  2. Announcements
  • MasMatM
    MasMatM
    MasMat
    wrote on last edited by MasMat
    #829
    I need help with my Rpi mqtt-gw.
      Mosquitto-log:
    syslog:
    GW configure-line:
      MasMatM 1 Reply Last reply
        MasMatM
        MasMatM
        MasMat
        @gohan Can I just edit mysgw.cpp and do "daemon-reload"?
            MasMatM
            MasMatM
            MasMat
            #833
            @gohan OK. I did that, the same socket error remains in Mosquitto just under new id.
              • MasMatM MasMat
                marceloaqno
                Code Contributor
                • ? A Former User
                  Can someone tell me how to apply this patch?
                  marceloaqno
                  Code Contributor
                  You can download from:
                  Here is a step-by-step:
                  cd MySensors
                  • M marceloaqno
                    MasMatM
                    MasMatM
                    MasMat
                    @marceloaqno Mosquitto v1.4.14.
                      I'm using dietpi and I am not having big issues even running 2 gateway instances with 2 different radios
                      A Former User
                      @gohan
                      I will try this...
                        • O
                          O
                          otto001
                          wrote on last edited by otto001
                          #840
                          @marceloaqno :
                          Still the gw stops receiving, but without high cpu usage :-(
                          Fortunately I can restart the gw now using a button and this udp-scripts :-)
                          cheers,
                          Otto
                            MasMatM
                            MasMatM
                            MasMat
                            #841
                            @gohan I had another sd card and tried a ready image of DietPi with Mosquitto pre-installed.
                            ..keeps repeating...
                            ...and sudo ./bin/mysgw -d:
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: MCO:BGN:STP
                            gohanG 1 Reply Last reply
                              mvader
                              1st patch is still working good for me. have had no issues since applying it.
                              • MasMatM MasMat
                                mysgw: TSF:LRT:OK
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: MCO:BGN:STP
                                MasMatM M 2 Replies Last reply
                                  MasMatM
                                  MasMatM
                                  MasMat
                                  @gohan How would I interface the rest of my HA without MQTT...that's at the center of my plan really :(
                                      MasMatM
                                      MasMatM
                                      MasMat
                                      @gohan I configured:
                                      ./bin/mysgw -d:
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: failed to connect
                                      mysgw: GWT:TIN:ETH OK
                                      mysgw: GWT:TPS:ETH OK
                                        • MasMatM MasMat
                                          ./bin/mysgw -d:
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          marceloaqno
                                          Code Contributor
                                          wrote on last edited by marceloaqno
                                          #848
                                            No LSB modules are available.
                                            Distributor ID: Raspbian
                                            Release:        9.1
                                            Codename:       stretch
                                            persistence true
                                            allow_anonymous false
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: MCO:BGN:STP
