  3. Anyone tried the Creality CR-10 3D printer?
104 Posts 12 Posters 33.1k Views 10 Watching
    What layer hight did you use?
    dbemowskD
    dbemowskD
    @gohan Sound like it was a gcode file on the SD card, so my guess is that he didn't slice it and may not know.
    gohanG 1 Reply Last reply
    • dbemowskD
      dbemowskD
      A note though if you are looking at choosing a slicer. For most of the time that I owned my 3D printer I was using Cura as my slicer. I have recently done some things using Slic3r and I find that it has a lot more options and does an overall better job at slicing. I also recommend a rapberry pi running octoprint.
      • dbemowskD dbemowsk
        @dbemowsk Presently using https://prusacontrol.org/ , which is a simplified version aimed at fresh noobs like me. I used it to generate the gcode for the Andreas Spiess power meter case (referenced above).,
          #85
          Are any of the available printer filaments odor free? The free roll of Prusa PLA that came with my kit doesn't smell very good when printing with it.
          I just now ordered: https://www.amazon.com/gp/product/B00MB3CV6K/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
          which claims to be "odor free." Well, here's hoping it is. ;)
          dbemowskD NeverDieN 2 Replies Last reply
            dbemowskD
            dbemowskD
            @neverdie said in Anyone tried the Creality CR-10 3D printer?:
            I myself have not tried any that are completely odor free. I haven't had too much trouble with the PLA that I have used, and I have tried a number of different brands. ABS smells a lot worse than PLA.
              @dbemowsk I was referring to the box he was printing, maybe a thicker layer would cut the print time since he doesn't need to have fine details on the box
              dbemowskD 1 Reply Last reply
                dbemowskD
                dbemowskD
                @gohan I see. I thought you were referring to his benchy.
                • E
                  E
                  executivul
                  PLA smells like hot popcorn/cooking oil, it's corn based afterall
                  ABS smells bad and it's a little toxic
                  PETG is almost odourless, very resistent, easy to print, doesn't warp or shrink when cooling
                  Best slicer: Simplify3D
                    #90
                    PETG and PLA are easier to print. PLA is easier, but PETG is not hard to use, just need a few changes on settings for speed etc.
                    I use simplify3d too :)
                    Note:
                    • when you buy new filament rolls, it's good to check the thickness with caliper and calibrate your slicer for that. It can improve results
                    • better use different nozzles. one for PLA, and one for PETG. they don't melt at same temperature.
                      So if you melt PETG and then would like to use PLA, then you could get clogging because of PETG residue not melting at PLA temperature.
                    • when sourcing parts on aliexpress for heatbreak etc (spare parts etc), it's good to remachine them. it can be a source of clogging too. They are not same quality as if you ordered them from e3d for example..
                    • E executivul
                      dbemowskD
                      dbemowskD
                      @executivul Doesn't Simplify3D cost $$$ though? Slic3r is free.
                      E 1 Reply Last reply
                        E
                        E
                        executivul
                        @dbemowsk said in Anyone tried the Creality CR-10 3D printer?:
                        Unfortunately for them it does, but we know a guy...
                        • E executivul
                          dbemowskD
                          dbemowskD
                          @executivul said in Anyone tried the Creality CR-10 3D printer?:
                          Never a bad thing...
                            #94
                            Worth mentioning: in fooling around with the Prusa slicer, I noticed that the estimated print times for the I3 MK3 are almost half of what they are for the I3 MK2. I presume that can be attributed to the Trinamic driver chips and also, possibly, Prusa's custom firmware's ability to effectively exploit them. Not sure as to whether or not Marlin can yet do the same.
                              I tried it, and indeed it seems to have no odor. Hopefully (?) it's also not giving off any emissions that I can't smell either.
                                #96
                                I upgraded my Prusa I3 MK3 to use a Volcano with a 0.8mm nozzle. Now I can print a Benchie in 16 minutes!
                                https://www.thingiverse.com/thing:763622
                                For enclosures, the relative speed improvement should be even more noticeable.
                                  dbemowskD
                                  dbemowskD
                                  @neverdie Are you using an E3D J-Head with your Volcano hot end? I am in the process of working on an E3D clone J-Head setup with a Bowden extruder, but I went with the standard heat block and not the Volcano.
                                    @dbemowsk All I did was swap the E3D V6 hot-end for the volcano hot end.
                                    What is a J-Head?
                                      I also printed a Benchie in translucent PLA at 0.1mm layer height using the volcano, and it came out very smooth:
                                      So, overall, it has pretty good dynamic range.
                                        What is a J-Head?
                                        dbemowskD
                                        dbemowskD
                                        #100
                                        @neverdie If you have an E3D V6, then you are running a J-Head.
                                        Not sure exactly why they call it a J-Head as it looks nothing like a J shape...
                                        I assume you just swapped out the heat block? The Volcanos are like a standard heat block only stood on end.
                                        https://www.amazon.com/J-head-Hotend-Filament-Extruder-Printer/dp/B010MSTVZO
                                          dbemowskD
                                          dbemowskD
                                          @neverdie That has got to be one of the smoothest benchies I've seen.
