  3. atmega328p small (SMD) alternative with more memory?
37 Posts 8 Posters 7.1k Views 9 Watching
    There doesn't exist a drop in replacement.
    AnticimexA
    AnticimexA
    Anticimex
    @neverdie a SenseBender mk2 based on samd would be a drop in replacement for SenseBender.
    • AnticimexA Anticimex
      @alexsh1 at some point I belive a SAMD based SenseBender might arrive.
      alexsh1A
      alexsh1A
      alexsh1
      @anticimex it would be good, right Thomas @tbowmo? :)))
      Given my experience, I'd rather go for SAMD - at least I do not have to start from zero.
      • alexsh1A
        alexsh1A
        alexsh1
        Are there any similar size wise alternatives to SenseBender mk2 (SAMD), which are available right now?
        • alexsh1A
          alexsh1A
          alexsh1
          @NeverDie Check out this one nRF52. Its not cheap though
          https://www.tindie.com/products/onehorse/nrf52-add-on-for-butterfly-and-teensy/?pt=ac_prod_search
          • alexsh1A
            alexsh1A
            alexsh1
            Alternatively, this is a good size for a node - https://www.sparkfun.com/products/13664
            • alexsh1A alexsh1
              @alexsh1 said in atmega328p small (SMD) alternative with more memory?:
              Yes, I would agree that's interesting. He uses it as a BLE device, albeit purely as a UART channel, which so far isn't something that we've managed to do here with the nRF52. @GertSanders might want to take notice, as he has been doing something similar for logging purposes, but with a different bluetooth.
                @anticimex said in atmega328p small (SMD) alternative with more memory?:
                SenseBender mk2
                If that's how you define drop-in replacement, I'll concede the point.
                Actually, I suppose if you had a fast enough ARM, it could emulate an atmega328p (well, at least its software behavior), and thereby indirectly offer up additional memory. I actually own a board which, IIRC, does that, and it can run code even faster than the atmega328. Just don't expect low power performance out of it.
                AnticimexA 1 Reply Last reply
                  SenseBender mk2
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @neverdie I perhaps misread the thread title... I did not interpret the quest as something that should be binary identical to atmega328p.
                  NeverDieN alexsh1A 2 Replies Last reply
                    @anticimex Yeah, the title was ambiguous. Looking back, your interpretation is probably closer than mine as to what he meant though.
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @anticimex you are absolutely correct. It does not have to be binary identical to atmega328p. However, size wise, it has to be small enough.
                      For now atmega1284p is a direct replacement for atmega328p as code is almost identical. I do not need much more processing power just memory. However, I did struggle to find a very small footprint.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @alexsh1
                        Hmm.. perhaps I should pick up on the SenseBender MK2 again.. I lost focus as I had a lot of other projects running at the same time..
                        If I remember right, it had problems in it's bootup sequence when I left it alone last..
                          In terms of BOM cost, it would be cheaper to add a second atmega328p (or even multiple) than to use a 1284. Maybe worth considering if memory of just one is insufficient.
                          alexsh1A 1 Reply Last reply
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            You will then waste memory with "intercom" between the devices. As they have to speak together in some way..
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @neverdie Did you see any small devices with two atmega328p?
                              Unfortunately, atmega1284p is more pricey (Moteino Mega is $15.95 on sale right now) and size wise it is much larger than atmega328p-au projects.
                              • alexsh1A alexsh1
                                Yes, that's what I was trying to say.
                                  On the other hand, if you go with the cheapest source, the 1284p is not too bad. Here's the cheapest I could find:
                                  https://www.aliexpress.com/item/ATMEGA1284P-AU-ATMEGA1284P-ATMEGA1284-TQFP44/32864539405.html?spm=2114.search0104.3.1.2efd4b5asFo5Vr&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10344_10068_10130_10324_10342_5722912_10547_10325_10343_10546_10340_10341_10548_5722612_10698_10545_10697_10696_5722812_10084_10083_10618_5722712_10307_5711215_10059_10534_308_100031_10103_441_10624_10623_10622_5711315_10621_5723012_10620_5722512,searchweb201603_1,ppcSwitch_5&algo_expid=2d7e9a21-bc2a-4ce1-bfa8-6246a79e84df-0&algo_pvid=2d7e9a21-bc2a-4ce1-bfa8-6246a79e84df&priceBeautifyAB=0
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @neverdie said in atmega328p small (SMD) alternative with more memory?:
                                    I paid around £3.5 (about $5) and thought it was the cheapest. WOW!
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #25
                                      My new toy (atmega1284p) - Mightyduino
                                      However, I have to think about connecting radio as this is just a bare board.
                                      Size wise it is quite small0_1523634439436_53944617-D2C8-4479-A40A-42DA90D8D896.jpeg
                                      • alexsh1A alexsh1
                                        tochinet
                                        wrote on last edited by tochinet
                                        #26
                                        @alexsh1 Wouldn"t a teensy 3.sth fill all the requirements ? Or an ESP8266 if you don't need ADC mux. ESP32 is you do.
                                        R alexsh1A 2 Replies Last reply
                                        • T tochinet
                                          R
                                          R
                                          RWoerz
                                          @tochinet
                                          If you don't need a lot of them use a Mega it has lots more memory. They're much cheaper than they used to be. Of course an ESP8266 will also work if you don't need all the pins.
