  2. Announcements
  • AnticimexA Anticimex
    @wes you can pull. Just as long as you verify that your working directory is clean or only contains changes you intend to have. And you have the appropriate branch or tag checked out.
    sineverba
    @anticimex @wes Can I please ask how to update? I mean, the right command to type.
    I have the folder "MySensors" on documents of my user in Pi:
    /home/sineverba/MySensors
    Of course I have all installed and perfectly working now (I'm on the 2.2.0 rc2).
    I need also to relaunch the ./config command?
    Thank you to both and all!
    AnticimexA 1 Reply Last reply
    • S sineverba
      AnticimexA
      AnticimexA
      Anticimex
      @sineverba https://www.mysensors.org/download
        Syna
        Hello, I configure the raspberry gateway to use MQTT. I set mosquitto as the broker. The problem that I encounter is that when I subscribe to test if the gateway publish on the broker, I have empty message. So my first guess is that there is an issue somewhere which cause that only empty message are sent.
        • Sergio RiusS
          Sergio RiusS
          Sergio Rius
          Regarding the communication issues described in the instructions page with the 2.2 stable version, is that still valid and still recommended to use the development branch?
              Sergio RiusS
              Sergio RiusS
              Sergio Rius
              @gohan Thank you verys muchos. :+1:
              • S Syna
                marceloaqno
                Code Contributor
                wrote on last edited by marceloaqno
                #797
                #define MY_NODE_ID X
                  sineverba
                  Hi to all,
                  1 - Disable the daemon with
                  sudo rm -r MySensors
                  4 - Git the "new" MySensors folder && configure it as usual. Remember to activate the daemon and see on Domoticz (for example) the gateway with new version :)
                  • O
                    O
                    otto001
                    # -*- coding: utf-8 -*-
                    LOOKFOR = u"mysgw"
                        if proc.name() == "mysgw":
                            #print(proc)
                            #print(cpu)
                            #print(proc.cpu_times())
                            if cpu > 50:
                            else:
                    Cheers,
                    Pula
                    Nick WillisN 1 Reply Last reply
                    • O otto001
                      LOOKFOR = u"mysgw"
                              #print(proc)
                              #print(cpu)
                              if cpu > 50:
                              else:
                      Cheers,
                      Pula
                      Nick WillisN
                      Nick WillisN
                      Nick Willis
                      @otto001 Thanks for that! I'm also getting this annoying service failure on 2.2 on a RPi 2. It seems to happen at random at night when nothing much is going on in the house. It probably happens once every 1 to 2 weeks.
                      • alowhumA
                        alowhumA
                        alowhum
                        • O
                          O
                          otto001
                          wrote on last edited by otto001
                          #802
                          @Nick-Willis:
                          from
                          to
                          sudo systemctl daemon-reload
                          followed by
                          to enable the change.
                          Cheers,
                          Otto
                          • O otto001
                            @Nick-Willis:
                            from
                            to
                            followed by
                            Cheers,
                            Otto
                            marceloaqno
                            Code Contributor
                            • O
                              O
                              otto001
                              #804
                              @marceloaqno : of course, thanks for the hint!
                              #ifndef MY_RF24_CHANNEL
                              #define MY_RF24_CHANNEL (82)
                              Maybe this helps.
                              Cheers,
                              Otto
                              • O otto001
                                Maybe this helps.
                                Cheers,
                                Otto
                                marceloaqno
                                Code Contributor
                                @otto001 I think I found the problem. I wrote a fix for it:
                                https://github.com/marceloaqno/MySensors/commit/ca8865d8e1fe1b08195943fae1640d5fddb81924
                                • O
                                  O
                                  otto001
                                  #806
                                  @marceloaqno : Wow, you are fast! Thanks!
                                  Cheers,
                                  Otto
                                  • M marceloaqno
                                    mvader
                                    @marceloaqno I am also recompiling and testing.
                                    thanks for the (hopeful) fix
                                    • O
                                      O
                                      otto001
                                      #808
                                      @marceloaqno :
                                      and so on....
                                      Thanks again and cheers,
                                      Otto
                                      • O otto001
                                        @marceloaqno :
                                        and so on....
                                        Otto
                                        marceloaqno
                                        Code Contributor
                                        • M marceloaqno
                                          mvader
                                          wrote on last edited by mvader
                                          #810
                                          @marceloaqno said in 💬 Building a Raspberry Pi Gateway:
                                          My uptime is at 4 days now. so far still working with your patch. CPU is at 2% and sensor network still working correctly. will report if that changes.
