  3. 230V power supply to Arduino
67 Posts 25 Posters 78.7k Views 22 Watching
  • RJ_MakeR
    RJ_MakeR
    RJ_Make
    What kind of protections are embedded?
    RJ_Make
    • RJ_MakeR
      RJ_MakeR
      RJ_Make
      Never mind...
      http://www.farnell.com/datasheets/606238.pdf
      RJ_Make
      • klimK
        klimK
        klim
        SR036/SR037 are discontinued products.
        Take a look at supertex (microchip) SR086 (Fixed 3.3V) or SR087 (Fixed 5V) or SR10 instead.
        • axillentA
          axillentA
          axillent
          thanks for the reference. interesting chip even it requires more external parts than sr036/037
          sr036 is still possible to purchase from China
          sr086 is available only in brand stores like farnel
          sense and drive
          • klimK
            klimK
            klim
            Here i found a size example of that chips:
            power supply
            SR086, SR087 and SR10 you can get at ali too.
            • axillentA
              axillentA
              axillent
              very cool picture! easy to imagine
              SR10 the most interesting for low power
              do you have any links to aliexpress?
              I'm not able to find any new chips
              sense and drive
              • klimK
                klimK
                klim
                Hi, sorry not available at aliexpress anymore, maybe it was just temporary.
                But the SR10 (fqn is SR10LG-G) is available at RS-Components and Alibaba.
                Powering the mcu and some peripherals is ok, but do you know the maximum burst time of the NRF24l01 when sending? As all of the chips are limited in current by a few mA, i'm not shure if it will work reliable. I know that big capacitors can fix such issues, but is it sufficient?
                • axillentA
                  axillentA
                  axillent
                  All is fine) I found them at local seller
                  Will be cool to try
                  NRF24L01 + MCU needs 15mA
                  If you have other things to connect you need to count them too
                  for example SSR needs at least +10mA
                  I'm currently looking for a small supply for the wall switch build based on arduino.
                  So, I will need 15 + 10 = 25mA. Both SR086 and SR10LG can be sufficient,
                  SR10LG datasheet has very clear table - power ability is very depends on input capacitor.
                  25mA should be not a problem. For 240V you need 0.68uF with full rectifier schema
                  For 120V you will need at minimum 1uF with full rectifier schema
                  sense and drive
                  • H Hausner
                    I have with succes used these:
                    http://www.aliexpress.com/item/Travel-Convenient-EU-Plug-Wall-USB-Charger-Adapter-For-Samsung-Galaxy-S5-S4-S3-Note-3/32220133044.html
                    They are really easy to dismatle, and the result is this - https://www.dropbox.com/s/ep43uyve5v0msv6/20141206_214210.jpg?dl=0
                    At $1.10 I didn't even think about making my own PSU :)
                    axillentA
                    axillentA
                    axillent
                    Just got it today and made some tests. Price is cool, but I will not recommend to use this for loads higher than 500mA and also will not recommend to supply arduino without an additional 1000uF capacitor. It is a conclusion from the measurement:
                    • without load 5.34V output with 440mV pulsation, 0.1W consuption
                    • 10 Om load gives 470mA current 4.74V output with 440mV pulsation, 3.5W consuption
                    • 5 Om load gives 848mA current 4.43V output with 520mV pulsation, 6W consuption
                    • 3.33 Om load gives 1.06mA current 4.07V output with 880mV pulsation, 7.4W consuption
                    sense and drive
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @axillent
                      What if you place a 3v3 ldo at the 5V output, what is the ripple then, at the different loads?
                      axillentA 1 Reply Last reply
                      • tbowmoT tbowmo
                        @axillent
                        axillentA
                        axillentA
                        axillent
                        with good ldo supported by sufficient capacitors it can be fine for arduino
                        but still I will not recommend to go above 500mA with this supply
                        sense and drive
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @axillent
                          500mA should also be sufficient for a sensor node, even with a couple of relays, mysensors in GW mode, etc. it's not even near the 500mA limit
                          • axillentA
                            axillentA
                            axillent
                            sure. sensornode without relays requires 15-20mA
                            with SSR relay will need +10-15mA for each relay
                            +50-100mA for each regular relay
                            sense and drive
                            • T
                              Tibus
                              Hello, I'm also searching a way to get 5V from AC to make a beatiful mysensor wallPlug... I'm searching the smallest and cheapest way to do it. My problem is I want to drive a regular relay (a SSR is not very good for plug and other things no?), an atmega328 tqfp, a NRF24 and some other things like a current sensor,... so, I think I need 150ma +-? (100ma for the relay, max 25-30ma for the NRF and arduino and some ma for the status leds,...)
                              I found here the SR086 but I don't know if I could take 150ma on it.
                              What is the best way for my projet?
                              I also found these one but don't know if it ok too :
                              http://www.newark.com/vigortronix/vtx-214-001-105/ac-dc-conv-fixed-1-o-p-1w-5v/dp/45X5484?ost=VTX-214-001-105
                              I'm searchin the smallest way because i also would like to make a in wall module for interuptor,... so the VTX above is ok for a wallplug but a bit big for a in wall module... How the cubino for exemple make a DC module so small?
                              • T Tibus
                                axillentA
                                axillentA
                                axillent
                                @Tibus your selection is fine. Any one above is also fine
                                what is you worry?
                                sense and drive
                                • T
                                  Tibus
                                  @axillent My worry is taking 150ma out of a SR086? Is the SR086 ok to give 150ma?
                                  The VTX is ok but big for an inwall module so is there a good way to get 150ma in 5V from 220VAC in the smallest form factor possible? (or in less than 1cm height?)
                                  I also found these one but a SR086 would be fine for a inwall relay... (but 150ma?)
                                  http://fr.rs-online.com/web/p/alimentations-a-decoupage-integrables/7719379/
                                  • T Tibus
                                    axillentA
                                    axillentA
                                    axillent
                                    #26
                                    @Tibus SR086 able to provide 100mA from 9-50V. For example you can set it to provide 20V and add DC-DC step-down for example based on MP2359. This will give you current-UP benefit at 5V etc. 20V@100mA will give you 5V@360mA maximum with 90% efficiency
                                    My preference in your case LNK306, you can get directly up to 350mA. Using ceramic capacitors and SMD inductors you will fit in 7-10mm height (see one of my picture above)
                                    And at last. Why not SSR? What type of the load do you have?
                                    sense and drive
                                    • T
                                      Tibus
                                      @axillent Thank's verry much. I didn't know the current up benefit of a step-down. I think it's the key of my problem!
                                      I'll test the lnk306. Hope It will work for my project.
                                      For my "in wall module", it's just lights so no problem for an SSR. But for the wall plug, The user chose the load they want... so if it's a TV or a washing machine or a power supply, I read an SSR is not verry good for these things...
                                      • T Tibus
                                        axillentA
                                        axillentA
                                        axillent
                                        @Tibus YAW
                                        For LNK take a look for AN37, especially optimization at table 9
                                        an37-linkswitch.pdf
                                        SSR is fine for most of the loads. But you need to follow recommendation of their use and to control limitations (like maximum ratings and heat dissipation)
                                        sense and drive
                                        • axillentA
                                          axillentA
                                          axillent
                                          I'm expecting to receive my SR086 and SR10 this week
                                          I have a plan to run some tests
                                          sense and drive
