  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.6k Views 73 Watching
  • tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    both. in my setup i'm using a serial over tcp approach (NAS: serial gateway & ser2net)- fw loading is substantially faster and more stable compared to the ethernet gateway.
    JohnJ 1 Reply Last reply
    • tekkaT tekka
      JohnJ
      JohnJ
      John
      @tekka
      Very nice approach, this could also work on other boxes where serial interfaces are not exclusively opened.
      • E
        E
        ericvdb
        @tekka
        You plan to share this, or provide the sources?
        It looks indeed verry nice ;)
        • ch3b7C
          ch3b7C
          ch3b7
          Good work man! im make a controller in .net!
          http://clip2net.com/s/3aGJdvY
          • tekkaT
            tekkaT
            tekka
            @ericvdb yes, I will provide a link soon
            @ch3b7 cool :+1: , are you also implementing tcp connections?
            • ch3b7C
              ch3b7C
              ch3b7
              yes but at now im not have a ethernet shield right now =( and i need to work with the optiboot/OTA bootloader part and dont know where find that part "request" "send" all that info. sorry my bad english im from argentina.!
              • daulagariD
                daulagariD
                daulagari
                Yes, looks really nice!
                Seems to be written in TK so cross-platform, even better!
                • greglG
                  greglG
                  gregl
                  Wow...really nice. Cant wait to give it a go!
                  • D
                    diamantmatch
                    wow, this is something!
                    would really love to set this up at home!
                    i also can't wait for your link to appear, really exited !
                    • T
                      Tibus
                      Yeah, really looks nice!
                      Can't wait too for the link and more info about de OTA bootloader.
                      I'm making some industrial opensources sensor based on MySensor and my current bootloader don't have an OTA Bootloader. So it would be greate with your Bootloader and your application!
                      • P
                        P
                        p0lar
                        Nice.... Following
                        • J
                          J
                          jribera
                          This looks very interesting. Seems like it will make remote debugging easy, ie can run this on a PC at home and RDP into it.
                          • C
                            C
                            chris021
                            Also Following. Very keen to try this!
                            • RJ_MakeR
                              RJ_MakeR
                              RJ_Make
                              Will this program act like a controller (take the place of Vera?) and handle automation logic?
                              RJ_Make
                              • tekkaT
                                tekkaT
                                tekka
                                hi all,
                                here is the first alpha version of the MYSController (I changed the name).
                                http://goo.gl/9DCWNo
                                There are still lots of things that need to be done and some bugs :), but feel free to give it a try. I included the modified bootloader (flash according to the settings in the fuses.txt file) and two example .hexs for testing/uploading. From my experience, the OTA works better/faster using the serial gateway.
                                Cheers,
                                tekka
                                • C
                                  C
                                  chris021
                                  Got it working first try! Can see data coming back from my Temp and Hum sensors!
                                  Looks like a great tool.
                                  Thank you!
                                  • daulagariD
                                    daulagariD
                                    daulagari
                                    @tekka
                                    :+1:
                                    Saw it was a Windows executable but did give it a try on Linux:
                                    wine MYSController.exe
                                    And the GUI comes up nicely!
                                    I can not select the serial port yet, so could not test it further, likely have to do some mapping in wine.
                                      wrote on last edited by hek
                                      Yepp.. GUI comes up on mac using wine as well. Will try tomorrow when I have an Arduino nearby.
                                      • T
                                        Tibus
                                        is it possible tu use the ota bootloader on 8Mhz?
                                        • tekkaT
                                          tekkaT
                                          tekka
                                          For OTA should be ok, for AVRDUDE not tested
