  2. Announcements
  • wesW
    wesW
    wes
    To upgrade to the latest release, can I use git pull, or is it better to delete the directory and start again?
    Blog: https://www.wes.id.au/
    Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
    Gateway & Controller: Raspberry Pi 3 + Home Assistant
    AnticimexA 1 Reply Last reply
    • wesW wes
      AnticimexA
      AnticimexA
      Anticimex
      @wes you can pull. Just as long as you verify that your working directory is clean or only contains changes you intend to have. And you have the appropriate branch or tag checked out.
      S 1 Reply Last reply
      • M macvictor
        @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
        Gateway:
        2. make
        3. sudo make install
        10. sudo mysgw --gen-aes-key
        Node:
        #define USE_SOFT_SIGNING
        #define STORE_SOFT_KEY
        #define USER_SOFT_KEY
        #define STORE_SOFT_SERIAL
        #define STORE_AES_KEY
        #define USER_AES_KEY
        EEPROM configuration:
        // Enable NRF24L01 radio type
        // Select soft signing
        #define MY_SIGNING_SOFT
        // Enable node whitelisting
        #define MY_REPEATER_FEATURE
        #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
        #define CHILD_ID 1      // Id of the sensor child
        #define RELAY_ON 1
        #define RELAY_OFF 0
        Bounce debouncer = Bounce();
        int oldValue = 0;
        bool state;
          // Setup the button
          pinMode(BUTTON_PIN, INPUT);
          // Activate internal pull-up
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
          pinMode(RELAY_PIN, OUTPUT);
          state = loadState(CHILD_ID);
          digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
        void presentation()  {
          debouncer.update();
          // Get the update value
          int value = debouncer.read();
        //  oldValue = value;
          delay(5000);
          if (message.isAck()) {
            // Change relay state
            state = message.getBool();
            // Store state in eeprom
        4 TSM:INIT
        5 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        13 TSF:SID:OK,ID=105
        15 TSM:FPAR
        2065 !TSM:FPAR:NO REPLY
        2067 TSM:FPAR
        4117 !TSM:FPAR:NO REPLY
        4119 TSM:FPAR
        6169 !TSM:FPAR:NO REPLY
        6171 TSM:FPAR
        8221 !TSM:FPAR:FAIL
        8222 TSM:FAIL:CNT=1
        8224 TSM:FAIL:PDT
        and in gateway i see:
        sudo mysgw -d
        mysgw: Starting gateway...
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:INIT:TSP OK
        mysgw: TSM:INIT:GW MODE
        mysgw: MCO:REG:NOT NEEDED
        mysgw: MCO:BGN:STP
        mysgw: MCO:BGN:INIT OK,TSP=1
        mysgw: connected to 127.0.0.1
        mysgw: MQTT connected
        mysgw: !TSF:MSG:PVER,3=2
        mysgw: !TSF:MSG:PVER,1=2
        mysgw: TSF:MSG:REL MSG
        mysgw: !TSF:RTE:240 UNKNOWN
        mysgw: !TSF:MSG:PVER,0=2
        mysgw: !TSF:RTE:233 UNKNOWN
        mysgw: !TSF:RTE:51 UNKNOWN
        Where is problem?
        pepsonP
        pepsonP
        pepson
        @macvictor
        Hi
        Is any chance to add security & signing for radio RFM69HW ? Please help me how ?
        • pepsonP pepson
          @macvictor
          Hi
          AnticimexA
          AnticimexA
          Anticimex
          @pepson signing is radio agnostic. It has nothing to do with the radio.
          • AnticimexA Anticimex
            sineverba
            @anticimex @wes Can I please ask how to update? I mean, the right command to type.
            I have the folder "MySensors" on documents of my user in Pi:
            /home/sineverba/MySensors
            Of course I have all installed and perfectly working now (I'm on the 2.2.0 rc2).
            I need also to relaunch the ./config command?
            Thank you to both and all!
            • S sineverba
              AnticimexA
              AnticimexA
              Anticimex
              @sineverba https://www.mysensors.org/download
                Syna
                Hello, I configure the raspberry gateway to use MQTT. I set mosquitto as the broker. The problem that I encounter is that when I subscribe to test if the gateway publish on the broker, I have empty message. So my first guess is that there is an issue somewhere which cause that only empty message are sent.
                • Sergio RiusS
                  Sergio RiusS
                  Sergio Rius
                  Regarding the communication issues described in the instructions page with the 2.2 stable version, is that still valid and still recommended to use the development branch?
                      Sergio RiusS
                      Sergio RiusS
                      Sergio Rius
                      @gohan Thank you verys muchos. :+1:
                      • S Syna
                        marceloaqno
                        Code Contributor
                        wrote on last edited by marceloaqno
                        #797
                        #define MY_NODE_ID X
                          sineverba
                          Hi to all,
                          1 - Disable the daemon with
                          sudo rm -r MySensors
                          4 - Git the "new" MySensors folder && configure it as usual. Remember to activate the daemon and see on Domoticz (for example) the gateway with new version :)
                          • O
                            O
                            otto001
                            # -*- coding: utf-8 -*-
                            LOOKFOR = u"mysgw"
                                if proc.name() == "mysgw":
                                    #print(proc)
                                    #print(cpu)
                                    #print(proc.cpu_times())
                                    if cpu > 50:
                                    else:
                            Cheers,
                            Pula
                            Nick WillisN 1 Reply Last reply
                            • O otto001
                              LOOKFOR = u"mysgw"
                                      #print(proc)
                                      #print(cpu)
                                      if cpu > 50:
                                      else:
                              Cheers,
                              Pula
                              Nick WillisN
                              Nick WillisN
                              Nick Willis
                              @otto001 Thanks for that! I'm also getting this annoying service failure on 2.2 on a RPi 2. It seems to happen at random at night when nothing much is going on in the house. It probably happens once every 1 to 2 weeks.
                              • alowhumA
                                alowhumA
                                alowhum
                                • O
                                  O
                                  otto001
                                  wrote on last edited by otto001
                                  #802
                                  @Nick-Willis:
                                  from
                                  to
                                  sudo systemctl daemon-reload
                                  followed by
                                  to enable the change.
                                  Cheers,
                                  Otto
                                  • O otto001
                                    @Nick-Willis:
                                    from
                                    to
                                    followed by
                                    Cheers,
                                    Otto
                                    marceloaqno
                                    Code Contributor
                                    • O
                                      O
                                      otto001
                                      #804
                                      @marceloaqno : of course, thanks for the hint!
                                      #ifndef MY_RF24_CHANNEL
                                      #define MY_RF24_CHANNEL (82)
                                      Maybe this helps.
                                      Cheers,
                                      Otto
                                      • O otto001
                                        Maybe this helps.
                                        Cheers,
                                        Otto
                                        marceloaqno
                                        Code Contributor
                                        @otto001 I think I found the problem. I wrote a fix for it:
                                        https://github.com/marceloaqno/MySensors/commit/ca8865d8e1fe1b08195943fae1640d5fddb81924
                                        • O
                                          O
                                          otto001
                                          #806
                                          @marceloaqno : Wow, you are fast! Thanks!
                                          Cheers,
                                          Otto
