  3. [SOLVED] MYSBootloader FOTA Update hangs on ProMini-3V-8MHz (reboot problem)
21 Posts 5 Posters 5.7k Views 4 Watching
  • R
    R
    rafael156
    wrote on last edited by rafael156
    Hello!
    I have a Pro Mini 328P 3.3V 8MHz clone with external quartz on which I wanted to install the MYSBootloader.
    The Arduino is as follows:
    https://de.aliexpress.com/item/ProMini-ATmega328P-3-3V-Compatible-for-Arduino-Pro-Mini/32525927539.html?spm=a2g0x.search0104.3.120.62c938ebDXquOj&ws_ab_test=searchweb0_0,searchweb201602_2_10320_10152_10321_10065_10151_10344_10068_10342_10547_10343_10322_10340_10548_10341_10193_10194_10084_10083_10618_10304_10307_10302_10180_10313_10059_10184_10534_100031_10319_1010101010103_10627_10634_1053searchweb201603_25,ppcSwitch_5&algo_expid=f9abed72-8c7f-41ab-9222-8e1f1c07db75-17&algo_pvid=f9abed72-8c7f-41ab-9222-8e1f1c07db75&priceBeautifyAB=0
    Fuse settings are as follows:
    low_fuses=0xFF
    high_fuses=0xD2
    extended_fuses=0x06
    I have the MYSBootloader here:
    https://github.com/mysensors/MySensorsBootloaderRF24/blob/master -> Branch:Master and MYSBootloader.hex
    I also tried:
    https://github.com/mysensors/MySensorsBootloaderRF24/tree/UpdateBoardFiles -> Branch: UpdateBoardFiles and /hex/MYSBootloader_8MHz.hex
    I have the Sensebender Gateway on a Linux server.
    All pins of the NRF24L01+ are connected to the Arduino.
    I use MySensors 2.2.0.
    I programmed the fuses, the hex files mentioned above and a sketch with the mySmartUSBLight Programmer without Arduino IDE. As an example sketch I took the "Mysensor passive node".
    Now to the problem:
    When I try to start a FOTA update to the node (ID100) with the MYSController (https://www.mysensors.org/controller/myscontroller), the following comes in the debug log of the MYSController:
    "[Firmware config response] 01000..."
    The status of the node indicates "FW updating 1%". Even after an hour of waiting, nothing happens. Even a reboot via the MYController does not work independently of the FOTA update.
    It seems that the bootloader does not work.
    I've been trying for hours, but I haven't found the error.
    Can you help me, please?
    • R
      R
      rafael156
      Can anyone help? Do i have to flash the Arduino with a USBasp?
        Is sensebender gw running as usb/serial? Did you get some debug from the node?
        • R
          R
          rafael156
          Thanks for the answer! I found the error yesterday:
          I had OpenHab running in the background on the Linux system with the Sensebender Gateway (as USB). As a result, it appears that the gateway was "occupied" for a time. After I closed Openhab, I was able to perform a FOTA update without errors.
          However, after I have uploaded the sketch "passive node", I cannot upload another sketch. After the first upload, the node executes its code normally and does not receive a new sketch anymore.
          Does the sketch have to be programmed for fota updates? Maybe with a setting?
          I have MYSController Version 1.0.0.3316
            yes you need to enable the FOTA with its define.
            For your problem with fota and openhab I think it is related to the gw being connected with USB so the 2 controllers are sharing the same serial port and I guess openhab doen't like to share much :D
            If you could add an ethernet module to the GW and make it ethernet or mqtt you could connect more controllers more easily
            • R
              R
              rafael156
              thanks for the info!
              i thought you only needed it for DualOptiboot. I read it here:
              https://www.mysensors.org/about/fota#enabling-fota-in-your-sketch-dualoptiboot-only
                maybe I am wrong, I use the dual optiboot as it is much easier to use
                • R
                  R
                  rafael156
                  this has now worked:
                  • in the sketch you don't have to activate the fota update in the mysbootloader
                  • the last MYSBootloader 1.3.0-rc.1 works
                  the next problem is:
                  if the node has no sketch, the node boots constantly into the bootloader and can load every sketch per fota update.
                  as soon as the node has a sketch and is rebooted by the myscontroller, the node is only restarted by software/watchdog and apparently does not jump into the bootloader. thus it cannot load a new sketch.
                  Only if I reboot the node manually, the fota update works.
                  The only problem is the soft-reset, which does not work as expected.
                  Is there a way to reboot the Atmega328p like I do with the manual button?
                  Why does the watchdog/ soft-reset not work?
                  • R
                    R
                    rafael156
                    here's what I've been trying on arduino 328P-8MHz XTAL-3v3:
                    fuse settings from development branch(only to external xtal changed):
                    MYSBL.menu.frequency.MYSBL8=ATmega328 8Mhz ext MYSBootloader_1.3.0-rc.1
                    MYSBL.menu.frequency.MYSBL8.build.f_cpu=8000000L
                    MYSBL.menu.frequency.MYSBL8.upload.speed=57600
                    MYSBL.menu.frequency.MYSBL8.bootloader.low_fuses=0xFF
                    MYSBL.menu.frequency.MYSBL8.bootloader.high_fuses=0xD2
                    MYSBL.menu.frequency.MYSBL8.bootloader.extended_fuses=0x06
                    MYSBL.menu.frequency.MYSBL8.bootloader.unlock_bits=0x3F
                    MYSBL.menu.frequency.MYSBL8.bootloader.lock_bits=0x0F
                    MYSBL.menu.frequency.MYSBL8.bootloader.file=MySensors/MYSBootloader_8MHz.hex
                    then i burned the bootloader from https://github.com/mysensors/MySensorsBootloaderRF24/blob/development/hex/MYSBootloader_8MHz.hex
                    and got warnings from arduino IDE:
                    avrdude: WARNING: invalid value for unused bits in fuse "lock", should be set to 1 according to datasheet
                    This behaviour is deprecated and will result in an error in future version
                    You probably want to use 0xff instead of 0x3f (double check with your datasheet first).
                    avrdude: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
                    You probably want to use 0xfe instead of 0x06 (double check with your datasheet first).
                    You probably want to use 0xcf instead of 0x0f (double check with your datasheet first).
                    Then the first firmware after flashing the bootloader:
                    https://ibb.co/gbQ7Sd
                    serial communication works, but with baud 115200. shouldn't this be 57600 at 8MHz?
                    https://ibb.co/cxpqfy
                    a manual restart of the node does nothing...
                    https://ibb.co/e7bp7d
                    after i hard-reset, the node is restarting...
                    https://ibb.co/jTxMnd
                    warum funktioniert der software reboot nicht? und warum hat der node eine baud rate von 115200 statt 57600 nach aktuellem dev.branch?
                    tekkaT 1 Reply Last reply
                    • R rafael156
                      tekkaT
                      tekkaT
                      tekka
                      wrote on last edited by tekka
                      @rafael156 Please post your sketch - looks like your sketch does not process incoming messages.
                      • R
                        R
                        rafael156
                        this is the current dht-sketch from mysensors-examples:
                         * Version 1.0: Henrik EKblad
                         * sensor using a DHT11/DHT-22.
                        // Enable debug prints
                        //#define MY_RS485
                        #define DHT_DATA_PIN 3
                        #define SENSOR_TEMP_OFFSET 0
                        static const uint64_t UPDATE_INTERVAL = 60000;
                        #define CHILD_ID_HUM 0
                        #define CHILD_ID_TEMP 1
                        float lastTemp;
                        float lastHum;
                        uint8_t nNoUpdatesTemp;
                        uint8_t nNoUpdatesHum;
                        bool metric = true;
                        DHT dht;
                          sendSketchInfo("TemperatureAndHumidity", "1.1");
                          present(CHILD_ID_HUM, S_HUM);
                          dht.readSensor(true);
                          if (isnan(temperature)) {
                            lastTemp = temperature;
                            if (!metric) {
                            // Reset no updates counter
                            nNoUpdatesTemp = 0;
                            #ifdef MY_DEBUG
                            Serial.print("T: ");
                            nNoUpdatesTemp++;
                          if (isnan(humidity)) {
                            lastHum = humidity;
                            nNoUpdatesHum = 0;
                            #ifdef MY_DEBUG
                            Serial.print("H: ");
                            Serial.println(humidity);
                            nNoUpdatesHum++;
                          sleep(UPDATE_INTERVAL);
                        • R
                          R
                          rafael156
                          @tekka Do you have an idea what´s wrong with the code? yesterday i have changed "sleep(UPDATE_INTERVAL);" to "wait(UPDATE_INTERVAL); " but bothing changed. Fota update or software reboot doesnt work.
                          Are the fuses and the bootloader options (txt) correct?
                            don't you need to reboot to trigger the update?
                            • R
                              R
                              rafael156
                              Yeah, right! That's the problem! But when I click on "reboot" on myscontroller, the node does not react to any command, i.e. reboot etc.
                              is there a function that takes the command from myscontroller and executes it or do I have to implement it myself in the sketch?
                              SoloamS gohanG 2 Replies Last reply
                              • R rafael156
                                SoloamS
                                SoloamS
                                Soloam
                                @rafael156 I had a similar problem, my node would stop responding when I tried to reboot it. The problem was in the fuse settings, have you checked if they are all set? What version are you using? (16,8 or 1)
                                • R rafael156
                                  @rafael156 have you tried with smartsleep instead of sleep? Of course the node would respond only when it wakes up.
                                  • R
                                    R
                                    rafael156
                                    @Soloam i have checked fuse settings several times . i use the 8 mhz version. boards.txt see above .
                                    at burn process, arduino ide (1.6.13) gave me a warning about the fuses
                                    which fuses do you have?
                                    @gohan no, i didnt. but i have tried wait(), with no success. i will try smartsleep() today!
                                    • R rafael156
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @rafael156 Hmm, I don't think this is related to the fuse settings. Try again changing sleep() to wait() and upload the full logs from MYSController and the node (with MY_DEBUG enabled)
                                      • R
                                        R
                                        rafael156
                                        ok, Thanks at all!
                                        You helped me find the mistake!
                                        it was actually because the node could not receive commands because there was a "sleep()" hidden somewhere in each sketch. after I searched all sketches thoroughly and replaced them with "wait()", everything runs without problems:
                                        //#define MY_RS485
                                        float lastTemp;
                                        float lastHum;
                                        bool metric = true;
                                        DHT dht;
                                          wait(dht.getMinimumSamplingPeriod());
                                            if (!metric) {
                                            nNoUpdatesTemp = 0;
                                            #ifdef MY_DEBUG
                                            nNoUpdatesTemp++;
                                            lastHum = humidity;
                                            nNoUpdatesHum = 0;
                                            #ifdef MY_DEBUG
                                            nNoUpdatesHum++;
                                          //sleep(UPDATE_INTERVAL);
                                        void receive(){
                                        However, I would suggest that the functions "wait()" and "smartsleep()" be mentioned in relation to the MySBootloader in a separate point under "https://www.mysensors.org/about/fota". Maybe under a chapter:
                                        1. Enabling FOTA in your sketch
                                          1.1 DualOptiboot only
                                          --> text as before
                                          1.2 MySBootloader
                                          --> ... use smartsleep() and wait() instead of sleep()...
                                        Summary:
                                        • fuse settings 8MHz external crystal:
                                        • if sensebender gateway is connected via usb, only one instance may access the gateway at a time, therefore "OpenHab" must be terminated first
                                        • do not use "sleep()" in the sketches. only "smartsleep()" or "wait()".
                                          use the current dev-branch from "https://github.com/mysensors/MySensorsBootloaderRF24
                                        gohanG badmannenB 2 Replies Last reply
                                        • R rafael156
                                          ok, Thanks at all!
                                          //#define MY_RS485
                                          float lastTemp;
                                          float lastHum;
                                          bool metric = true;
                                          DHT dht;
                                              if (!metric) {
                                              nNoUpdatesTemp = 0;
                                              #ifdef MY_DEBUG
                                              nNoUpdatesTemp++;
                                              lastHum = humidity;
                                              nNoUpdatesHum = 0;
                                              #ifdef MY_DEBUG
                                              nNoUpdatesHum++;
                                          void receive(){
                                            --> text as before
                                            1.2 MySBootloader
                                          Summary:
                                          @rafael156 said in [SOLVED] MYSBootloader FOTA Update hangs on ProMini-3V-8MHz (reboot problem):
                                          I'd use smartsleep in this case as wait will keep the MCU active and drain battery. Wait is better used in place of "delay"
