhile to install them? I'm blithely running off the built-in RC oscillator, and I'm not noticing problems.
    JokgiJ
    JokgiJ
    Jokgi
    @neverdie The internal RC Osc will allow you to keep your BOM costs lower. However when using the Bluetooth Softdevice the Crystal will lower the power consumption as the BT window will be narrower.
    • JokgiJ Jokgi
      #1395
      @jokgi said in nRF5 Bluetooth action!:
      Is the choice of RC osc or crystal of any consequence at all for Nordic's proprietary radio modes? For instance, I wasn't sure whether or not the cyrstal's greater accuracy might achieve a lower bit error rate at 2mbps.
      Nca78N 1 Reply Last reply
        @neverdie I suppose the radio is using the high frequency clock, so it doesn't have any influence ?
        d00616D 1 Reply Last reply
        • Nca78N Nca78
          d00616D
          d00616D
          d00616
          @nca78 said in nRF5 Bluetooth action!:
          The LFCLK is required for BLE timing. Without the MCU required more energy to generate (synthetic) or calibrate (RC) the 32kHz signal.
          • d00616D d00616
            Since Mysensors isn't using BLE, then it doesn't matter?
            • T
              Toyman
              Where can i get a Kicad component for Ebyte nrf52832?
              mtiutiuM 1 Reply Last reply
              • T Toyman
                mtiutiuM
                mtiutiuM
                mtiutiu
                @toyman
                You can find it in my kicad repo: symbol and footprint
                I didn't used it in any design so please double check.
                • nagelcN
                  nagelcN
                  nagelc
                  wrote on last edited by nagelc
                  #1401
                  Any suggestions how can I get serial debug messages out of the NRF52832 (Fanstel BT832)? I can upload the program over the SWD interface. I'm using a black magic probe with the Arduino NRF5 package on Windows 10. I know it works because the node shows up in my controller.
                  • nagelcN nagelc
                    #1402
                    @nagelc said in nRF5 Bluetooth action!:
                    Define one of the pins as serial TXO. Then connect it to RXI on an FTDI TTL-USB converter and read it that way. That's what I do, and it works.
                    nagelcN 1 Reply Last reply
                      nagelcN
                      nagelcN
                      nagelc
                      @neverdie
                      Do you define the pins in MyBoardNRF5? In MyBoadNRF5.cpp, I replaced the 0 in the first line with10, thinking this will map Arduino TX0 to P010. This did not seem to work. How do you map the TX0 pin?
                      • nagelcN nagelc
                        @neverdie
                        #1404
                        @nagelc No, you want to change the values in the MyBoardNRF5.h file instead. For an example, see the source code in: https://www.openhardware.io/view/499/10-years-wireless-PIR-Sensor-on-just-one-set-of-3-AAs#tabs-source
                        So, in your case, you'd want:
                        #define PIN_SERIAL_TX       (10)
                        and, to avoid conflicts, make sure that pin P0.10 isn't defined anywhere in the same .h file as something else already. If it is, you may need to change that as well.
                        • nagelcN
                          nagelcN
                          nagelc
                          Thanks. I'll give that a try.
                          • T
                            Toyman
                            Yesterday, I 've got a mailing from my components' supplier featuring new type of cells, Li-MnO2. The cell has all the features needed for nRF5:
                            • 1200mah capacity
                            • 1.8-3.0v range
                            • low cost (ca. $3)
                            • 41,0 x 24,5 x 5,2 dimensions and, importantly
                            • up to 120mah peak discharge current.
                            The link to manufacturer:
                            http://www.fanso-battery.com/Ultra-thin-Li-MnO2-battery-CP502440-3V1200mAh-pd1905.html
                            Nca78N NeverDieN 2 Replies Last reply
                            • T Toyman
                              • 1200mah capacity
                              • 1.8-3.0v range
                              • low cost (ca. $3)
                              @toyman said in nRF5 Bluetooth action!:
                              • 1200mah capacity
                              • 1.8-3.0v range
                              • low cost (ca. $3)
                              Mhmhmh, a disposable battery that you have to solder I can't see it as a good idea for a node...
                              • Nca78N Nca78
                                • 1200mah capacity
                                • 1.8-3.0v range
                                • low cost (ca. $3)
                                Toyman
                                • 1200mah capacity
                                • 1.8-3.0v range
                                • low cost (ca. $3)
                                well, 1200mah will last AT LEAST for a year (two in real life). I have no issues resoldering 2 joints once a year, given it gives AAA capacity in a much smaller package
                                  Speaking of batteries, I found only one proper holder for holding two CR2032's in series:
                                  It turns out you pretty much need the plastic carrier to guarantee that the edge of the button cell doesn't short out against the side of the metal holding bracket.
                                    d00616D
                                    d00616D
                                    d00616
                                    @neverdie said in nRF5 Bluetooth action!:
                                    There are CR2477 (560mAh) or CR2450 (950mAh) 3V cells. Maybe its's better to handle.
                                    • T Toyman
                                      • 1200mah capacity
                                      • 1.8-3.0v range
                                      • low cost (ca. $3)
                                      #1411
                                      Footprint seems kinda large, at least for nodes intended to be small. It trades off length in order to get thin. In contrast, a CR123 is shorter (34.5mm), but thicker (17mm), but can deliver 1.5a continuous (which makes it very tempting for powering a PA):
                                      https://www.batteryjunction.com/energizer-cr123a.html
                                      On the other hand, when you add the CR123 holder, the length may be comparable.
                                      If you decide to try out the fanso, please do let us know how you like it.
                                      • d00616D d00616
                                        Good point. I think maybe the only actual justified use of two CR2032's in series is to power the AM612, which requires a voltage of at least 2.7v.
                                        • O
                                          O
                                          Omemanti
                                          Did someone get an NRF52 working with an ESP8266(ESP32) and successfully connected it to a controller?
                                          Since my controller is something stuffed away in a closet, Id like to have a gateway that's positioned more centralized. An ESP+NRF52832 would be a lovely cost-efficient solution.
