  3. atmega328p small (SMD) alternative with more memory?
37 Posts 8 Posters 7.1k Views 9 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    More and more, I come across that atmega328p loaded with mysensors, signing, encryption and a few sensors and libraries gives me this:
    Sketch uses 31924 bytes (103%) of program storage space. Maximum is 30720 bytes.
    Global variables use 2076 bytes (101%) of dynamic memory, leaving -28 bytes for local variables. Maximum is 2048 bytes.
    Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
    Error
    Whereas I do have Moteino Mega, which is an excellent form factor, but a but a bit too large when it comes to a small node. Anyone can recommend a tiny form factor node like Sensebender Micro but with considerably more memory please?
    AnticimexA NeverDieN 2 Replies Last reply
    • alexsh1A alexsh1
      Error
      AnticimexA
      AnticimexA
      Anticimex
      @alexsh1 at some point I belive a SAMD based SenseBender might arrive.
      alexsh1A 1 Reply Last reply
      • alexsh1A alexsh1
        Error
        @alexsh1 said in atmega328p small (SMD) alternative with more memory?:
        Well, the nRF52 series has more memory and is better in almost every way. And you can program it through the familiar Arduino IDE. Time to join the band wagon.
        AnticimexA 1 Reply Last reply
          AnticimexA
          AnticimexA
          Anticimex
          @neverdie are you sure they always come with a bootloader, and one that's compatible with Arduino? Afaik you need a debugger. Not that it's a problem, but it isn't exactly plug and play either.
          • AnticimexA Anticimex
            @anticimex said in atmega328p small (SMD) alternative with more memory?:
            You just need a programmer. I use JTAG, but many here have reported success with the super cheap STM v2.
              AnticimexA
              AnticimexA
              Anticimex
              @neverdie I know, but it is still a detail worth mentioning. It is not a drop in replacement unless you happen to sit on compatible debuggers or programmers already. And even then, I am unsure if the arduino IDE can be used to program a suitable bootloader in a user friendly way.
              That said, I agree that nrf52 is the future. Closely followed by SAMD.
                There doesn't exist a drop in replacement.
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @neverdie a SenseBender mk2 based on samd would be a drop in replacement for SenseBender.
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @anticimex it would be good, right Thomas @tbowmo? :)))
                    Given my experience, I'd rather go for SAMD - at least I do not have to start from zero.
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      Are there any similar size wise alternatives to SenseBender mk2 (SAMD), which are available right now?
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        @NeverDie Check out this one nRF52. Its not cheap though
                        https://www.tindie.com/products/onehorse/nrf52-add-on-for-butterfly-and-teensy/?pt=ac_prod_search
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          Alternatively, this is a good size for a node - https://www.sparkfun.com/products/13664
                          • alexsh1A alexsh1
                            Yes, I would agree that's interesting. He uses it as a BLE device, albeit purely as a UART channel, which so far isn't something that we've managed to do here with the nRF52. @GertSanders might want to take notice, as he has been doing something similar for logging purposes, but with a different bluetooth.
                              SenseBender mk2
                              If that's how you define drop-in replacement, I'll concede the point.
                              Actually, I suppose if you had a fast enough ARM, it could emulate an atmega328p (well, at least its software behavior), and thereby indirectly offer up additional memory. I actually own a board which, IIRC, does that, and it can run code even faster than the atmega328. Just don't expect low power performance out of it.
                                SenseBender mk2
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @neverdie I perhaps misread the thread title... I did not interpret the quest as something that should be binary identical to atmega328p.
                                NeverDieN alexsh1A 2 Replies Last reply
                                  @anticimex Yeah, the title was ambiguous. Looking back, your interpretation is probably closer than mine as to what he meant though.
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @anticimex you are absolutely correct. It does not have to be binary identical to atmega328p. However, size wise, it has to be small enough.
                                    For now atmega1284p is a direct replacement for atmega328p as code is almost identical. I do not need much more processing power just memory. However, I did struggle to find a very small footprint.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @alexsh1
                                      Hmm.. perhaps I should pick up on the SenseBender MK2 again.. I lost focus as I had a lot of other projects running at the same time..
                                      If I remember right, it had problems in it's bootup sequence when I left it alone last..
                                        In terms of BOM cost, it would be cheaper to add a second atmega328p (or even multiple) than to use a 1284. Maybe worth considering if memory of just one is insufficient.
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          You will then waste memory with "intercom" between the devices. As they have to speak together in some way..
