  2. Announcements
  3. πŸ’¬ Power Meter Pulse Sensor
183 Posts 40 Posters 93.0k Views 37 Watching
    Any more suggestions on the Watt issue?
      Did you by any chance change SLEEP_MODE to true?
      gohanG 1 Reply Last reply
        No, I get every pulse reported as soon as it is detected.
          wrote on last edited by gohan
          #113
          I think I found a problem: the WATT calculation is returning values over 172000 watts and since I put 10000 as the max value, it was not sending anything. I double checked my energy meter and indeed it is 1000 pulses per KWH and this is what I set in sketch
            @hek I said I found the problem, I didn't say I know how to solve it πŸ˜…
              Here is the log I get from node
              7230 TSF:MSG:READ,0-0-250,s=1,c=2,t=24,pt=0,l=7,sg=0:1682675
              rece
              Received last pulse count from gw:1682675
              11817 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=17,pt=5,l=4,sg=0,ft=0,st=OK:528
              Watt:528
              Watt:197065
              21820 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682677
              21913 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6770
              Watt:196807
              36824 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682679
              36917 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6790
              Watt:197368
              51827 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682681
              51920 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6810
              Watt:196850
              Am I the only one using this sketch?
                mickecarlsson
                Please post you sketch.
                  it is the one in https://www.mysensors.org/build/pulse_power
                    mickecarlsson
                    wrote on last edited by mickecarlsson
                    #118
                    How is the pulse counter set up? Is it connected to the S0 port?
                    Edit:
                    If you are using S0 it is vital that you use a pull down resistor, if you dont’t have that you get false pulses.
                    pulse connection
                      I'm using the lm393 light detector. Domoticz is able to do a calculation from the pulses to give a Watt value and it is correct but it does it every 5 minutes and it is too slow for me
                        sundberg84S
                        sundberg84S
                        @gohan - is Domoticz updating anything (except switches) faster than 5 min? I dont think so...
                        S 1 Reply Last reply
                          If you send the watt reading faster it updates like the switch, anyway I need the watt values for node-red also
                            Could it be the Light sensor is triggering more interrupts from each pulse?
                            • NiklasON NiklasO
                              Just changed from 1-wire counter to MySensors for logging my power consumption. Using the same LED detector as I did when using 1-wire. Also changed watt limit to 20 000 (my heat pump likes to use 9-10kW sometimes). The wires from the old 1-wire net now provide power for the new MySensors-sensor. I have 10 000 led blinks per kWh. Had som crazy counter values with 1-wire that totally messed up the graphs and haven't seen anything like that with this sketch. Let's hope it stays that way. ;) Dumping data to Domoticz. This sensor gives me higher resolution as a bonus. The 1-wire counter was read every minute, this every 20-sec. ;-)
                              My old 1-wire counter with one crazy value messing upp all the graphs:
                              I know that you can hold shift and click the value that is crazy to make the graphs show up good but you loose the data for the full day. That's not good. ;-)
                              henninneH
                              henninneH
                              henninne
                              @niklaso
                              Hi Niklas,
                              I know this is a very old post, but its worth a try. How did you get out the daily Kwh usage? As default my sensor only gives Watts and Kwh (accumulated from start), I have tried to run a Scene in Vera UI7 where there are a function in the sensor called resetKWh(), but it looks like it doesn't do anything. Any tips would be great, thanks.
                              Henning
                              • sundberg84S sundberg84
                                smilvert
                                @gohan I think it is a little tricky to update domoticz every minute but try update the sql-file, see the domoticz forum
                                https://www.domoticz.com/forum/viewtopic.php?t=10183
                                  The main issue is the fact that the sensor is not calculating the instant power correctly
                                  xydixX 1 Reply Last reply
                                  • D
                                    DaTim69
                                    I created this kWh sensor with the TCRT5000 IR Barrier Line Track Sensor.
                                    My powermeter is a ferarrismeter with 375 rotations per kWh.
                                    I also had the problem with spikes in the power usage. But after long...too long investigation I solved the problem.
                                    At my config it was a double issue.
                                    Issue 1.
                                    The problem is the pulse width of the rotation.
                                    The pulse are at night ( low power) much wider that during the day when more power is consumed. At night the spikes in power usage where huge.
                                    Issue 2.
                                    Switching on/off the halogen light causes spikes and related to also strange power measurement.
                                    Solution:
                                    I added a second arduino mini pro as a pulse regulator between the TCRT5000 and the power meter arduino.
                                    this arduino triggers on Rising and will always give a 100ms puls. Als debounce is handled (spikes).
                                    I don't upload the sketch here, I'm a beginning programmer on arduino. It's made on " trail and error" but it functions as it supposed to do.
                                    If someone wants a copy feel free to contact mee
                                      xydixX
                                      xydixX
                                      xydix
                                      @gohan Did you solve this?
                                      I get very high watt usage as well. Sometimes like 40 000 - 130 000 watt if I check the serial monitor.
                                      Of course, those values will never be sent to the controler.
                                        Nope, I am looking at other things now. Very little time available for too many things. I'm looking at buying CT clamp and do a more direct measurement.
                                        • xydixX
                                          xydixX
                                          xydix
                                          wrote on last edited by xydix
                                          #129
                                          Okay. Really annoying. Check this.
                                          Received last pulse count from gw:2527
                                          Watt:121065
                                          22235 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2539
                                          22246 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5390
                                          Watt:121621
                                          42238 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2551
                                          42250 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5510
                                          Watt:121342
                                          62239 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2563
                                          62251 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5630
                                          Watt:121539
                                          82240 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2575
                                          82251 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5750
                                          Watt:121951
                                          102239 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2589
                                          102250 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5890
                                          Watt:122067
                                          122243 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2601
                                          122254 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.6010
                                          The plus count seems OK, right?
                                          My energy meter is 1000 pluses /kwh
                                          Here is my sketch. I use Home assistant so i created three sensors for this as I don't think V_VAR1 is supported with S_POWER.
                                          Otherwise it is the standard example.
                                           * Version 1.0 - Henrik EKblad
                                           * This sketch provides an example how to implement a distance sensor using HC-SR04
                                           * Use this sensor to measure KWH and Watt of your house meeter
                                           * You need to set the correct pulsefactor of your meeter (blinks per KWH).
                                           * The sensor starts by fetching current KWH value from gateway.
                                           * Reports both KWH and Watt back to gateway.
                                           * Unfortunately millis() won't increment when the Arduino is in
                                           * sleepmode. So we cannot make this sensor sleep if we also want
                                           * to calculate/report watt-number.
                                           * http://www.mysensors.org/build/pulse_power
                                          // Enable debug prints
                                          #define MY_NODE_ID 78
                                          #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
                                          #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
                                          #define MAX_WATT 20000          // Max watt value to report. This filetrs outliers.
                                          #define WATT_CHILD_ID 1              // Id of the sensor child
                                          #define KWH_CHILD_ID 2
                                          #define PC_CHILD_ID 3
                                          unsigned long SEND_FREQUENCY =
                                              20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                                          double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
                                          bool pcReceived = false;
                                          unsigned long oldPulseCount = 0;
                                          unsigned long oldWatt = 0;
                                          double oldKwh;
                                          unsigned long lastSend;
                                          MyMessage wattMsg(WATT_CHILD_ID,V_WATT);
                                          MyMessage kwhMsg(KWH_CHILD_ID,V_KWH);
                                          MyMessage pcMsg(PC_CHILD_ID,V_VAR1);
                                            request(PC_CHILD_ID, V_VAR1);
                                            pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
                                            attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
                                            lastSend=millis();
                                            present(WATT_CHILD_ID, S_POWER);
                                            present(KWH_CHILD_ID, S_POWER);
                                            present(PC_CHILD_ID, S_CUSTOM);
                                            unsigned long now = millis();
                                            if (pcReceived && (SLEEP_MODE || sendTime)) {
                                              if (!SLEEP_MODE && watt != oldWatt) {
                                                if (watt<((unsigned long)MAX_WATT)) {
                                                Serial.print("Watt:");
                                                Serial.println(watt);
                                                oldWatt = watt;
                                              // Pulse cout has changed
                                              if (pulseCount != oldPulseCount) {
                                                send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                                                double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                                                oldPulseCount = pulseCount;
                                                if (kwh != oldKwh) {
                                                  send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                                                  oldKwh = kwh;
                                              lastSend = now;
                                            } else if (sendTime && !pcReceived) {
                                              // No count received. Try requesting it again
                                              lastSend=now;
                                            if (SLEEP_MODE) {
                                              sleep(SEND_FREQUENCY);
                                            if (message.type==V_VAR1) {
                                              pulseCount = oldPulseCount = message.getLong();
                                              Serial.print("Received last pulse count from gw:");
                                              Serial.println(pulseCount);
                                              pcReceived = true;
                                          void onPulse()
                                            if (!SLEEP_MODE) {
                                              unsigned long interval = newBlink-lastBlink;
                                              if (interval<10000L) { // Sometimes we get interrupt on RISING
                                                return;
                                              watt = (3600000000.0 /interval) / ppwh;
                                              lastBlink = newBlink;
                                            pulseCount++;
                                          Anyone got any ideas?
                                          BTW. First i tried the original example sketch, unmodified, with the same result.
                                          With your input, this post could be even better πŸ’—
