  2. Announcements
  • Sergio RiusS
    Sergio RiusS
    Sergio Rius
    Regarding the communication issues described in the instructions page with the 2.2 stable version, is that still valid and still recommended to use the development branch?
        Sergio RiusS
        Sergio RiusS
        Sergio Rius
        @gohan Thank you verys muchos. :+1:
        • S Syna
          Hello, I configure the raspberry gateway to use MQTT. I set mosquitto as the broker. The problem that I encounter is that when I subscribe to test if the gateway publish on the broker, I have empty message. So my first guess is that there is an issue somewhere which cause that only empty message are sent.
          marceloaqno
          Code Contributor
          wrote on last edited by marceloaqno
          #797
          #define MY_NODE_ID X
            sineverba
            Hi to all,
            1 - Disable the daemon with
            sudo rm -r MySensors
            4 - Git the "new" MySensors folder && configure it as usual. Remember to activate the daemon and see on Domoticz (for example) the gateway with new version :)
            • O
              O
              otto001
              # -*- coding: utf-8 -*-
              LOOKFOR = u"mysgw"
                  if proc.name() == "mysgw":
                      #print(proc)
                      #print(cpu)
                      #print(proc.cpu_times())
                      if cpu > 50:
                      else:
              Cheers,
              Pula
              Nick WillisN 1 Reply Last reply
              • O otto001
                LOOKFOR = u"mysgw"
                        #print(proc)
                        #print(cpu)
                        if cpu > 50:
                        else:
                Cheers,
                Pula
                Nick WillisN
                Nick WillisN
                Nick Willis
                @otto001 Thanks for that! I'm also getting this annoying service failure on 2.2 on a RPi 2. It seems to happen at random at night when nothing much is going on in the house. It probably happens once every 1 to 2 weeks.
                • alowhumA
                  alowhumA
                  alowhum
                  • O
                    O
                    otto001
                    wrote on last edited by otto001
                    #802
                    @Nick-Willis:
                    from
                    to
                    sudo systemctl daemon-reload
                    followed by
                    to enable the change.
                    Cheers,
                    Otto
                    • O otto001
                      @Nick-Willis:
                      from
                      to
                      followed by
                      Cheers,
                      Otto
                      marceloaqno
                      Code Contributor
                      • O
                        O
                        otto001
                        #804
                        @marceloaqno : of course, thanks for the hint!
                        #ifndef MY_RF24_CHANNEL
                        #define MY_RF24_CHANNEL (82)
                        Maybe this helps.
                        Cheers,
                        Otto
                        • O otto001
                          Maybe this helps.
                          Cheers,
                          Otto
                          marceloaqno
                          Code Contributor
                          @otto001 I think I found the problem. I wrote a fix for it:
                          https://github.com/marceloaqno/MySensors/commit/ca8865d8e1fe1b08195943fae1640d5fddb81924
                          • O
                            O
                            otto001
                            #806
                            @marceloaqno : Wow, you are fast! Thanks!
                            Cheers,
                            Otto
                            • M marceloaqno
                              mvader
                              @marceloaqno I am also recompiling and testing.
                              thanks for the (hopeful) fix
                              • O
                                O
                                otto001
                                #808
                                @marceloaqno :
                                and so on....
                                Thanks again and cheers,
                                Otto
                                • O otto001
                                  @marceloaqno :
                                  and so on....
                                  Otto
                                  marceloaqno
                                  Code Contributor
                                  • M marceloaqno
                                    mvader
                                    wrote on last edited by mvader
                                    #810
                                    @marceloaqno said in 💬 Building a Raspberry Pi Gateway:
                                    My uptime is at 4 days now. so far still working with your patch. CPU is at 2% and sensor network still working correctly. will report if that changes.
                                    • Nick WillisN
                                      Nick WillisN
                                      Nick Willis
                                      I've been using your restarting method and its been working ok and has done one restart in 5 days.
                                      However I now see something else where altho cpu use is fine, none of my nodes can communicate to the gateway. My controller can connect to the gateway no problem but there are no messages received. Restarting nodes does not help. Only a manual restart of the gateway gets things going again - at least for a while anyway.
                                      Where is the log output from the gateway to be found? I know it can be run from the bash prompt to write the output to screen but how about logging the installed service output?
                                      • Nick WillisN Nick Willis
                                        #812
                                        @nick-willis the log is sent to syslog by default. See https://www.mysensors.org/build/raspberry#troubleshooting for details.
                                        • O
                                          O
                                          otto001
                                          #813
                                          @marceloaqno : This is strange. I am using a RPi 1 on this gateway with raspbian Jessie. Beside the GW-service there is only a small python programm which listens on an UPD-Port and plays an mp3 if it receives suitable data (for doorbell). Since March 4, 20:15 there were several restarts due to high cpu usage (after dis-applying your patch):
                                          2018-03-04 23:01:03 cpu (99.7) very high! --> restarting service
                                          2018-03-05 07:31:03 cpu (99.7) very high! --> restarting service
                                          2018-03-05 11:01:03 cpu (98.7) very high! --> restarting service
                                          2018-03-05 13:31:04 cpu (94.7) very high! --> restarting service
                                          2018-03-06 11:31:03 cpu (99.7) very high! --> restarting service
                                          2018-03-06 12:31:03 cpu (98.7) very high! --> restarting service
                                          2018-03-07 06:01:03 cpu (94.8) very high! --> restarting service
                                          2018-03-07 22:31:03 cpu (99.8) very high! --> restarting service
                                          With this "auto-restarts" the sensors are working fine, I did not notice any problems.
                                          However, I just upgraded to the recent Stretch (what takes a LONG time on RPi 1 and made me struggle a little bit with the new network names). I also rebuilt the GW of course and will report here what will happen....
                                          @Nick-Willis : did you apply the patch of marceloaqno or not? Did you enable debugging? (see here )
                                          Cheers,
                                          Otto
