716 Posts 111 Posters 703.1k Views 93 Watching
  • AnticimexA Anticimex
    @sundberg84 I will just go ahead and update the spec. Yes, it may cause some existing designs to violate the spec, but that will always be the case. We look forwards, not backwards :)
    Spec is here.
    sundberg84S
    sundberg84S
    #523
    Back to the drawing desk! :)
    Edit: MysX alignment changed so PCB needs to be redesigned.
    • Nca78N
      wrote on last edited by Nca78
      #524
      I have moved the discussion about the alignment here :
      https://forum.mysensors.org/topic/9060/mysx-connector-alignment
      • sundberg84S
        sundberg84S
        Thoughs? (Noth Nrf + RFM)
        @Nca78 - MysX alignment?
        AnticimexA 1 Reply Last reply
        • sundberg84S sundberg84
          AnticimexA
          AnticimexA
          Anticimex
          @sundberg84 be careful about daughterboards colliding with the pro mini.
            sundberg84S
            sundberg84S
            @anticimex - thanks for input. Same with radio I guess... ? Don't know how to solve it by fitting all these things into one board.
              AnticimexA
              AnticimexA
              Anticimex
              @sundberg84 The rfm69 radio can be surface mounted. If one goes for headers, the pitch it uses allow for low profile headers so the radio should go clear under a daughterboard assuming it does not have reverse side mounted components with a high profile.
                sundberg84S
                sundberg84S
                #529
                @anticimex you could use male headers on mother and female headers on daughter...
                Or just mount the mother on top.
                here it seems the capacitor is the biggest concern.
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @sundberg84 if I remember correctly, the motherboard has to use male MYSX. So there is no option for that. I thought you planned to use sockets for the arduino. But if it is soldered directly on the pcb, it should go clear I think. But best to use angled ftdi interface then.
                  • Nca78N
                    Yes I guess the only viable solution with MYSX and a pro mini is to solder the promini without headers so it can be under the daughter board and big (electrolytic capacitor) or sensible (radio antenna) stuff can be as far away as possible.
                    @sundberg84, I'm not sure it's great to have antenna in that position for my "vertical" concept but I guess it's not a great idea any more to do that. Now that pin 1 is in a corner I have all the space in the world to put reed/hall switch next to the other side (on top of pro mini) and it will be much more in line with expected use of MYSX connector.
                    Antenna is on the side that's not supposed to be below daughter board so I don't think you can do better for that., I think it's much better than before, I'll be able to make a board that's more versatile than the current one with footprints for most common sensors.
                      #532
                      @sundberg84
                      not sure but on your preview, I see that you don't use any gnd planes?? Imho, just sayin for your users :), it would be better to have it, ideally unbroken+ vias, for impedance, emi, rf counterpoise, impedance matching rf feedline to sma depending on its length and how it's routed etc.., maybe a little google it ;)
                      looks nice :+1:
                      • scalzS scalz
                        @sundberg84
                        looks nice :+1:
                        sundberg84S
                        sundberg84S
                        @scalz - yes it is true about ground plane! I did that one rev 4 or something but something broke the thing... so I have been hesitating since but I know all about the benefits - been reading and googling.
                        I have not made any traces or planes on the images - just component placement. I will give it another shot... maybe I have learned some since rev 4 ;)
                        Thanks for your feedback.
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @sundberg84 I forgot to mention that your nRF24 module goes very close to the MYSX. There is a risk a female receptacle might collide with the rf module if you are unlucky. And daughterboards will most likely be at least as wide as the courtyard of the MYSX.
                            #535
                            @sundberg84
                            yes not talking about your latest but saw that on your rev9 and 10 pics.
                            it will make it better, and it's good point for rf quality (range and msg fail) ;)
                            placing planes is one of the first thing I usually do after component placements.. then it's easier to route as it solves many connection.
                            keep the good work!
                              Mr_sensor
                              @sundberg84 I have a "newby" question about how to use the Extra's part of the board. If I want to connect a DS18B20 sensor per example can I just solder it on the extra area and connect is with some wires to the pinout I need?
                              Asking this because I did this with the i2c sensor on the board discussed here. having a wire form the extras towards the arduino i2c pins directly. Later I discovered that the i2c pins are also on the board.
                              So how to deal with this?
                                you can add a wire to the I2C pins, in your case you just need a short wire to a digital pin that are just next to the Extra area
                                  Mr_sensor
                                  @gohan said in 💬 Easy/Newbie PCB for MySensors:
                                  Ok. And if attaching a DS18B20 I have a pull up resistor soldered on the board. Than it is also just the digital pin I need from the board? D3 I think?
                                  • M Mr_sensor
                                    sundberg84S
                                    sundberg84S
                                    #539
                                    @mr_sensor with a DS18B20 temp sensor I just solder it to the MysX pins (D3, Gnd and VCC) directly and populate the resistor for D3.
                                      Mr_sensor
                                      wrote on last edited by Mr_sensor
                                      #540
                                      @sundberg84 Yes thanks I did so. But do not get any temp read out? Have al in space also the 4,7 k resistor.
                                      this is my sketch:
                                      [code]
                                       * Version 1.0: Henrik EKblad
                                       * Dallas temperature sensor DS18B20
                                       HTU21D Humidity Sensor
                                       Hardware Connections (Breakoutboard to Arduino):
                                       -VCC = 3.3V
                                       -GND = GND
                                       -data  = D3 met pcb 470 uf resistor
                                      #define MY_NODE_ID 4
                                      #define MY_PARENT_NODE_ID 0
                                      // Enable debug prints
                                      //#define MY_RS485
                                      #include <OneWire.h>
                                      //#include <Wire.h>
                                      //static const uint8_t FORCE_UPDATE_N_READS = 10;
                                      //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
                                      int numSensors=0;
                                      bool receivedConfig = false;
                                      bool metric = true;
                                      #define CHILD_ID_TEMP 0
                                      #define CHILD_ID_BATTERY 1
                                      #define CHILD_ID_VOLT 2
                                      //#define CHILD_ID_PRCNT 3
                                      //float lastTemp;
                                      //float lastHum;
                                      //uint8_t nNoUpdatesTemp;
                                      //uint8_t nNoUpdatesHum;
                                      //boolean metric = true;
                                      //  present(CHILD_ID_HUM, S_HUM);
                                        //metric = getControllerConfig().isMetric;
                                           present(i, S_TEMP);
                                      unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)  60000
                                      static int oldBatteryPcnt = 0;
                                        MyMessage msg(0,V_TEMP);
                                      //MyMessage msgHum(CHILD_ID_HUM, V_HUM);
                                      MyMessage msgBattery(CHILD_ID_BATTERY, V_VOLTAGE);
                                      //MyMessage msgBattery(CHILD_ID_BATTERY, V_PRC);
                                        sensors.begin();
                                          analogReference(INTERNAL1V1);
                                          analogReference(INTERNAL);
                                        sleep(conversionTime);
                                          #if COMPARE_TEMP == 1
                                      // some delay here
                                         delay(500);
                                         // get the battery Voltage
                                          delay(500);
                                      #ifdef MY_DEBUG
                                          Serial.println(sensorValue);
                                      #ifdef MY_DEBUG
                                          Serial.print("Child ID ");
                                          Serial.print(CHILD_ID_BATTERY);
                                          Serial.print(batteryV);
                                          Serial.println(" V");
                                          Serial.print("Battery Percent: ");
                                          Serial.print(batteryPcnt);
                                          Serial.println(" %");
                                              // Power up radio after sleep
                                              oldBatteryPcnt = batteryPcnt;
                                      [/code]```
                                      | |/| | | | _
                                      \ / _ \ _ \/ __|/ _ \|
                                      _/ __|
                                      | || | / | | _ \ _ | | \�
                                      |_
                                      , |/ ___|| ||/_/|| |/
                                      __/ 2.2.0
                                      26 TSM:INIT
                                      28 TSF:WUR:MS=0
                                      34 TSM:INIT:TSP OK
                                      36 TSM:INIT:STATID=4
                                      38 TSF:SID:OK,ID=4
                                      40 TSM:FPAR
                                      43 TSM:FPAR:STATP=0
                                      45 TSM:ID
                                      47 TSM:ID:OK
                                      47 TSM:UPL
                                      53 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      67 TSF:MSG:READ,0-0-4,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      71 TSF:MSG:PONG RECV,HP=1
                                      75 TSM:UPL:OK
                                      77 TSM:READY:ID=4,PAR=0,DIS=1
                                      116 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                                      2125 TSF:MSG:SEND,4-4-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=OK:2.2.0
                                      2138 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      4177 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
                                      4196 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                                      4214 TSF:MSG:SEND,4-4-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                                      4227 TSF:MSG:SEND,4-4-0-0,s=1,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                                      4235 MCO:REG:REQ
                                      4237 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                      6246 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                      8255 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                      10264 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                      12273 MCO:BGN:STP
                                      12275 MCO:BGN:INIT OK,TSP=1
                                      12279 MCO:SLP:MS=94,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      12285 TSF:TDI:TSL
                                      12288 MCO:SLP:WUP=-1
                                      12290 TSF:TRI:TSB
                                      915
                                      Child ID 1Battery Voltage: 3.08 V
                                      Battery Percent: 91 %
                                      13297 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:91
                                      13305 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      13312 TSF:TDI:TSL
                                      13314 MCO:SLP:WUP=-1
                                      13316 TSF:TRI:TSB
                                      13320 MCO:SLP:MS=94,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      13326 TSF:TDI:TSL
                                      13328 MCO:SLP:WUP=-1
                                      13330 TSF:TRI:TSB
                                      826
                                      Child ID 1Battery Voltage: 2.78 V
                                      Battery Percent: 82 %
                                      14340 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:82
                                      14346 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      14352 TSF:TDI:TSL
                                      • M Mr_sensor
                                        this is my sketch:
                                        [code]
                                         -VCC = 3.3V
                                         -GND = GND
                                        //#define MY_RS485
                                        //#include <Wire.h>
                                        int numSensors=0;
                                        bool metric = true;
                                        //float lastTemp;
                                        //float lastHum;
                                             present(i, S_TEMP);
                                          sensors.begin();
                                        // some delay here
                                           delay(500);
                                            delay(500);
                                        #ifdef MY_DEBUG
                                        #ifdef MY_DEBUG
                                        [/code]```
                                        | |/| | | | _
                                        _/ __|
                                        | || | / | | _ \ _ | | \�
                                        |_
                                        __/ 2.2.0
                                        26 TSM:INIT
                                        28 TSF:WUR:MS=0
                                        34 TSM:INIT:TSP OK
                                        38 TSF:SID:OK,ID=4
                                        40 TSM:FPAR
                                        43 TSM:FPAR:STATP=0
                                        45 TSM:ID
                                        47 TSM:ID:OK
                                        47 TSM:UPL
                                        75 TSM:UPL:OK
                                        4235 MCO:REG:REQ
                                        12273 MCO:BGN:STP
                                        12285 TSF:TDI:TSL
                                        12290 TSF:TRI:TSB
                                        915
                                        13312 TSF:TDI:TSL
                                        13316 TSF:TRI:TSB
                                        13326 TSF:TDI:TSL
                                        13330 TSF:TRI:TSB
                                        826
                                        14352 TSF:TDI:TSL
                                        sundberg84S
                                        sundberg84S
                                        @mr_sensor - it looks ok except the temp sensor. Hard to say but doulecheck your wiring!
                                          Mr_sensor
