  3. 230V power supply to Arduino
67 Posts 25 Posters 78.7k Views 22 Watching
  • axillentA
    axillentA
    axillent
    The one similar to this you can solder on top of your PCB or assemble near your PCB in any case type http://www.aliexpress.com/item/20-pcs-lot-4-8W-400mA-Switching-Power-Supply-Board-Voltage-Regelator-Module-AC-90V-240V/1421878190.html
    5V or 12V version can be easily found
    sense and drive
    • H
      H
      Hausner
      wrote on last edited by Hausner
      I have with succes used these:
      http://www.aliexpress.com/item/Travel-Convenient-EU-Plug-Wall-USB-Charger-Adapter-For-Samsung-Galaxy-S5-S4-S3-Note-3/32220133044.html
      They are really easy to dismatle, and the result is this - https://www.dropbox.com/s/ep43uyve5v0msv6/20141206_214210.jpg?dl=0
      At $1.10 I didn't even think about making my own PSU :)
      jocke4uJ axillentA 2 Replies Last reply
      • tbowmoT
        tbowmoT
        tbowmo
        What is the efficiency of these "cheap" mains -> 12V/5V converters?
        Also, it means that you need a second regulator (be that a linear, or a switching) from 12/5V -> 3.3V.
        If you KNOW what you are doing, you could use SR036 from supertex, that can deliver 3.3V directly from mains (non isolated output).
        it could probably be used for mysensor connected dimers / light switches on mains. (something where human interface is not needed).
        Again, ONLY if you realy know what you are messing with :)
        axillentA 1 Reply Last reply
        • tbowmoT tbowmo
          axillentA
          axillentA
          axillent
          they are quite efficient. 5V version can deliver 400mA while unloaded supply consumes only 0.2W
          output voltage is defined by output resistor divider. I have an experience on changing 12V output to 5V by replacing a single SMD resistor. Theoretically the same way you can get 3.3V directly from the supply.
          that is true. I have the experience with SR036 (SR037 provides 5V output) and can say that you will never find smaller supply. But the output current will not exceed 50mA and this will depends on your mosfet output capability. Such a supply consumes about 1W while unloaded. Etc. not that green from the power consumption. This is my one side SR037 supply:
          if you know what you are doing it is also other choice - linkswitch chips LNK302/304/306. The last one can deliver up to 350mA not isolated power directly 5V or 3.3V. It is as efficient as isolated - unloaded it will consume about 0.2W. A bit bigger than SR036. Easy to construct because you do not need custom transformers. For example Duwi zwave wall switches are using this type of the supply. This is my one side SMD version with regulated output:
          next one is a classical low frequency transformer. The smallest here http://www.hahn-trafo.com/english/pcb-transformers-bv20.php - BV 201 0128 is ideal to power low power arduino device. It will consume unloaded about 1W. Can deliver about 60mA with linear regulator or about 100mA back regulated at 3.3V output. This one is my light controlling arduino using BV 201 0128:
          and the last one is capacitive supply. Most chinice cheap devices are using this type, most cheap supply:
          sense and drive
          tbowmoT themolochT 2 Replies Last reply
          • axillentA axillent
            tbowmoT
            tbowmoT
            tbowmo
            I just took a quick google, where the SR036 showed up, so no in depth analysis of alternatives.
            That one seems very interesting, for powering arduino things (from an efficiency point of view).
            Only one problem, I don't have the time for it at the moment.. I have to restrict my self, in starting new projects :). So for the moment it's battery powered sensors, that are getting my attention,
            • tbowmoT tbowmo
              axillentA
              axillentA
              axillent
              SR036/037 is very hard to purchase. Even ebay/ali you will find very limited proposal.
              It seams that Supertex has stopped a production
              sense and drive
              • H Hausner
                jocke4uJ
                jocke4uJ
                jocke4u
                Yes, that is an option. I did it with one and it was pretty easy.
                Also found this https://github.com/openhardwarelabs/arduino-power-supply and I like some parts being isolated/encapsulated .
                https://raw.githubusercontent.com/openhardwarelabs/arduino-power-supply/master/pictures/IMG_8030.jpg
                • jocke4uJ jocke4u
                  axillentA
                  axillentA
                  axillent
                  myrra also provides regulated modules without need of external regulator
                  for example this one http://ru.farnell.com/myrra/47121/power-supply-3-3v-2-5w/dp/1825772
                  sense and drive
                  • RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    What kind of protections are embedded?
                    RJ_Make
                    • RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      Never mind...
                      http://www.farnell.com/datasheets/606238.pdf
                      RJ_Make
                      • klimK
                        klimK
                        klim
                        SR036/SR037 are discontinued products.
                        Take a look at supertex (microchip) SR086 (Fixed 3.3V) or SR087 (Fixed 5V) or SR10 instead.
                        • axillentA
                          axillentA
                          axillent
                          thanks for the reference. interesting chip even it requires more external parts than sr036/037
                          sr036 is still possible to purchase from China
                          sr086 is available only in brand stores like farnel
                          sense and drive
                          • klimK
                            klimK
                            klim
                            Here i found a size example of that chips:
                            power supply
                            SR086, SR087 and SR10 you can get at ali too.
                            • axillentA
                              axillentA
                              axillent
                              very cool picture! easy to imagine
                              SR10 the most interesting for low power
                              do you have any links to aliexpress?
                              I'm not able to find any new chips
                              sense and drive
                              • klimK
                                klimK
                                klim
                                Hi, sorry not available at aliexpress anymore, maybe it was just temporary.
                                But the SR10 (fqn is SR10LG-G) is available at RS-Components and Alibaba.
                                Powering the mcu and some peripherals is ok, but do you know the maximum burst time of the NRF24l01 when sending? As all of the chips are limited in current by a few mA, i'm not shure if it will work reliable. I know that big capacitors can fix such issues, but is it sufficient?
                                • axillentA
                                  axillentA
                                  axillent
                                  All is fine) I found them at local seller
                                  Will be cool to try
                                  NRF24L01 + MCU needs 15mA
                                  If you have other things to connect you need to count them too
                                  for example SSR needs at least +10mA
                                  I'm currently looking for a small supply for the wall switch build based on arduino.
                                  So, I will need 15 + 10 = 25mA. Both SR086 and SR10LG can be sufficient,
                                  SR10LG datasheet has very clear table - power ability is very depends on input capacitor.
                                  25mA should be not a problem. For 240V you need 0.68uF with full rectifier schema
                                  For 120V you will need at minimum 1uF with full rectifier schema
                                  sense and drive
                                  • H Hausner
                                    axillentA
                                    axillentA
                                    axillent
                                    Just got it today and made some tests. Price is cool, but I will not recommend to use this for loads higher than 500mA and also will not recommend to supply arduino without an additional 1000uF capacitor. It is a conclusion from the measurement:
                                    • without load 5.34V output with 440mV pulsation, 0.1W consuption
                                    • 10 Om load gives 470mA current 4.74V output with 440mV pulsation, 3.5W consuption
                                    • 5 Om load gives 848mA current 4.43V output with 520mV pulsation, 6W consuption
                                    • 3.33 Om load gives 1.06mA current 4.07V output with 880mV pulsation, 7.4W consuption
                                    sense and drive
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @axillent
                                      What if you place a 3v3 ldo at the 5V output, what is the ripple then, at the different loads?
                                      • tbowmoT tbowmo
                                        @axillent
                                        axillentA
                                        axillentA
                                        axillent
                                        with good ldo supported by sufficient capacitors it can be fine for arduino
                                        but still I will not recommend to go above 500mA with this supply
                                        sense and drive
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @axillent
                                          500mA should also be sufficient for a sensor node, even with a couple of relays, mysensors in GW mode, etc. it's not even near the 500mA limit
