  3. 6/8 Buttons battery remote node
53 Posts 7 Posters 12.3k Views 8 Watching
  • zboblamontZ zboblamont
    @neverdie Is this not an instance where a high efficiency low dropout booster supply would null this particular issue?
    @zboblamont said in 6/8 Buttons battery remote node:
    Yes, that trade-off would relax the constraints.
    But so does a one-time calibration. Since writing the above, I've warmed up to the idea. At least for my purposes, it's not that big a deal.
    Nca78N 1 Reply Last reply
      @neverdie said in 6/8 Buttons battery remote node:
      What about resistance variation due to temperature changes ? :)
      • Nca78N Nca78
        @nca78 said in 6/8 Buttons battery remote node:
        I hadn't really thought about that. Should I? In my case (12 buttons on a remote control) I'm assuming the resistors stay more or less room temperature.
          It would depend on the quality of your resistors, and if your room temperature varies. Cheap carbon film resistors can have relatively wide temperature coefficient variation range, I see over 1000ppm/°C between min and max of range for some "branded" resistors on Arrow.com so it could be worse with cheap aliexpress versions. So if you're unlucky you could get resistors in the two opposite parts of the range. With 27 units on average on a 1024 max value you have an average 27000ppm margin, so you should be ok if your keyboard stays inside, but it could become a problem if it's outside, a 30°C variation between summer and winter could in theory give your wrong results.
          But I suppose I'm really nitpicking here, you would need to be really unlucky with your resistors :D
            Since values are a bit far apart, I could make a range of values to be considered a specific key pressed.
              #29
              @gohan Exactly right.
              @gohan Does the Arduino keypad that you already have work on the same principle?
              Presently I'm doing the layout on a 3x4 matrix keypad that uses fewer resistors (using the design I referenced earlier), but which works on the same voltage dividing principle.
              gohanG 1 Reply Last reply
                @neverdie this is the one I'm talking about http://www.circuitstoday.com/interfacing-hex-keypad-to-arduino
                • wesW
                  wesW
                  wes
                  I have the same use case (remote control with buttons to control lights/scenes).
                  I'm planning to use some cheap RF remotes and connect a RF receiver to my RPI, which hosts both my gateway and controller.
                  Not sure if I'll receive the codes via MySensors, or write something that talks directly to the controller (thoughts on pros/cons of each approach welcome).
                  Of course this won't be as reliable or flexible as buttons connected to a MySensors node, but it should be enough for my needs.
                  Further thoughts welcome :-)
                  Blog: https://www.wes.id.au/
                  Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
                  Gateway & Controller: Raspberry Pi 3 + Home Assistant
                  • wesW wes
                    @wes said in 6/8 Buttons battery remote node:
                    I think you should change the remote controls into MySensors nodes. A bit more work at the beginning but you'll probably save a lot of hair pulling, reliability etc in the long term.
                    • CarywinC
                      CarywinC
                      Carywin
                      You can use pin change interrupts with MySensors sleep loops with an easy hack. Here's the code I use for 4 button battery powered nodes that also report temperature and humidity using DHT a sensor. I run them from 2 AA and so far they've been running for more than 6 months without showing signs of discharge. This could be easily modified for 6 or 8 buttons.
                      // MySensors EnviroButtons
                      // Temperature and Humidity Sensor with 4 Push Buttons
                      // Battery Powered Node
                      // Don't forget to change buttons and VCC_CAL for each node
                      // Cary Wintle - July 2017
                      // MySensors configuration
                      #define SN "EnviroButtons"  // Software name
                      #define SV "0.4"            // Version number
                      #define MY_NODE_ID 6
                      #define MY_RADIO_RFM69
                      #define MY_RFM69_NETWORKID 137
                      #define MY_RFM69_ENABLE_ENCRYPTION
                      #define MY_RFM69_NEW_DRIVER
                      #define MY_RFM69_FREQUENCY RFM69_433MHZ
                      #define MY_IS_RFM69HW
                      #define EI_NOTEXTERNAL // External interrupts managed by built-in routines
                      #include <EnableInterrupt.h> // Pin-change interrupts
                      #define DHT_DATA_PIN 8
                      // Buttons
                      #define BUTTON1_PIN A1 // 5: A1 - 6: A1
                      #define BUTTON2_PIN A2 // 5: A3 - 6: A2
                      #define BUTTON3_PIN A3 // 5: A2 - 6: A3
                      #define BUTTON4_PIN A0 // 5: A0 - 6: A0
                      #define SENSOR_TEMP_OFFSET 0
                      static const uint64_t UPDATE_INTERVAL = 120000;
                      #define BAT_UPDATE_INTERVAL 720 // 24 hrs - Interval between battery updates (multiples of UPDATE_INTERVAL)
                      // VCC Calibration Values
                      // Node 5: 1128953L
                      // Node 6: 1125300L
                      #define VCC_CAL 1125300L
                      static const uint8_t FORCE_UPDATE_N_READS = 30; // After an hour
                      float lastTemp;
                      float lastHum;
                      uint8_t nNoUpdatesTemp;
                      uint8_t nNoUpdatesHum;
                      int cycleCount = BAT_UPDATE_INTERVAL; // Send battery update immediately
                      volatile byte B1Int = 0, B2Int = 0, B3Int = 0, B4Int = 0; // Interrupt button flags
                      uint32_t now;
                      MyMessage msgHum(0, V_HUM);
                      MyMessage msgTemp(0, V_TEMP);
                      MyMessage msgButtons(0, V_SCENE_ON);
                      MyMessage msgBattV(0, V_VOLTAGE);
                      DHT dht;
                        sendSketchInfo(SN,SV);
                        // Present the sensor
                        present(0, S_CUSTOM, "Temp/Humid/Buttons");
                        // Setup pins the DHT sensor is on
                        digitalWrite(6, LOW);
                        pinMode(6, OUTPUT);
                        digitalWrite(7, LOW);
                        pinMode(7, OUTPUT);
                        digitalWrite(9, HIGH);
                        pinMode(9, OUTPUT);
                        sleep(2000);
                        dht.setup(DHT_DATA_PIN); // Setup the DHT sensor
                        pinMode(BUTTON1_PIN,INPUT_PULLUP);
                        pinMode(BUTTON2_PIN,INPUT_PULLUP);
                        pinMode(BUTTON3_PIN,INPUT_PULLUP);
                        pinMode(BUTTON4_PIN,INPUT_PULLUP);
                        enableInterrupt(BUTTON1_PIN,Button1,FALLING);
                        enableInterrupt(BUTTON2_PIN,Button2,FALLING);
                        enableInterrupt(BUTTON3_PIN,Button3,FALLING);
                        enableInterrupt(BUTTON4_PIN,Button4,FALLING);
                      void Button1() {
                        B1Int++;
                        _wokeUpByInterrupt = 0xFE; // Dirty hack to get out of MySensors sleep loop
                      void Button2() {
                        B2Int++;
                      void Button3() {
                        B3Int++;
                      void Button4() {
                        B4Int++;
                        _wokeUpByInterrupt = INVALID_INTERRUPT_NUM;
                        // Power up the DHT sensor
                        // Process buttons
                        if(B1Int > 0) {
                          send(msgButtons.set(1));
                          B1Int = 0;
                        } else if(B2Int > 0) {
                          send(msgButtons.set(2));
                          B2Int = 0;
                        } else if(B3Int > 0) {
                          send(msgButtons.set(3));
                          B3Int = 0;
                        } else if(B4Int > 0) {
                          send(msgButtons.set(4));
                          B4Int = 0;
                        // Wait for the DHT sensor to init
                        sleep(2000);
                        dht.readSensor(true);
                        if (isnan(temperature)) {
                          lastTemp = temperature;
                          // Reset no updates counter
                          nNoUpdatesTemp = 0;
                          #ifdef MY_DEBUG
                          Serial.print("T: ");
                          nNoUpdatesTemp++;
                        byte humidity = (byte)dht.getHumidity();
                        if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS) {
                          lastHum = humidity;
                          nNoUpdatesHum = 0;
                          #ifdef MY_DEBUG
                          Serial.print("H: ");
                          Serial.println(humidity);
                          nNoUpdatesHum++;
                        if (cycleCount >= BAT_UPDATE_INTERVAL) {
                          cycleCount = 0;
                          int BatV = readVCC();
                          #ifdef MY_DEBUG
                          Serial.print("BatVR: ");
                          Serial.println(BatV);
                          float BatVolts = BatV / 1000.0;
                          #ifdef MY_DEBUG
                          Serial.print("BatV: ");
                          Serial.println(BatVolts);
                          send(msgBattV.set(BatVolts, 2));
                          float BatPercent = (BatVolts - 2.8) / 0.6 * 100;
                          if(BatPercent > 100) BatPercent = 100;
                          #ifdef MY_DEBUG
                          Serial.print("Bat%: ");
                          Serial.println(BatPercent);
                          sendBatteryLevel((int)BatPercent);
                        cycleCount++;
                        // Power down the DHT sensor
                        digitalWrite(9, LOW);
                        sleep(UPDATE_INTERVAL);
                      int readVCC() {
                        wait(2); // Wait for Vref to settle
                        int result = (high<<8) | low;
                        #ifdef MY_DEBUG
                        Serial.print("R: ");
                        Serial.println(result);
                        result = VCC_CAL / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
                      dbemowskD gohanG 2 Replies Last reply
                      • CarywinC Carywin
                        // Buttons
                        // Node 5: 1128953L
                        // Node 6: 1125300L
                        float lastTemp;
                        float lastHum;
                        uint32_t now;
                        DHT dht;
                          pinMode(6, OUTPUT);
                          pinMode(7, OUTPUT);
                          pinMode(9, OUTPUT);
                          sleep(2000);
                        void Button1() {
                          B1Int++;
                        void Button2() {
                          B2Int++;
                        void Button3() {
                          B3Int++;
                        void Button4() {
                          B4Int++;
                          // Process buttons
                          if(B1Int > 0) {
                            B1Int = 0;
                            B2Int = 0;
                            B3Int = 0;
                            B4Int = 0;
                          sleep(2000);
                            nNoUpdatesTemp = 0;
                            #ifdef MY_DEBUG
                            nNoUpdatesTemp++;
                            lastHum = humidity;
                            nNoUpdatesHum = 0;
                            #ifdef MY_DEBUG
                            nNoUpdatesHum++;
                            cycleCount = 0;
                            #ifdef MY_DEBUG
                            #ifdef MY_DEBUG
                            #ifdef MY_DEBUG
                          cycleCount++;
                        int readVCC() {
                          #ifdef MY_DEBUG
                        dbemowskD
                        dbemowskD
                        @carywin Certain arduinos such as the pro minis can ONLY do interrupts on pins 2 or 3 from my understanding.
                        NeverDieN CarywinC 2 Replies Last reply
                        • CarywinC Carywin
                          // Buttons
                          // Node 5: 1128953L
                          // Node 6: 1125300L
                          float lastTemp;
                          float lastHum;
                          uint32_t now;
                          DHT dht;
                            pinMode(6, OUTPUT);
                            pinMode(7, OUTPUT);
                            pinMode(9, OUTPUT);
                            sleep(2000);
                          void Button1() {
                            B1Int++;
                          void Button2() {
                            B2Int++;
                          void Button3() {
                            B3Int++;
                          void Button4() {
                            B4Int++;
                            // Process buttons
                            if(B1Int > 0) {
                              B1Int = 0;
                              B2Int = 0;
                              B3Int = 0;
                              B4Int = 0;
                            sleep(2000);
                              nNoUpdatesTemp = 0;
                              #ifdef MY_DEBUG
                              nNoUpdatesTemp++;
                              lastHum = humidity;
                              nNoUpdatesHum = 0;
                              #ifdef MY_DEBUG
                              nNoUpdatesHum++;
                              cycleCount = 0;
                              #ifdef MY_DEBUG
                              #ifdef MY_DEBUG
                              #ifdef MY_DEBUG
                            cycleCount++;
                          int readVCC() {
                            #ifdef MY_DEBUG
                          @carywin what is the sleep current of your node with this "interrupt hack"?
                          CarywinC 1 Reply Last reply
                            Here's the PCB I made for the matrix keypad:
                            The whole thing fits on a single sided PCB. :)
                            • dbemowskD dbemowsk
                              @dbemowsk said in 6/8 Buttons battery remote node:
                              IIRC, you can do interrupts from other pins too, but each is tied to a separate bank of pins, so you have to do additional testing to determine which specific pin triggered the interrupt. In the case of the voltage divider keypad, that should be no problem.
                                #38
                                Here's the link: https://playground.arduino.cc/Main/PinChangeInterrupt
                                So, in this scenario, it would be:
                                ISR (PCINT1_vect) pin change interrupt for A0 to A5
                                  Here's a revision of the earlier code so that it uses ONLY ONE PIN (namely, A0) on the Arduino. And yes, this does work on a pro mini too, because that's what I tested it on. :)
                                  //  Description:
                                  //  Use just A0 to process the 12 button keypad.
                                  //  Button press is detected by interrupt set on A0.
                                  //  Which button was pressed is determined by an analog read of A0.
                                  // Note: sleep code borrows from Nick Gammon's Schedule J
                                  // Interrupt code borrows from https://playground.arduino.cc/Main/PinChangeInterrupt
                                  #include <avr/sleep.h>
                                  void pciSetup(byte pin)
                                      *digitalPinToPCMSK(pin) |= bit (digitalPinToPCMSKbit(pin));  // enable pin
                                      PCIFR  |= bit (digitalPinToPCICRbit(pin)); // clear any outstanding interrupt
                                      PCICR  |= bit (digitalPinToPCICRbit(pin)); // enable interrupt for the group
                                  ISR (PCINT1_vect) // handle pin change interrupt for A0 to A5 here
                                       //no need to do anything beyond just waking up.
                                    pinMode(A0,INPUT);
                                    pciSetup(A0);
                                    Serial.flush();
                                    uint16_t voltage;
                                    set_sleep_mode (SLEEP_MODE_PWR_DOWN);
                                    sleep_enable();
                                    // Do not interrupt before we go to sleep, or the
                                    // ISR will detach interrupts and we won't wake.
                                    noInterrupts ();
                                    pciSetup(A0);
                                    // turn off brown-out enable in software
                                    // BODS must be set to one and BODSE must be set to zero within four clock cycles
                                    MCUCR = bit (BODS) | bit (BODSE);
                                    // The BODS bit is automatically cleared after three clock cycles
                                    MCUCR = bit (BODS);
                                    // We are guaranteed that the sleep_cpu call will be done
                                    // as the processor executes the next instruction after
                                    // interrupts are turned on.
                                    interrupts ();  // one cycle
                                    sleep_cpu ();   // one cycle
                                    delay(20);  //debounce the button
                                    voltage=analogRead(A0);  //throw out this first result
                                    if (voltage>700) {
                                      Serial.println(voltage);
                                      Serial.flush();
                                    How does that integrates with mysensors?
                                      @gohan That's your department. :)
                                        @neverdie well... kind of... I haven't written mysensors' core so I don't know if it will clash with normal sleep management.
                                          Here's an improved sketch that gives you the number (rather than the voltage) of the button that was pressed:
                                          //  Description:
                                          int key[12][3] = {  //min and max analogRead values for each key in the 3x4 keypad
                                                            {0,993,1012},
                                                            {1,848,865},
                                                            {2,834,847},
                                                            {3,800,833},
                                                            {4,901,914},
                                                            {5,884,900},
                                                            {6,866,883},
                                                            {7,948,969},
                                                            {8,930,947},
                                                            {9,915,929},
                                                            {10,1013,1023},
                                                            {11,970,992}
                                           int identifyKey(uint16_t voltage) {
                                            int i=0;
                                            while ((i<12) && ((voltage<key[i][1]) || (voltage>key[i][2]))) {
                                              i++;
                                            return i;
                                            pinMode(A0,INPUT);
                                            pciSetup(A0);
                                            Serial.flush();
                                            uint16_t voltage;
                                            sleep_enable();
                                            noInterrupts ();
                                            pciSetup(A0);
                                            MCUCR = bit (BODS);
                                            if (voltage>799) {
                                              Serial.println(identifyKey(voltage));
                                              Serial.flush();
