1.1k Posts 105 Posters 796.0k Views 98 Watching
    #385
    Interestingly, I just now checked, and it appears my LoRa leak detectors have even better range still. Maybe it's because GND completely encircles the PCB along all four edges. This may cause me to rethink the design of the gateway node, which up to now has been much smaller than the leak detectors....
    • sundberg84S
      sundberg84S
      #386
      Today some maintenance on my GW.
      Added a ground wire for debug and also corrected a buildmisstske and grounded the case.
      And relocated (let's hope for the best) it to my new HA DIY board...
      NeverDieN YveauxY 2 Replies Last reply
      • sundberg84S
        sundberg84S
        #387
        And there was the first failing sensor.... But was it because I changed the location on the gw? Nope... I had a temp/hum right beside the gw which I pushed so it fell on the floor...
        Radio cap de-attashed and sensor died.
        Easy fix and now back in operation.
        gohanG 1 Reply Last reply
        • sundberg84S sundberg84
          @sundberg84 Sorry for the stupid question, but what holds your WEB/MAIL black box in place?
            You meant "the first FALLING sensor" :sweat_smile:
              sundberg84S
              sundberg84S
              #390
              @neverdie said in What did you build today (Pictures) ?:
              Screws.
                @sundberg84 +1 for the mySensors sticker!
                • petewillP
                  petewillP
                  petewill
                  My son and I finally finished his first MySensors project- a remote control for his room. He wasn't too interested but you have to start somewhere right...? :)
                  Question for you all... what are you doing (if anything) to vent the fumes from soldering? I haven't really been worried about it in the past but it makes me nervous with my son doing it with me.
                  Anyway, here are the pictures.
                  NeverDieN dbemowskD mfalkviddM gohanG Nca78N 5 Replies Last reply
                  • petewillP petewill
                    #393
                    @petewill What up with the red, yellow, and blue wires on the pro mini?
                    Also, did you print the case with a volcano?
                      dbemowskD
                      dbemowskD
                      @petewill That's awesome. Did you work with him too on the design of the box? Great job.
                        @petewill I put a regular 120mm pc fan to blow the fumes sideways. Not perfect, but I think it is good enough for the short time I spend soldering.
                          @petewill is it battery powered? Can you share the code?
                            sundberg84S
                            sundberg84S
                            #397
                            @petewill , @gohan I use the same as @mfalkvidd and its pretty much a PC fan with the wires to a 9v battery.... been thinking for a long time to make a more permanent sollution with a tubes from outside....
                            • mfalkviddM
                              #398
                              Today's test was to see if the regular reed switches can be closed by the magnetic field created by a 1A current.
                              I got an opportunity to try out my recently USB power meter and adjustable load.
                              Since I am not sure how the reed switch is mounted inside the sensor, I tried different orientations but nothing triggered the sensor. I also tried 2A but that wasn't enough either.
                              I need a non-invasive way to know if (how much) current is flowing in a DC cable. I was hoping the reed switch would be an easy way. My next hope is something like a SCT-013, unless someone has suggestions for other sensors. Requirements: 6-48V DC. 0.5-10A. I only need to know if the circuit is consuming >0.5A, no need for an exact measurement.
                              gohanG NeverDieN 2 Replies Last reply
                                @mfalkvidd Hall sensor?
                                  #400
                                  @gohan SCT-013 is a hall-based sensor I think. I was looking for more specific that just the type of sensor.
                                    @mfalkvidd said in What did you build today (Pictures) ?:
                                    No, it's only a current transformer, and you possibly need (at least) a burden resistor to measure the current. Ofcourse we already have a thread on it ;-)
                                    • YveauxY Yveaux
                                      @yveaux yes I've read that thread and I would choose one of the sct-013 variants that already contains a burden resistor.
                                        #403
                                        @mfalkvidd Didn't you play with electromagnets when you were a kid? At least try coiling the wire and maybe putting a metal core inside it. Use a lot of coils. The more the better. Then maybe your reed-type switch would have a chance of seeing enough magnetism to trigger it.
                                        gohanG mfalkviddM 2 Replies Last reply
                                          @neverdie wouldn't that choke the current passing through the coil? He said he needs 6-48V DC. 0.5-10A
