  3. SCT-013-030 to measure watt
12 Posts 5 Posters 25.5k Views 6 Watching
  • Patrik SöderströmP
    Patrik SöderströmP
    Patrik Söderström
    I would like to reach the watt usage. I would like to use SCT-013-030, but as it seems to have a 3.5" connector, how can I connect this to my arduino? I can only see project where one is using pulse power. But with this one I would not need to install a new energy meter where I would like to read the watt usage.
    Any tips and ideas?
    • FleischtorteF
      FleischtorteF
      Fleischtorte
      wrote on last edited by Fleischtorte
      Hi Patrik,
      i use two of these to monitor my washer and dryer. Here is the schematic:
      And the MS-Sketch:
      SCT_Dual_Sensor MySensors 2.0 EmonLib
      // Enable debug prints
      //#define MY_DEBUG
      // Set Static NodeID
      #define MY_NODE_ID 5
      #define MY_RADIO_RFM69
      #define MY_RFM69_FREQUENCY RF69_868MHZ
      #define MY_RFM69_NETWORKID 121
      #define MY_RFM69_ENABLE_ENCRYPTION
      #define MY_REPEATER_FEATURE
      #include <EmonLib.h>
      #define ANALOG_INPUT_SENSOR1  1
      #define ANALOG_INPUT_SENSOR2  2
      #define CHILD_ID_PWR1 1              // Id of the sensor child
      #define CHILD_ID_PWR2 2              // Id of the sensor child
      #define CHILD_ID_RSSI 7              // Id for RSSI Value
      //Init Emon
      EnergyMonitor emon1;
      EnergyMonitor emon2;
      //Set Vars
      unsigned long SLEEP_TIME = 60000 - 3735; // sleep for 60 seconds (-4 seconds to calculate values)
      long wattsum1 = 0;
      double kwh1 = 0;
      double wh1= 0;
      int minutes1 = 61;
      long wattsum2 = 0;
      double kwh2 = 0;
      double wh2 = 0;
      int minutes2 = 61;
      //Int Messages
      MyMessage wattMsg1(CHILD_ID_PWR1,V_WATT);
      MyMessage kwhMsg1(CHILD_ID_PWR1,V_KWH);
      MyMessage wattMsg2(CHILD_ID_PWR2,V_WATT);
      MyMessage kwhMsg2(CHILD_ID_PWR2,V_KWH);
      MyMessage rssiMsg(CHILD_ID_RSSI,V_TEXT);
       emon1.current(ANALOG_INPUT_SENSOR1, 30);             // Current: input pin, calibration. stock = 30
       emon2.current(ANALOG_INPUT_SENSOR2, 30);             // Current: input pin, calibration. stock = 30
       double Irms1 = emon1.calcIrms(1480);  // initial boot to charge up capacitor (no reading is taken) - testing
       double Irms2 = emon2.calcIrms(1480);  // initial boot to charge up capacitor (no reading is taken) - testing
      void presentation() {
        sendSketchInfo("Energy Meter Dual SCT013", "0.1");
        present(CHILD_ID_PWR1, S_POWER);
        present(CHILD_ID_PWR2, S_POWER);
        present(CHILD_ID_RSSI, S_INFO);
        // power used each minute
        if (minutes1 < 60) {
          double Irms1 = emon1.calcIrms(1480);  // Calculate Irms only
          if (Irms1 < 0.3) Irms1 = 0;
          long watt1 = Irms1*230.0;  // default was 230 but our local voltage is about 240
          wattsum1 = wattsum1+watt1;
          minutes1++;
          send(wattMsg1.set(watt1));  // Send watt value to gw
          Serial.print(watt1);         // Apparent power
          Serial.print("W, I= ");
          Serial.print(Irms1);          // Irms
          int var1 = _radio.RSSI;
          send(rssiMsg.set(var1));  // Send RSSI value to gw
        // end power used each minute
         if (minutes2 < 60) {
          double Irms2 = emon2.calcIrms(1480);  // Calculate Irms only
          if (Irms2 < 0.3) Irms2 = 0;
          long watt2 = Irms2*230.0;  // default was 230 but our local voltage is about 240
          wattsum2 = wattsum2+watt2;
          minutes2++;
          send(wattMsg2.set(watt2));  // Send watt value to gw
          Serial.print(watt2);         // Apparent power
          Serial.print(Irms2);          // Irms
        // hours KW reading
        if (minutes1 >= 60) {
          wh1 = wh1 + wattsum1/60;
          kwh1 = wh1/1000;
          send(kwhMsg1.set(kwh1, 4)); // Send kwh value to gw
          wattsum1 = 0;
          minutes1 = 0;
        // end of hourly KW reading
          // hours KW reading
        if (minutes2 >= 60) {
          wh2 = wh2 + wattsum2/60;
          kwh2 = wh2/1000;
          send(kwhMsg2.set(kwh2, 4)); // Send kwh value to gw
          wattsum2 = 0;
          minutes2 = 0;
      //sleep until the next minute
      sleep(SLEEP_TIME);
      Also check this site : https://openenergymonitor.org/emon/buildingblocks/ct-sensors-interface
      • TmasterT
        TmasterT
        Tmaster
        wrote on last edited by Tmaster
        for the SCT-013-000(100A) ,what differ? just the calibration value?
        i'm a arduino fan .Even sometimes don't undestanding how to use it :P
        • FleischtorteF
          FleischtorteF
          Fleischtorte
          Hi Tmaster,
          the SCT-013-030 have an build in burden, the SCT-013-000 dont have one. So you need to calculate the right burden and set the right calibration value (see https://openenergymonitor.org/emon/buildingblocks/how-to-build-an-arduino-energy-monitor-measuring-current-only)
          • dbemowskD
            dbemowskD
            So I have a question on this. I have a couple of the SCT-013-050 sensors, but plan on purchasing some of the SCT-013-000 sensors as I will need to read higher amperage from my incoming mains lines. The SCT-013-030 (and I think the SCT-013-050) contain the burden resistor. The open energy monitor project says to choose the burden resistor based on the voltage that you are running the arduino at (3.3 or 5 volts) . My question is the ones that have the burden resistor built in, what voltage is it designed to run at?
            Talat KeleşT 1 Reply Last reply
            • dbemowskD dbemowsk
              Talat KeleşT
              Talat KeleşT
              Talat Keleş
              wrote on last edited by Talat Keleş
              @dbemowsk
              Short answer: Built-in burden versions output 1V for rated current. Therefore 030 version has 1V for 30A, and 050 has 1V for 50A current. Either 3.3 or 5V supply, 1Vrms swing is almost in ADC range. So you can use 1V output types in any system. Just adjust the calibration constant in sketch.
              Long answer: SCT-013-000 version user-selected burden let you control voltage output, so you can have i.e. 2.5Vp-p output for a 5V system or 1.65Vp-p for a 3.3V system to fully utilize ADC range.
              Let's assume you select a burden for 1Vrms (±1.707 Vp-p) @50A (R=~28,28ohm) which will be identical to a 050 model, however selecting a burden for 1.76 Vrms (±2,49Vp-p)@50A will have better resolution (mV per ADC step) in a 5V system.
              Ideal value calculation is stated as: Burden Resistor (ohms) = (AREF * CT TURNS) / (2√2 * max primary current) So, ~68 ohm will use whole 0-5V range (±2,49Vp-p) OR ~47 ohm in 0-3.3V (±1,66Vp-p) range and will have best resolution.
              dbemowskD 1 Reply Last reply
              • Talat KeleşT Talat Keleş
                @dbemowsk
                dbemowskD
                dbemowskD
                @Talat-Keleş Thanks for the response. Now that I look at the case of the CT, I see that it says 1V. I am a bit stumpped on how to adjust the sketch to measure the 0.5v p-p rather than the 2.5v p-p that it uses in the sketch.
                Also, I am a bit confused on the calibration value (111.1) in this line:
                emon1.current(1, 111.1);             // Current: input pin, calibration.
                My assumption would be that that is the actual incoming voltage for it to use in calculating the current. Is this correct? If this is the case, would it be possible to use a transformer say from an old wall wart that would take the line voltage and bring it down to say 6 - 12 volts and read that somehow on another analog pin to get a more exact value for the calibration?
                  Talat KeleşT
                  Talat KeleşT
                  Talat Keleş
                  Your CT gives 1V already, there is nothing to change in sketch. That output is physical voltage on Analog pin. Just need to adjust calibration value to read correct Amps as:
                  Since you own 050
                  emon1.current(1, 50);
                  as calibration constant. All above calculations and given calibration values on web for 000 model.
                  I didn't clearly understand what you want to achieve. For current calibration you don't need voltage values. If you take apart a wall-wart you can use that for calculating real power, power factor etc.
                    Since you own 050
                    dbemowskD
                    dbemowskD
                    That's where I was confused. I thought that was a voltage calibration value for calculating watts using the formula:
                    P(watts) = I(Current) X E(Voltage)
                    What I was talking about was getting an accurate wattage measurement by more precisely calculating the voltage using the transformer method. Now that I look at the sketch closer, that would be more for this line of code:
                    Serial.print(Irms*230.0);
                    Where you would use the transformer to more precisely calculate the voltage to use in the sketch. In the example sketch they use an estimated value of 230.0.
                      Talat KeleşT
                      Talat KeleşT
                      Talat Keleş
                      @dbemowsk
                      For precise wattage measurement you need transformer as you think. Irms*230.0 is just a rough estimation. You can measure outlet voltage and use that value in sketch for better estimation.
                      With transformer you use calcVI() instead of Irms*230. i.e below sketch, that measure both I and V, and calculate power (watt and VA, and other AC related stuff):
                      #include "EmonLib.h"              // Include Emon Library
                      EnergyMonitor emon1;              // Create an instance
                        Serial.begin(9600);
                        emon1.voltage(2, 234.26, 1.7);  // Voltage: input pin, calibration, phase_shift
                        emon1.calcVI(20,2000);          // Calculate all. No.of crossings, time-out
                        emon1.serialprint();            // Print out all variables
                        @dbemowsk
                          Serial.begin(9600);
                        dbemowskD
                        dbemowskD
                        @Talat-Keleş Perfect. Thanks for all your help.
                        • dbemowskD
                          dbemowskD
                          So my current transformers just came. I would like to build the circuit for this and I have one question. For the burden resistor and the voltage divider resistors, can I use 1/8 watt resistors or would I be better with 1/4 watt or higher?
