  3. Vera
  4. veralite ui5 not seeing distance sensor in 1.4
5 Posts 2 Posters 1.8k Views 1 Watching
  • 5546dug5
    5546dug5
    5546dug
    ok here is problem added distance sketch from my sensors and when included, plugin saw 2 devices, node1 and distance 1.
    both boxes are blank as well as my sensors plugin box
    Have been using temp/humidity successfully for the last few weeks. After including new device allboxes ( distance,temp,hum,and plugin) are there but blank.
    Using veralite ui5, lib 1.4 and issue 1.4
    I have tried with only distance deleting the temp portion and reinstalling plugin and including with same results. reverting back to both units gave the same results?
    I have included pic .
    Is there something I missed and need to do with the gw? or new node?
    It is on a pro mini 5v clone with3 v regulator for radio and seemed to compile correctly and uploaded with no problems
    any ideas
    • 5546dug5
      5546dug5
      5546dug
        Did you upload the Distance device files?
        http://www.mysensors.org/build/vera#device-specific-settings-and-files
        • 5546dug5
          5546dug5
          5546dug
          Thanks @hek!
          Another problem solved for the rookie!
          • 5546dug5
            5546dug5
            5546dug
            all sensors are good now thanks! @hek
