716 Posts 111 Posters 703.2k Views 93 Watching
    #532
    @sundberg84
    not sure but on your preview, I see that you don't use any gnd planes?? Imho, just sayin for your users :), it would be better to have it, ideally unbroken+ vias, for impedance, emi, rf counterpoise, impedance matching rf feedline to sma depending on its length and how it's routed etc.., maybe a little google it ;)
    looks nice :+1:
    • scalzS scalz
      @sundberg84
      looks nice :+1:
      sundberg84S
      sundberg84S
      @scalz - yes it is true about ground plane! I did that one rev 4 or something but something broke the thing... so I have been hesitating since but I know all about the benefits - been reading and googling.
      I have not made any traces or planes on the images - just component placement. I will give it another shot... maybe I have learned some since rev 4 ;)
      Thanks for your feedback.
      AnticimexA 1 Reply Last reply
      • sundberg84S sundberg84
        AnticimexA
        AnticimexA
        Anticimex
        @sundberg84 I forgot to mention that your nRF24 module goes very close to the MYSX. There is a risk a female receptacle might collide with the rf module if you are unlucky. And daughterboards will most likely be at least as wide as the courtyard of the MYSX.
          #535
          @sundberg84
          yes not talking about your latest but saw that on your rev9 and 10 pics.
          it will make it better, and it's good point for rf quality (range and msg fail) ;)
          placing planes is one of the first thing I usually do after component placements.. then it's easier to route as it solves many connection.
          keep the good work!
            Mr_sensor
            @sundberg84 I have a "newby" question about how to use the Extra's part of the board. If I want to connect a DS18B20 sensor per example can I just solder it on the extra area and connect is with some wires to the pinout I need?
            Asking this because I did this with the i2c sensor on the board discussed here. having a wire form the extras towards the arduino i2c pins directly. Later I discovered that the i2c pins are also on the board.
            So how to deal with this?
              you can add a wire to the I2C pins, in your case you just need a short wire to a digital pin that are just next to the Extra area
                Mr_sensor
                @gohan said in 💬 Easy/Newbie PCB for MySensors:
                Ok. And if attaching a DS18B20 I have a pull up resistor soldered on the board. Than it is also just the digital pin I need from the board? D3 I think?
                • M Mr_sensor
                  sundberg84S
                  sundberg84S
                  #539
                  @mr_sensor with a DS18B20 temp sensor I just solder it to the MysX pins (D3, Gnd and VCC) directly and populate the resistor for D3.
                    Mr_sensor
                    wrote on last edited by Mr_sensor
                    #540
                    @sundberg84 Yes thanks I did so. But do not get any temp read out? Have al in space also the 4,7 k resistor.
                    this is my sketch:
                    [code]
                     * Version 1.0: Henrik EKblad
                     * Dallas temperature sensor DS18B20
                     HTU21D Humidity Sensor
                     Hardware Connections (Breakoutboard to Arduino):
                     -VCC = 3.3V
                     -GND = GND
                     -data  = D3 met pcb 470 uf resistor
                    #define MY_NODE_ID 4
                    #define MY_PARENT_NODE_ID 0
                    // Enable debug prints
                    //#define MY_RS485
                    #include <OneWire.h>
                    //#include <Wire.h>
                    //static const uint8_t FORCE_UPDATE_N_READS = 10;
                    //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
                    int numSensors=0;
                    bool receivedConfig = false;
                    bool metric = true;
                    #define CHILD_ID_TEMP 0
                    #define CHILD_ID_BATTERY 1
                    #define CHILD_ID_VOLT 2
                    //#define CHILD_ID_PRCNT 3
                    //float lastTemp;
                    //float lastHum;
                    //uint8_t nNoUpdatesTemp;
                    //uint8_t nNoUpdatesHum;
                    //boolean metric = true;
                    //  present(CHILD_ID_HUM, S_HUM);
                      //metric = getControllerConfig().isMetric;
                         present(i, S_TEMP);
                    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)  60000
                    static int oldBatteryPcnt = 0;
                      MyMessage msg(0,V_TEMP);
                    //MyMessage msgHum(CHILD_ID_HUM, V_HUM);
                    MyMessage msgBattery(CHILD_ID_BATTERY, V_VOLTAGE);
                    //MyMessage msgBattery(CHILD_ID_BATTERY, V_PRC);
                      sensors.begin();
                        analogReference(INTERNAL1V1);
                        analogReference(INTERNAL);
                      sleep(conversionTime);
                        #if COMPARE_TEMP == 1
                    // some delay here
                       delay(500);
                       // get the battery Voltage
                        delay(500);
                    #ifdef MY_DEBUG
                        Serial.println(sensorValue);
                    #ifdef MY_DEBUG
                        Serial.print("Child ID ");
                        Serial.print(CHILD_ID_BATTERY);
                        Serial.print(batteryV);
                        Serial.println(" V");
                        Serial.print("Battery Percent: ");
                        Serial.print(batteryPcnt);
                        Serial.println(" %");
                            // Power up radio after sleep
                            oldBatteryPcnt = batteryPcnt;
                    [/code]```
                    | |/| | | | _
                    \ / _ \ _ \/ __|/ _ \|
                    _/ __|
                    | || | / | | _ \ _ | | \�
                    |_
                    , |/ ___|| ||/_/|| |/
                    __/ 2.2.0
                    26 TSM:INIT
                    28 TSF:WUR:MS=0
                    34 TSM:INIT:TSP OK
                    36 TSM:INIT:STATID=4
                    38 TSF:SID:OK,ID=4
                    40 TSM:FPAR
                    43 TSM:FPAR:STATP=0
                    45 TSM:ID
                    47 TSM:ID:OK
                    47 TSM:UPL
                    53 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    67 TSF:MSG:READ,0-0-4,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    71 TSF:MSG:PONG RECV,HP=1
                    75 TSM:UPL:OK
                    77 TSM:READY:ID=4,PAR=0,DIS=1
                    116 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                    2125 TSF:MSG:SEND,4-4-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=OK:2.2.0
                    2138 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    4177 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
                    4196 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                    4214 TSF:MSG:SEND,4-4-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                    4227 TSF:MSG:SEND,4-4-0-0,s=1,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                    4235 MCO:REG:REQ
                    4237 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    6246 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    8255 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    10264 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    12273 MCO:BGN:STP
                    12275 MCO:BGN:INIT OK,TSP=1
                    12279 MCO:SLP:MS=94,SMS=0,I1=255,M1=255,I2=255,M2=255
                    12285 TSF:TDI:TSL
                    12288 MCO:SLP:WUP=-1
                    12290 TSF:TRI:TSB
                    915
                    Child ID 1Battery Voltage: 3.08 V
                    Battery Percent: 91 %
                    13297 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:91
                    13305 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                    13312 TSF:TDI:TSL
                    13314 MCO:SLP:WUP=-1
                    13316 TSF:TRI:TSB
                    13320 MCO:SLP:MS=94,SMS=0,I1=255,M1=255,I2=255,M2=255
                    13326 TSF:TDI:TSL
                    13328 MCO:SLP:WUP=-1
                    13330 TSF:TRI:TSB
                    826
                    Child ID 1Battery Voltage: 2.78 V
                    Battery Percent: 82 %
                    14340 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:82
                    14346 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                    14352 TSF:TDI:TSL
                    • M Mr_sensor
                      this is my sketch:
                      [code]
                       -VCC = 3.3V
                       -GND = GND
                      //#define MY_RS485
                      //#include <Wire.h>
                      int numSensors=0;
                      bool metric = true;
                      //float lastTemp;
                      //float lastHum;
                           present(i, S_TEMP);
                        sensors.begin();
                      // some delay here
                         delay(500);
                          delay(500);
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      [/code]```
                      | |/| | | | _
                      _/ __|
                      | || | / | | _ \ _ | | \�
                      |_
                      __/ 2.2.0
                      26 TSM:INIT
                      28 TSF:WUR:MS=0
                      34 TSM:INIT:TSP OK
                      38 TSF:SID:OK,ID=4
                      40 TSM:FPAR
                      43 TSM:FPAR:STATP=0
                      45 TSM:ID
                      47 TSM:ID:OK
                      47 TSM:UPL
                      75 TSM:UPL:OK
                      4235 MCO:REG:REQ
                      12273 MCO:BGN:STP
                      12285 TSF:TDI:TSL
                      12290 TSF:TRI:TSB
                      915
                      13312 TSF:TDI:TSL
                      13316 TSF:TRI:TSB
                      13326 TSF:TDI:TSL
                      13330 TSF:TRI:TSB
                      826
                      14352 TSF:TDI:TSL
                      sundberg84S
                      sundberg84S
                      @mr_sensor - it looks ok except the temp sensor. Hard to say but doulecheck your wiring!
                        Mr_sensor
                        • M Mr_sensor
                          sundberg84S
                          sundberg84S
                          @mr_sensor looks right. Upload a sketch without MySensors from the temp library
                            Mr_sensor
                            @sundberg84 I run the "single" sketch from temp library and this is what I get:
                            Dallas Temperature IC Control Library Demo
                            Locating devices...Found 0 devices.
                            Parasite power is: OFF
                            Unable to find address for Device 0
                            Device 0 Address: 0000000000000000
                            Device 0 Resolution: 0
                            Temp C: -127.00 Temp F: -196.60
                            dbemowskD sundberg84S 3 Replies Last reply
                            • M Mr_sensor
                              dbemowskD
                              dbemowskD
                              @mr_sensor Lets see your code
                              • M Mr_sensor
                                sundberg84S
                                sundberg84S
                                #546
                                @mr_sensor ok, so either it's not wired correctly (but it looks good), or it's a sensor failure or it's a failure between the sensor and the Arduino.
                                You can try to measure continuity from sensor to VCC / Gnd and D3 on the atmega.
                                • M Mr_sensor
                                  dbemowskD
                                  dbemowskD
                                  @mr_sensor And show a pic of the bottom of the board with the sensor.
                                  • dbemowskD dbemowsk
                                    Mr_sensor
                                    @dbemowsk said in 💬 Easy/Newbie PCB for MySensors:
                                    • M Mr_sensor
                                      sundberg84S
                                      sundberg84S
                                        In general I'd say that more soldering practice is needed 😅
                                          Mr_sensor
                                          @gohan Not a solder problem I think. This is no short on the board it is just the angel of the picture hiding the gap underneath. :)
                                          tried the same set-up with an other dallas sensor. still the same result.
                                          sundberg84S Nca78N 2 Replies Last reply
