  3. 6/8 Buttons battery remote node
53 Posts 7 Posters 12.3k Views 8 Watching
  • CarywinC
    CarywinC
    Carywin
    You can use pin change interrupts with MySensors sleep loops with an easy hack. Here's the code I use for 4 button battery powered nodes that also report temperature and humidity using DHT a sensor. I run them from 2 AA and so far they've been running for more than 6 months without showing signs of discharge. This could be easily modified for 6 or 8 buttons.
    // MySensors EnviroButtons
    // Temperature and Humidity Sensor with 4 Push Buttons
    // Battery Powered Node
    // Don't forget to change buttons and VCC_CAL for each node
    // Cary Wintle - July 2017
    // MySensors configuration
    #define SN "EnviroButtons"  // Software name
    #define SV "0.4"            // Version number
    #define MY_NODE_ID 6
    #define MY_RADIO_RFM69
    #define MY_RFM69_NETWORKID 137
    #define MY_RFM69_ENABLE_ENCRYPTION
    #define MY_RFM69_NEW_DRIVER
    #define MY_RFM69_FREQUENCY RFM69_433MHZ
    #define MY_IS_RFM69HW
    #define EI_NOTEXTERNAL // External interrupts managed by built-in routines
    #include <EnableInterrupt.h> // Pin-change interrupts
    #define DHT_DATA_PIN 8
    // Buttons
    #define BUTTON1_PIN A1 // 5: A1 - 6: A1
    #define BUTTON2_PIN A2 // 5: A3 - 6: A2
    #define BUTTON3_PIN A3 // 5: A2 - 6: A3
    #define BUTTON4_PIN A0 // 5: A0 - 6: A0
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 120000;
    #define BAT_UPDATE_INTERVAL 720 // 24 hrs - Interval between battery updates (multiples of UPDATE_INTERVAL)
    // VCC Calibration Values
    // Node 5: 1128953L
    // Node 6: 1125300L
    #define VCC_CAL 1125300L
    static const uint8_t FORCE_UPDATE_N_READS = 30; // After an hour
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    int cycleCount = BAT_UPDATE_INTERVAL; // Send battery update immediately
    volatile byte B1Int = 0, B2Int = 0, B3Int = 0, B4Int = 0; // Interrupt button flags
    uint32_t now;
    MyMessage msgHum(0, V_HUM);
    MyMessage msgTemp(0, V_TEMP);
    MyMessage msgButtons(0, V_SCENE_ON);
    MyMessage msgBattV(0, V_VOLTAGE);
    DHT dht;
      sendSketchInfo(SN,SV);
      // Present the sensor
      present(0, S_CUSTOM, "Temp/Humid/Buttons");
      // Setup pins the DHT sensor is on
      digitalWrite(6, LOW);
      pinMode(6, OUTPUT);
      digitalWrite(7, LOW);
      pinMode(7, OUTPUT);
      digitalWrite(9, HIGH);
      pinMode(9, OUTPUT);
      sleep(2000);
      dht.setup(DHT_DATA_PIN); // Setup the DHT sensor
      pinMode(BUTTON1_PIN,INPUT_PULLUP);
      pinMode(BUTTON2_PIN,INPUT_PULLUP);
      pinMode(BUTTON3_PIN,INPUT_PULLUP);
      pinMode(BUTTON4_PIN,INPUT_PULLUP);
      enableInterrupt(BUTTON1_PIN,Button1,FALLING);
      enableInterrupt(BUTTON2_PIN,Button2,FALLING);
      enableInterrupt(BUTTON3_PIN,Button3,FALLING);
      enableInterrupt(BUTTON4_PIN,Button4,FALLING);
    void Button1() {
      B1Int++;
      _wokeUpByInterrupt = 0xFE; // Dirty hack to get out of MySensors sleep loop
    void Button2() {
      B2Int++;
    void Button3() {
      B3Int++;
    void Button4() {
      B4Int++;
      _wokeUpByInterrupt = INVALID_INTERRUPT_NUM;
      // Power up the DHT sensor
      // Process buttons
      if(B1Int > 0) {
        send(msgButtons.set(1));
        B1Int = 0;
      } else if(B2Int > 0) {
        send(msgButtons.set(2));
        B2Int = 0;
      } else if(B3Int > 0) {
        send(msgButtons.set(3));
        B3Int = 0;
      } else if(B4Int > 0) {
        send(msgButtons.set(4));
        B4Int = 0;
      // Wait for the DHT sensor to init
      sleep(2000);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      byte humidity = (byte)dht.getHumidity();
      if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      if (cycleCount >= BAT_UPDATE_INTERVAL) {
        cycleCount = 0;
        int BatV = readVCC();
        #ifdef MY_DEBUG
        Serial.print("BatVR: ");
        Serial.println(BatV);
        float BatVolts = BatV / 1000.0;
        #ifdef MY_DEBUG
        Serial.print("BatV: ");
        Serial.println(BatVolts);
        send(msgBattV.set(BatVolts, 2));
        float BatPercent = (BatVolts - 2.8) / 0.6 * 100;
        if(BatPercent > 100) BatPercent = 100;
        #ifdef MY_DEBUG
        Serial.print("Bat%: ");
        Serial.println(BatPercent);
        sendBatteryLevel((int)BatPercent);
      cycleCount++;
      // Power down the DHT sensor
      digitalWrite(9, LOW);
      sleep(UPDATE_INTERVAL);
    int readVCC() {
      wait(2); // Wait for Vref to settle
      int result = (high<<8) | low;
      #ifdef MY_DEBUG
      Serial.print("R: ");
      Serial.println(result);
      result = VCC_CAL / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
    dbemowskD gohanG 2 Replies Last reply
    • CarywinC Carywin
      // Buttons
      // Node 5: 1128953L
      // Node 6: 1125300L
      float lastTemp;
      float lastHum;
      uint32_t now;
      DHT dht;
        pinMode(6, OUTPUT);
        pinMode(7, OUTPUT);
        pinMode(9, OUTPUT);
        sleep(2000);
      void Button1() {
        B1Int++;
      void Button2() {
        B2Int++;
      void Button3() {
        B3Int++;
      void Button4() {
        B4Int++;
        // Process buttons
        if(B1Int > 0) {
          B1Int = 0;
          B2Int = 0;
          B3Int = 0;
          B4Int = 0;
        sleep(2000);
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
          cycleCount = 0;
          #ifdef MY_DEBUG
          #ifdef MY_DEBUG
          #ifdef MY_DEBUG
        cycleCount++;
      int readVCC() {
        #ifdef MY_DEBUG
      dbemowskD
      dbemowskD
      @carywin Certain arduinos such as the pro minis can ONLY do interrupts on pins 2 or 3 from my understanding.
      NeverDieN CarywinC 2 Replies Last reply
      • CarywinC Carywin
        // Buttons
        // Node 5: 1128953L
        // Node 6: 1125300L
        float lastTemp;
        float lastHum;
        uint32_t now;
        DHT dht;
          pinMode(6, OUTPUT);
          pinMode(7, OUTPUT);
          pinMode(9, OUTPUT);
          sleep(2000);
        void Button1() {
          B1Int++;
        void Button2() {
          B2Int++;
        void Button3() {
          B3Int++;
        void Button4() {
          B4Int++;
          // Process buttons
          if(B1Int > 0) {
            B1Int = 0;
            B2Int = 0;
            B3Int = 0;
            B4Int = 0;
          sleep(2000);
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            nNoUpdatesTemp++;
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            nNoUpdatesHum++;
            cycleCount = 0;
            #ifdef MY_DEBUG
            #ifdef MY_DEBUG
            #ifdef MY_DEBUG
          cycleCount++;
        int readVCC() {
          #ifdef MY_DEBUG
        @carywin what is the sleep current of your node with this "interrupt hack"?
        CarywinC 1 Reply Last reply
          Here's the PCB I made for the matrix keypad:
          The whole thing fits on a single sided PCB. :)
          • dbemowskD dbemowsk
            @dbemowsk said in 6/8 Buttons battery remote node:
            IIRC, you can do interrupts from other pins too, but each is tied to a separate bank of pins, so you have to do additional testing to determine which specific pin triggered the interrupt. In the case of the voltage divider keypad, that should be no problem.
              #38
              Here's the link: https://playground.arduino.cc/Main/PinChangeInterrupt
              So, in this scenario, it would be:
              ISR (PCINT1_vect) pin change interrupt for A0 to A5
                Here's a revision of the earlier code so that it uses ONLY ONE PIN (namely, A0) on the Arduino. And yes, this does work on a pro mini too, because that's what I tested it on. :)
                //  Description:
                //  Use just A0 to process the 12 button keypad.
                //  Button press is detected by interrupt set on A0.
                //  Which button was pressed is determined by an analog read of A0.
                // Note: sleep code borrows from Nick Gammon's Schedule J
                // Interrupt code borrows from https://playground.arduino.cc/Main/PinChangeInterrupt
                #include <avr/sleep.h>
                void pciSetup(byte pin)
                    *digitalPinToPCMSK(pin) |= bit (digitalPinToPCMSKbit(pin));  // enable pin
                    PCIFR  |= bit (digitalPinToPCICRbit(pin)); // clear any outstanding interrupt
                    PCICR  |= bit (digitalPinToPCICRbit(pin)); // enable interrupt for the group
                ISR (PCINT1_vect) // handle pin change interrupt for A0 to A5 here
                     //no need to do anything beyond just waking up.
                  pinMode(A0,INPUT);
                  pciSetup(A0);
                  Serial.flush();
                  uint16_t voltage;
                  set_sleep_mode (SLEEP_MODE_PWR_DOWN);
                  sleep_enable();
                  // Do not interrupt before we go to sleep, or the
                  // ISR will detach interrupts and we won't wake.
                  noInterrupts ();
                  pciSetup(A0);
                  // turn off brown-out enable in software
                  // BODS must be set to one and BODSE must be set to zero within four clock cycles
                  MCUCR = bit (BODS) | bit (BODSE);
                  // The BODS bit is automatically cleared after three clock cycles
                  MCUCR = bit (BODS);
                  // We are guaranteed that the sleep_cpu call will be done
                  // as the processor executes the next instruction after
                  // interrupts are turned on.
                  interrupts ();  // one cycle
                  sleep_cpu ();   // one cycle
                  delay(20);  //debounce the button
                  voltage=analogRead(A0);  //throw out this first result
                  if (voltage>700) {
                    Serial.println(voltage);
                    Serial.flush();
                  How does that integrates with mysensors?
                    @gohan That's your department. :)
                    gohanG 1 Reply Last reply
                      @neverdie well... kind of... I haven't written mysensors' core so I don't know if it will clash with normal sleep management.
                        Here's an improved sketch that gives you the number (rather than the voltage) of the button that was pressed:
                        //  Description:
                        int key[12][3] = {  //min and max analogRead values for each key in the 3x4 keypad
                                          {0,993,1012},
                                          {1,848,865},
                                          {2,834,847},
                                          {3,800,833},
                                          {4,901,914},
                                          {5,884,900},
                                          {6,866,883},
                                          {7,948,969},
                                          {8,930,947},
                                          {9,915,929},
                                          {10,1013,1023},
                                          {11,970,992}
                         int identifyKey(uint16_t voltage) {
                          int i=0;
                          while ((i<12) && ((voltage<key[i][1]) || (voltage>key[i][2]))) {
                            i++;
                          return i;
                          pinMode(A0,INPUT);
                          pciSetup(A0);
                          Serial.flush();
                          uint16_t voltage;
                          sleep_enable();
                          noInterrupts ();
                          pciSetup(A0);
                          MCUCR = bit (BODS);
                          if (voltage>799) {
                            Serial.println(identifyKey(voltage));
                            Serial.flush();
                          CarywinC
                          CarywinC
                          Carywin
                          @gohan Sorry I don't have a way to measure current that small, but given that it's already run for months on the original batteries, I'm going to assume it's a "normal" Atmega sleep state
                            CarywinC
                            CarywinC
                            Carywin
                            @dbemowsk The Pro Mini does have pin change interrupts on every pin
                            dbemowskD 1 Reply Last reply
                              CarywinC
                              CarywinC
                              Carywin
                              @neverdie This is correct, but this testing is all handled by the EnableInterrupt library
                              • CarywinC Carywin
                                dbemowskD
                                dbemowskD
                                @carywin I stand corrected.
                                • wesW
                                  wesW
                                  wes
                                  wrote on last edited by wes
                                  #48
                                  @wes said in 6/8 Buttons battery remote node:
                                  I'm planning to use some cheap RF remotes and connect a RF receiver to my RPI, which hosts both my gateway and controller.
                                  I finally received the RF remotes and receiver/decoder from eBay and got them set up to talk directly to my controller - they work pretty well: https://youtu.be/9458-3IiG3Y
                                  I did try a OneButton-type approach on a MySensors node, but had lots of malfunctions with long-presses (e.g. fade up 10% per second whilst the button is depressed), where the the "button pressed" message gets through, but the "button released" message is delayed or dropped.
                                  Blog: https://www.wes.id.au/
                                  Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
                                  Gateway & Controller: Raspberry Pi 3 + Home Assistant
                                  • wesW wes
                                    @wes Maybe your resistors don't have a high enough power rating for the current that's running through them? i.e. holding down the button heats them up and therefore changes their resistance? That might explain the slowness to react as expected after the button is released. After release, they cool off and eventually return within their expected resistance tolerance, at which point the expected behavior finally happens.
                                      @NeverDie do you think a NRF5x would be better solution to make a small compact remote control?
                                        #51
                                        @gohan It's hard to answer a question like that in a vacuum, but in general, I do like nRF5x better than nRF24L01 beause of nRF5x's better link budget. I also like LoRa because of its great range and coverage. I have made remotes using each (and I have made posts about them), and they each have their place.
                                          did you post the nrf5x remote in the nrf5x topic or did you made a new one?
