  2. Announcements
  • M macvictor
    @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
    Gateway:
    2. make
    3. sudo make install
    10. sudo mysgw --gen-aes-key
    Node:
    #define USE_SOFT_SIGNING
    #define STORE_SOFT_KEY
    #define USER_SOFT_KEY
    #define STORE_SOFT_SERIAL
    #define STORE_AES_KEY
    #define USER_AES_KEY
    EEPROM configuration:
    // Enable NRF24L01 radio type
    // Select soft signing
    #define MY_SIGNING_SOFT
    // Enable node whitelisting
    #define MY_REPEATER_FEATURE
    #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
    #define CHILD_ID 1      // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool state;
      // Setup the button
      pinMode(BUTTON_PIN, INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      pinMode(RELAY_PIN, OUTPUT);
      state = loadState(CHILD_ID);
      digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
    void presentation()  {
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
    //  oldValue = value;
      delay(5000);
      if (message.isAck()) {
        // Change relay state
        state = message.getBool();
        // Store state in eeprom
    4 TSM:INIT
    5 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSF:SID:OK,ID=105
    15 TSM:FPAR
    2065 !TSM:FPAR:NO REPLY
    2067 TSM:FPAR
    4117 !TSM:FPAR:NO REPLY
    4119 TSM:FPAR
    6169 !TSM:FPAR:NO REPLY
    6171 TSM:FPAR
    8221 !TSM:FPAR:FAIL
    8222 TSM:FAIL:CNT=1
    8224 TSM:FAIL:PDT
    and in gateway i see:
    sudo mysgw -d
    mysgw: Starting gateway...
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: connected to 127.0.0.1
    mysgw: MQTT connected
    mysgw: !TSF:MSG:PVER,3=2
    mysgw: !TSF:MSG:PVER,1=2
    mysgw: TSF:MSG:REL MSG
    mysgw: !TSF:RTE:240 UNKNOWN
    mysgw: !TSF:MSG:PVER,0=2
    mysgw: !TSF:RTE:233 UNKNOWN
    mysgw: !TSF:RTE:51 UNKNOWN
    Where is problem?
    rajeev2301R
    rajeev2301R
    rajeev2301
    @macvictor
    I followed all the step that you mentioned in your post to establish the serial gateway. However I am still not able to receive the message from arduino. Could you please what to do?
    import RPi.GPIO as GPIO
    from lib_nrf24 import NRF24
    import time
    import spidev
    GPIO.setmode(GPIO.BCM)
    pipes = [[0xE8, 0xE8, 0xF0, 0xF0, 0xE1], [0xF0, 0xF0, 0xF0, 0xF0, 0xE1]]
    radio = NRF24(GPIO, spidev.SpiDev())
    radio.begin(0,8)
    radio.setPayloadSize(32)
    radio.setChannel(0x76)
    radio.setDataRate(NRF24.BR_1MBPS)
    radio.setPALevel (NRF24.PA_MAX)
    radio.setAutoAck(True)
    radio.enableDynamicPayloads()
    radio.enableAckPayload()
    radio.openReadingPipe(1 ,pipes[1])
    radio.printDetails()
    radio.startListening()
    radio.GPIO.cleanup()
    Please find below my raspberry code..can you please suggest , if there is any issue with code or am I missing anything ?
    • rajeev2301R rajeev2301
      @macvictor
      import time
      import spidev
      radio.begin(0,8)
      @rajeev2301 please don't split our effort to help you into multiple threads. It wastes people's time when some information is in one thread and some in another thread.
      • wesW
        wesW
        wes
        To upgrade to the latest release, can I use git pull, or is it better to delete the directory and start again?
        Blog: https://www.wes.id.au/
        Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
        Gateway & Controller: Raspberry Pi 3 + Home Assistant
        AnticimexA 1 Reply Last reply
        • wesW wes
          AnticimexA
          AnticimexA
          Anticimex
          @wes you can pull. Just as long as you verify that your working directory is clean or only contains changes you intend to have. And you have the appropriate branch or tag checked out.
          S 1 Reply Last reply
          • M macvictor
            Gateway:
            2. make
            Node:
            #define RELAY_ON 1
            #define RELAY_OFF 0
            int oldValue = 0;
            bool state;
              // Setup the button
              debouncer.update();
              delay(5000);
            4 TSM:INIT
            5 TSF:WUR:MS=0
            11 TSM:INIT:TSP OK
            15 TSM:FPAR
            2067 TSM:FPAR
            4119 TSM:FPAR
            6171 TSM:FPAR
            8221 !TSM:FPAR:FAIL
            8222 TSM:FAIL:CNT=1
            8224 TSM:FAIL:PDT
            sudo mysgw -d
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: MCO:BGN:STP
            Where is problem?
            pepsonP
            pepsonP
            pepson
            @macvictor
            Hi
            Is any chance to add security & signing for radio RFM69HW ? Please help me how ?
            • pepsonP pepson
              @macvictor
              Hi
              AnticimexA
              AnticimexA
              Anticimex
              @pepson signing is radio agnostic. It has nothing to do with the radio.
              • AnticimexA Anticimex
                sineverba
                @anticimex @wes Can I please ask how to update? I mean, the right command to type.
                I have the folder "MySensors" on documents of my user in Pi:
                /home/sineverba/MySensors
                Of course I have all installed and perfectly working now (I'm on the 2.2.0 rc2).
                I need also to relaunch the ./config command?
                Thank you to both and all!
                • S sineverba
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @sineverba https://www.mysensors.org/download
                    Syna
                    Hello, I configure the raspberry gateway to use MQTT. I set mosquitto as the broker. The problem that I encounter is that when I subscribe to test if the gateway publish on the broker, I have empty message. So my first guess is that there is an issue somewhere which cause that only empty message are sent.
                    • Sergio RiusS
                      Sergio RiusS
                      Sergio Rius
                      Regarding the communication issues described in the instructions page with the 2.2 stable version, is that still valid and still recommended to use the development branch?
                          Sergio RiusS
                          Sergio RiusS
                          Sergio Rius
                          @gohan Thank you verys muchos. :+1:
                          • S Syna
                            marceloaqno
                            Code Contributor
                            wrote on last edited by marceloaqno
                            #797
                            #define MY_NODE_ID X
                              sineverba
                              Hi to all,
                              1 - Disable the daemon with
                              sudo rm -r MySensors
                              4 - Git the "new" MySensors folder && configure it as usual. Remember to activate the daemon and see on Domoticz (for example) the gateway with new version :)
                              • O
                                O
                                otto001
                                # -*- coding: utf-8 -*-
                                LOOKFOR = u"mysgw"
                                    if proc.name() == "mysgw":
                                        #print(proc)
                                        #print(cpu)
                                        #print(proc.cpu_times())
                                        if cpu > 50:
                                        else:
                                Cheers,
                                Pula
                                Nick WillisN 1 Reply Last reply
                                • O otto001
                                  LOOKFOR = u"mysgw"
                                          #print(proc)
                                          #print(cpu)
                                          if cpu > 50:
                                          else:
                                  Cheers,
                                  Pula
                                  Nick WillisN
                                  Nick WillisN
                                  Nick Willis
                                  @otto001 Thanks for that! I'm also getting this annoying service failure on 2.2 on a RPi 2. It seems to happen at random at night when nothing much is going on in the house. It probably happens once every 1 to 2 weeks.
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    • O
                                      O
                                      otto001
                                      wrote on last edited by otto001
                                      #802
                                      @Nick-Willis:
                                      from
                                      to
                                      sudo systemctl daemon-reload
                                      followed by
                                      to enable the change.
                                      Cheers,
                                      Otto
                                      • O otto001
                                        @Nick-Willis:
                                        from
                                        to
                                        followed by
                                        Cheers,
                                        Otto
                                        marceloaqno
                                        Code Contributor
                                        • O
                                          O
                                          otto001
                                          #804
                                          @marceloaqno : of course, thanks for the hint!
                                          #ifndef MY_RF24_CHANNEL
                                          #define MY_RF24_CHANNEL (82)
                                          Maybe this helps.
                                          Cheers,
                                          Otto
