  3. atmega328p small (SMD) alternative with more memory?
37 Posts 8 Posters 7.1k Views 9 Watching
  • alexsh1A alexsh1
    More and more, I come across that atmega328p loaded with mysensors, signing, encryption and a few sensors and libraries gives me this:
    Sketch uses 31924 bytes (103%) of program storage space. Maximum is 30720 bytes.
    Global variables use 2076 bytes (101%) of dynamic memory, leaving -28 bytes for local variables. Maximum is 2048 bytes.
    Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
    Error
    Whereas I do have Moteino Mega, which is an excellent form factor, but a but a bit too large when it comes to a small node. Anyone can recommend a tiny form factor node like Sensebender Micro but with considerably more memory please?
    @alexsh1 said in atmega328p small (SMD) alternative with more memory?:
    Well, the nRF52 series has more memory and is better in almost every way. And you can program it through the familiar Arduino IDE. Time to join the band wagon.
    AnticimexA 1 Reply Last reply
      AnticimexA
      AnticimexA
      Anticimex
      @neverdie are you sure they always come with a bootloader, and one that's compatible with Arduino? Afaik you need a debugger. Not that it's a problem, but it isn't exactly plug and play either.
      • AnticimexA Anticimex
        @anticimex said in atmega328p small (SMD) alternative with more memory?:
        You just need a programmer. I use JTAG, but many here have reported success with the super cheap STM v2.
          AnticimexA
          AnticimexA
          Anticimex
          @neverdie I know, but it is still a detail worth mentioning. It is not a drop in replacement unless you happen to sit on compatible debuggers or programmers already. And even then, I am unsure if the arduino IDE can be used to program a suitable bootloader in a user friendly way.
          That said, I agree that nrf52 is the future. Closely followed by SAMD.
            There doesn't exist a drop in replacement.
              AnticimexA
              AnticimexA
              Anticimex
              @neverdie a SenseBender mk2 based on samd would be a drop in replacement for SenseBender.
                @alexsh1 at some point I belive a SAMD based SenseBender might arrive.
                alexsh1A
                alexsh1A
                alexsh1
                @anticimex it would be good, right Thomas @tbowmo? :)))
                Given my experience, I'd rather go for SAMD - at least I do not have to start from zero.
                • alexsh1A
                  alexsh1A
                  alexsh1
                  Are there any similar size wise alternatives to SenseBender mk2 (SAMD), which are available right now?
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    @NeverDie Check out this one nRF52. Its not cheap though
                    https://www.tindie.com/products/onehorse/nrf52-add-on-for-butterfly-and-teensy/?pt=ac_prod_search
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      Alternatively, this is a good size for a node - https://www.sparkfun.com/products/13664
                      • alexsh1A alexsh1
                        Yes, I would agree that's interesting. He uses it as a BLE device, albeit purely as a UART channel, which so far isn't something that we've managed to do here with the nRF52. @GertSanders might want to take notice, as he has been doing something similar for logging purposes, but with a different bluetooth.
                          SenseBender mk2
                          If that's how you define drop-in replacement, I'll concede the point.
                          Actually, I suppose if you had a fast enough ARM, it could emulate an atmega328p (well, at least its software behavior), and thereby indirectly offer up additional memory. I actually own a board which, IIRC, does that, and it can run code even faster than the atmega328. Just don't expect low power performance out of it.
                            SenseBender mk2
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @neverdie I perhaps misread the thread title... I did not interpret the quest as something that should be binary identical to atmega328p.
                            NeverDieN alexsh1A 2 Replies Last reply
                              @anticimex Yeah, the title was ambiguous. Looking back, your interpretation is probably closer than mine as to what he meant though.
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @anticimex you are absolutely correct. It does not have to be binary identical to atmega328p. However, size wise, it has to be small enough.
                                For now atmega1284p is a direct replacement for atmega328p as code is almost identical. I do not need much more processing power just memory. However, I did struggle to find a very small footprint.
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @alexsh1
                                  Hmm.. perhaps I should pick up on the SenseBender MK2 again.. I lost focus as I had a lot of other projects running at the same time..
                                  If I remember right, it had problems in it's bootup sequence when I left it alone last..
                                    In terms of BOM cost, it would be cheaper to add a second atmega328p (or even multiple) than to use a 1284. Maybe worth considering if memory of just one is insufficient.
                                    alexsh1A 1 Reply Last reply
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      You will then waste memory with "intercom" between the devices. As they have to speak together in some way..
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @neverdie Did you see any small devices with two atmega328p?
                                        Unfortunately, atmega1284p is more pricey (Moteino Mega is $15.95 on sale right now) and size wise it is much larger than atmega328p-au projects.
                                        • alexsh1A alexsh1
                                          Yes, that's what I was trying to say.
