1.1k Posts 105 Posters 796.0k Views 98 Watching
  • Nca78N
    I made a working version of my test board with PCF85176 LCD driver, finally reaching some decently low current consumption for an always on display. There are still some possible gains to make with lower driver voltage, and with a more recent driver that should allow to go as low as 5uA.
    • dbemowskD
      dbemowskD
      Though not MySensors related, I thought I'd post my latest build that has been consuming a lot of my time lately. This is the main reason I haven't been on the forum much lately. I bought a drone kit recently. Here are some pics from the initial assembly:
      Since the initial build I have flown it and from a hard landing broken one of the cheap plastic legs that it came with. I designed a replacement with my 3D printer and some 1/4 inch aluminum rod.
      Here are some pics at it's current stage. I have designed and printed some prop guards and a few other add-ons:
      I have also designed and built a small servo based 3 axis camera gimbal. The controller was built using one of my spare 5 volt pro minis and an MPU-6050 accelerometer. Still working on the parts that will attach it to the drone, and I still need to pick up an FPV camera to attach to it, but a simple FPV cam is cheap.
      • sundberg84S sundberg84
        @bjacobse it's the cheapest one on eBay with the software cheese on Linux. I think it's a replica on Andostar x500 so search Usb microscope Andostar and you will find.
        bjacobseB
        bjacobseB
        bjacobse
        #571
        @sundberg84
        Thank you Sundberg for your help, I now have received my own microscope, a reply to your comments from 1 or 2 months ago
        • andrewA andrew
          @andrew said in What did you build today (Pictures) ?:
          0_1512830079874_small_20171119_155404.jpg 0_1512830092134_small_20171119_163354.jpg 0_1512830107562_small_20171119_163849.jpg 0_1512830119867_small_20171119_164745.jpg 0_1512830130032_small_20171119_165717.jpg 0_1512830150237_small_20171203_092353.jpg 0_1512830159490_small_20171203_163658.jpg 0_1512830169403_small_20171207_194213.jpg
          so, it is ready. I mean ready to SW development :) both the schematic and pcb design is now confirmed and fortunately theory meets the practice :)
          it is assembled, programmed, tested, everything works as expected.
          I did not mount it to the wall so far (I'll need a controller and real actuators first), but there was no issue with the communication between two nrf modules (both with PCB antenna) from cca 6 meter distance + 2 walls (10 cm brick) in between.
          the touch panel's firmware will be enhanced as well as the controller's firmware, at the moment the touch sensing is reliable and a PoC code run on both of them for testing/debugging purposes. for the controller board I'm collecting additional information for the development on the following link:
          https://forum.mysensors.org/topic/8831/which-sensor-and-msg-type-for-switch-dimmer-node-sender-only
          jeremushkaJ
          jeremushkaJ
          jeremushka
          @andrew have you also designed the power board or do you reuse the livolo's one?
          andrewA 1 Reply Last reply
          • jeremushkaJ jeremushka
            andrewA
            andrewA
            andrew
            @jeremushka I reused the top PCB (the touch panel) with its original microcontroller, but with a custom firmware. the bottom PCB was fully replaced with my own designed version. this includes the power supply with additional protections, atmega328, atsha and nrf radio.
            it is running very well on my desk, but I was super busy in the past months so it is not yet installed to the wall.
            in parallel I also had to finish its opposite side, the controller at the lamp. it is also ready for final installation, I just need time for that :)
            • vladimirV
              vladimirV
              vladimir
              The other day I finished the first version of the PCB for my system of protection against water leakage. It will have two automatic ball valves, six leakage sensors with wire breakage monitoring and in the future I plan to connect it to the Mysensors.
              Here is a prototype collected with the help of Arduino Pro Mini. Arduino Uno is just nearby, but not connected. Do not pay any attention to him. :)
              • vladimirV vladimir
                zboblamontZ
                zboblamontZ
                zboblamont
                @vladimir I gather you meant motorised ball valves rather than automatic, the automation being on the processor.
                When you refer to leakage, is this to react to pipes potentially bursting or an external failure such as drainage failure in a cellar?
                vladimirV 1 Reply Last reply
                • zboblamontZ zboblamont
                  vladimirV
                  vladimirV
                  vladimir
                  @zboblamont Yes, it is, motorized ball valves.
                  I meant the reaction to the breakthrough of pipes or flexible connections of sanitary ware.
                    zboblamontZ
                    zboblamontZ
                    zboblamont
                    @vladimir Ok understood, washing machine hose failure or plumbing seals etc..
                    Had also considered incorporating leak detection after twice flooding out my bathroom (water softener cycle discharged externally normally - doesn't work so well at -20), ultimately solved by some overflow plumbing to internal drainage.
                    Still considering leak detection as a failsafe, but was looking at monitoring internal and external pressure and flow as well as conductivity at three separate areas. The idea was to similarly initiate shutdown of a motorised valve (for the entire house), or close down the supply pump for an external burst, so a little more complicated, but hence the curiosity.
                    For surface water detection I was looking at either fixed stainless stud contacts on the tiled floors, or mounting 3 on a plate like a tripod, as it should be more resistant to corrosion than standard rain sensor plates.
                    bjacobseB 1 Reply Last reply
                      bjacobseB
                      bjacobseB
                      bjacobse
                      @zboblamont
                      water leak/flooding detection,
                      I propose to get some stainless conductive wire, like this: https://www.adafruit.com/product/603
                      and then add 2 parallel wires on tape, and tape this to the floor, besides the dishwasher
                      • bjacobseB bjacobse
                        @zboblamont
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @bjacobse Interesting concept, and product, not so sure about the tape idea over a mechanical fix, the tape's behaviour in a wet or moist environment could prove unpredictable.
                        Tie/clamp this to a stud, or to a stainless rod projected to floor level might solve the corrosion issue with copper wire though....
                          vladimirV
                          vladimirV
                          vladimir
                          wrote on last edited by vladimir
                          #580
                          @zboblamont @bjacobse
                          I plan to make the leakage sensors waterproof, with outwardly exposed contacts made of stainless steel. I plan to lift the contacts 1-2mm from the floor so that when washing floors, when the floor is just a little wet sensor did not work. I really like the sensors from Xiaomi.
                          I ordered for the sample here are such cases from China:
                          1 - 31х10mm
                          2 - 61х20mm
                          • vladimirV
                            vladimirV
                            vladimir
                            The project of today is not yet connected with Mysensors.
                            This is a light relay with an IR receiver for the spotlight illuminating the backyard of my friends' house.
                            In the dark, the relay can be switched off from the remote control (to block the activation of the relay). If the remote is far away from you, then the lock can be removed with the searchlight switch by restarting it.
                            To understand if the relay is locked, there is a red LED on the case.
                            • sundberg84S
                              sundberg84S
                              #582
                              Anyone spots the differens? One booster draws 21mA sleeping and the other 13uA.
                              (I don't).
                              zboblamontZ NeverDieN 3 Replies Last reply
                                (I don't).
                                zboblamontZ
                                zboblamontZ
                                zboblamont
                                @sundberg84 Easy, one is disconnected... :joy: At 90 degrees? :stuck_out_tongue_winking_eye:
                                  (I don't).
                                  @sundberg84 Different SMD capacitors?
                                    (I don't).
                                    zboblamontZ
                                    zboblamontZ
                                    zboblamont
                                    @sundberg84 Which booster is this anyway it looks better made than many I've seen available ?
                                      sundberg84S
                                      sundberg84S
                                      @zboblamont its the one from mysensors store. I bought 10 and 8 of them is working.
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        #587
                                        Finally I finished my chicken coop door opening thingie :) A build that has taken way to much time to complete, and a few different directions.
                                        Just as I was ready to install the thing, I discovered that the DC motor that I had bought for this, couldn't lift the gate. So I had to go scrap hunting, to find a larger motor for it.. Luckily I had a 24V motor from a broken garageport opener which chould be used at 12V.
                                        Control box above the door, includes a PIR sensor in the lid.
                                        the gate, a sheet of 3mm black acrylic "glass". I had a couple of reed relays in the parts bin, so I use those to detect positions of the gate.
                                        The motor on is placed on the inside of the wall.
                                        Field update of the firmware.. Should probably reflash the bootloader, to mysboot, so I can do it OTA..
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          and of course a small video of the in action
                                          https://youtu.be/ABd86RK-Z4E
                                          YveauxY bjacobseB 2 Replies Last reply
