  3. Anyone tried the Creality CR-10 3D printer?
104 Posts 12 Posters 33.1k Views 10 Watching
  • dbemowskD dbemowsk
    @mbj It would have to tighten and also not cause any binding of the Z axis during travel. I have see belt tensioner springs that snap on to the belt, but with this needing to be continual rotation, that wouldn't work.
    @dbemowsk I think that if pretty much nobody is doing that kind of setup, I guess the technical complications kind of outweight the benefits of using a single motor for Z axis, don't they?
    • E
      E
      executivul
      Tevo Black Widow uses a single z stepper with 2 screws.
      • P
        P
        pjr
        @dbemowsk there is the same with tensioning with motor: Tevo Tarantula Single Motor Dual Z Axis
          #75
          I'm in the middle of putting the Prusa IS3 MK3 together, and it is a lot of assembly. If it's true that the CR-10 can be put together in half an hour, then that's really quite impressive.
          dbemowskD gohanG 2 Replies Last reply
            dbemowskD
            dbemowskD
            @neverdie If it is anything like my Anet A8, mine took quite a few hours to put together. It looks like the MK3 has an all or at least mostly metal frame which is nice. The frame on min is laser cut acrylic and one of the big things with that is that the acrylic comes with a protective paper coating which needed to be peeled off prior to assembly. That part took over an hour in itself and was a pain.
              @neverdie the frame comes assembled is 2 pieces plus the control unit, so it is a matter of a few bolts and connecting the wires, nothing more.
                #78
                Attached is a photo of the benchy that was printed in PLA from a file that came 0_1524851107876_benchy.jpg
                on the Prusa I3 MK3 SD Card. Not perfect, but I guess about par for a hobbyist 3D printer.
                  Nice, a little stringing that you can solve with minor tweaks. What happened to the chimney?
                    #80
                    @gohan said in Anyone tried the Creality CR-10 3D printer?:
                    Heck if I know. This is only the second object I've ever printed. However, if I had to guess, I'd guess that it's an artifact of the way it was sliced.
                    Presently I'm printing the Andreas Spiess power meter case: https://www.thingiverse.com/thing:2789890/#files
                    Just for the box itself, not even including the lid, the estimated print time is over 5 hours! So maybe when the megavolcano hot end comes out, I'll look into getting one.
                      What layer hight did you use?
                      dbemowskD 1 Reply Last reply
                        dbemowskD
                        dbemowskD
                        @gohan Sound like it was a gcode file on the SD card, so my guess is that he didn't slice it and may not know.
                        gohanG 1 Reply Last reply
                        • dbemowskD
                          dbemowskD
                          A note though if you are looking at choosing a slicer. For most of the time that I owned my 3D printer I was using Cura as my slicer. I have recently done some things using Slic3r and I find that it has a lot more options and does an overall better job at slicing. I also recommend a rapberry pi running octoprint.
                            @dbemowsk Presently using https://prusacontrol.org/ , which is a simplified version aimed at fresh noobs like me. I used it to generate the gcode for the Andreas Spiess power meter case (referenced above).,
                              #85
                              Are any of the available printer filaments odor free? The free roll of Prusa PLA that came with my kit doesn't smell very good when printing with it.
                              I just now ordered: https://www.amazon.com/gp/product/B00MB3CV6K/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
                              which claims to be "odor free." Well, here's hoping it is. ;)
                              dbemowskD NeverDieN 2 Replies Last reply
                                dbemowskD
                                dbemowskD
                                @neverdie said in Anyone tried the Creality CR-10 3D printer?:
                                I myself have not tried any that are completely odor free. I haven't had too much trouble with the PLA that I have used, and I have tried a number of different brands. ABS smells a lot worse than PLA.
                                  @dbemowsk I was referring to the box he was printing, maybe a thicker layer would cut the print time since he doesn't need to have fine details on the box
                                    dbemowskD
                                    dbemowskD
                                    @gohan I see. I thought you were referring to his benchy.
                                    • E
                                      E
                                      executivul
                                      PLA smells like hot popcorn/cooking oil, it's corn based afterall
                                      ABS smells bad and it's a little toxic
                                      PETG is almost odourless, very resistent, easy to print, doesn't warp or shrink when cooling
                                      Best slicer: Simplify3D
                                        #90
                                        PETG and PLA are easier to print. PLA is easier, but PETG is not hard to use, just need a few changes on settings for speed etc.
                                        I use simplify3d too :)
                                        Note:
                                        • when you buy new filament rolls, it's good to check the thickness with caliper and calibrate your slicer for that. It can improve results
                                        • better use different nozzles. one for PLA, and one for PETG. they don't melt at same temperature.
                                          So if you melt PETG and then would like to use PLA, then you could get clogging because of PETG residue not melting at PLA temperature.
                                        • when sourcing parts on aliexpress for heatbreak etc (spare parts etc), it's good to remachine them. it can be a source of clogging too. They are not same quality as if you ordered them from e3d for example..
                                        • E executivul
                                          dbemowskD
                                          dbemowskD
                                          @executivul Doesn't Simplify3D cost $$$ though? Slic3r is free.
                                          E 1 Reply Last reply
