1.1k Posts 105 Posters 796.0k Views 98 Watching
  • vladimirV vladimir
    The other day I finished the first version of the PCB for my system of protection against water leakage. It will have two automatic ball valves, six leakage sensors with wire breakage monitoring and in the future I plan to connect it to the Mysensors.
    Here is a prototype collected with the help of Arduino Pro Mini. Arduino Uno is just nearby, but not connected. Do not pay any attention to him. :)
    zboblamontZ
    zboblamontZ
    zboblamont
    @vladimir I gather you meant motorised ball valves rather than automatic, the automation being on the processor.
    When you refer to leakage, is this to react to pipes potentially bursting or an external failure such as drainage failure in a cellar?
    vladimirV 1 Reply Last reply
    • zboblamontZ zboblamont
      vladimirV
      vladimirV
      vladimir
      @zboblamont Yes, it is, motorized ball valves.
      I meant the reaction to the breakthrough of pipes or flexible connections of sanitary ware.
        zboblamontZ
        zboblamontZ
        zboblamont
        @vladimir Ok understood, washing machine hose failure or plumbing seals etc..
        Had also considered incorporating leak detection after twice flooding out my bathroom (water softener cycle discharged externally normally - doesn't work so well at -20), ultimately solved by some overflow plumbing to internal drainage.
        Still considering leak detection as a failsafe, but was looking at monitoring internal and external pressure and flow as well as conductivity at three separate areas. The idea was to similarly initiate shutdown of a motorised valve (for the entire house), or close down the supply pump for an external burst, so a little more complicated, but hence the curiosity.
        For surface water detection I was looking at either fixed stainless stud contacts on the tiled floors, or mounting 3 on a plate like a tripod, as it should be more resistant to corrosion than standard rain sensor plates.
        bjacobseB 1 Reply Last reply
          bjacobseB
          bjacobseB
          bjacobse
          @zboblamont
          water leak/flooding detection,
          I propose to get some stainless conductive wire, like this: https://www.adafruit.com/product/603
          and then add 2 parallel wires on tape, and tape this to the floor, besides the dishwasher
          • bjacobseB bjacobse
            @zboblamont
            zboblamontZ
            zboblamontZ
            zboblamont
            @bjacobse Interesting concept, and product, not so sure about the tape idea over a mechanical fix, the tape's behaviour in a wet or moist environment could prove unpredictable.
            Tie/clamp this to a stud, or to a stainless rod projected to floor level might solve the corrosion issue with copper wire though....
              vladimirV
              vladimirV
              vladimir
              wrote on last edited by vladimir
              #580
              @zboblamont @bjacobse
              I plan to make the leakage sensors waterproof, with outwardly exposed contacts made of stainless steel. I plan to lift the contacts 1-2mm from the floor so that when washing floors, when the floor is just a little wet sensor did not work. I really like the sensors from Xiaomi.
              I ordered for the sample here are such cases from China:
              1 - 31х10mm
              2 - 61х20mm
              • vladimirV
                vladimirV
                vladimir
                The project of today is not yet connected with Mysensors.
                This is a light relay with an IR receiver for the spotlight illuminating the backyard of my friends' house.
                In the dark, the relay can be switched off from the remote control (to block the activation of the relay). If the remote is far away from you, then the lock can be removed with the searchlight switch by restarting it.
                To understand if the relay is locked, there is a red LED on the case.
                • sundberg84S
                  sundberg84S
                  #582
                  Anyone spots the differens? One booster draws 21mA sleeping and the other 13uA.
                  (I don't).
                  zboblamontZ NeverDieN 3 Replies Last reply
                  • sundberg84S sundberg84
                    (I don't).
                    zboblamontZ
                    zboblamontZ
                    zboblamont
                    @sundberg84 Easy, one is disconnected... :joy: At 90 degrees? :stuck_out_tongue_winking_eye:
                      (I don't).
                      @sundberg84 Different SMD capacitors?
                        (I don't).
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @sundberg84 Which booster is this anyway it looks better made than many I've seen available ?
                          sundberg84S
                          sundberg84S
                          @zboblamont its the one from mysensors store. I bought 10 and 8 of them is working.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            #587
                            Finally I finished my chicken coop door opening thingie :) A build that has taken way to much time to complete, and a few different directions.
                            Just as I was ready to install the thing, I discovered that the DC motor that I had bought for this, couldn't lift the gate. So I had to go scrap hunting, to find a larger motor for it.. Luckily I had a 24V motor from a broken garageport opener which chould be used at 12V.
                            Control box above the door, includes a PIR sensor in the lid.
                            the gate, a sheet of 3mm black acrylic "glass". I had a couple of reed relays in the parts bin, so I use those to detect positions of the gate.
                            The motor on is placed on the inside of the wall.
                            Field update of the firmware.. Should probably reflash the bootloader, to mysboot, so I can do it OTA..
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              and of course a small video of the in action
                              https://youtu.be/ABd86RK-Z4E
                              YveauxY bjacobseB 2 Replies Last reply
                              • tbowmoT tbowmo
                                @tbowmo smooth! :+1:
                                That should keep the foxes out :fox_face:
                                • tbowmoT tbowmo
                                  bjacobseB
                                  bjacobseB
                                  bjacobse
                                  @tbowmo Looks good
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    "funny" thing, that you first find all bugs after a more advanced node is deployed.. But after a couple of days debugging, with frequent firmware updates (opening the box, plugging in cables, and sitting with a laptop between all the chickens). I think that it is done now..
                                    Firmware is here (if anyone is curios) https://github.com/tbowmo/chickenCoopFirmware
                                    • Z
                                      Z
                                      zelen
                                      Hi all!
                                      Today I eventually built my first MySensors device - Serial Gateway.
                                      Now I'm testing it with OpenHab and working on first node - battery powered scene controller.
                                      • tbowmoT tbowmo
                                        @bjacobse
                                        I have been using influxdb/grafana for the last year or so, for logging data and presenting it, so no need to use domoticz for that. Over a year ago I injected nodered into the stream, so it sits between mysensors and domoticz, and was used to route things around (And make some fake sensors for domoticz).
                                        For the dashboard part I have been developing my own solution. First it was running within domoticz as a customized dashboard, but I moved it to Angular instead, with a strong dependency towards domoticz, as I could query that to get sensor values. Lately I had moved on to use MQTT for the dashboard (and internal node-red data routing). There I can get persistent data (retain) that keeps the latest data on a given topic. Then my need for domoticz went away there..
                                        The last thing I then used domoticz for, was the automation rules for turning on / off my tv when the chromecast was activated, and control a couple of LED strips according to the state of the chromecast (playing / paused etc). With that moved to nodered, then domoticz could be turned off.
                                        The complete software stack is a bit larger, than with domoticz for everything, but it is much more flexible, than what I could achieve with domoticz.
                                        also it brought in a couple of needed updates for my node-red mysensors nodes, so that was a "bonus" as well :)
                                        chisightC
                                        chisightC
                                        chisight
                                        wrote on last edited by chisight
                                        #593
                                        @tbowmo I've also been using MQTT and NodeRed as the routing solution for my home automation. I found that there was no default handling of ID_REQUEST messages which made configuring new nodes a manual process but eventually added that to my flows and now new nodes don't have to be configured at the Arduino end.
                                        It would be nice to see more about your setup, more specifically about the dependencies in nodered-mysensors-flow/package.json on your github.
                                        See me on IRC at ircs://freenode:6697/##nodered and ircs://freenode:6697/#mysensors
                                        tbowmoT 1 Reply Last reply
                                        • chisightC chisight
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @chisight
                                          Have you seen this thread: https://forum.mysensors.org/topic/9296/node-red-contrib-mysensors-release-thread ?
                                          Basically these set of nodes includes a controller node, that handles mysensors ID assignments, and a couple of other basic controller features.
                                          chisightC 1 Reply Last reply
