1.1k Posts 105 Posters 796.0k Views 98 Watching
  • bjacobseB bjacobse
    @zboblamont
    water leak/flooding detection,
    I propose to get some stainless conductive wire, like this: https://www.adafruit.com/product/603
    and then add 2 parallel wires on tape, and tape this to the floor, besides the dishwasher
    zboblamontZ
    zboblamontZ
    zboblamont
    @bjacobse Interesting concept, and product, not so sure about the tape idea over a mechanical fix, the tape's behaviour in a wet or moist environment could prove unpredictable.
    Tie/clamp this to a stud, or to a stainless rod projected to floor level might solve the corrosion issue with copper wire though....
    vladimirV 1 Reply Last reply
    • zboblamontZ zboblamont
      vladimirV
      vladimirV
      vladimir
      wrote on last edited by vladimir
      #580
      @zboblamont @bjacobse
      I plan to make the leakage sensors waterproof, with outwardly exposed contacts made of stainless steel. I plan to lift the contacts 1-2mm from the floor so that when washing floors, when the floor is just a little wet sensor did not work. I really like the sensors from Xiaomi.
      I ordered for the sample here are such cases from China:
      1 - 31х10mm
      2 - 61х20mm
      • vladimirV
        vladimirV
        vladimir
        The project of today is not yet connected with Mysensors.
        This is a light relay with an IR receiver for the spotlight illuminating the backyard of my friends' house.
        In the dark, the relay can be switched off from the remote control (to block the activation of the relay). If the remote is far away from you, then the lock can be removed with the searchlight switch by restarting it.
        To understand if the relay is locked, there is a red LED on the case.
        • sundberg84S
          sundberg84S
          #582
          Anyone spots the differens? One booster draws 21mA sleeping and the other 13uA.
          (I don't).
          zboblamontZ NeverDieN 3 Replies Last reply
          • sundberg84S sundberg84
            (I don't).
            zboblamontZ
            zboblamontZ
            zboblamont
            @sundberg84 Easy, one is disconnected... :joy: At 90 degrees? :stuck_out_tongue_winking_eye:
              (I don't).
              @sundberg84 Different SMD capacitors?
                (I don't).
                zboblamontZ
                zboblamontZ
                zboblamont
                @sundberg84 Which booster is this anyway it looks better made than many I've seen available ?
                  sundberg84S
                  sundberg84S
                  @zboblamont its the one from mysensors store. I bought 10 and 8 of them is working.
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    #587
                    Finally I finished my chicken coop door opening thingie :) A build that has taken way to much time to complete, and a few different directions.
                    Just as I was ready to install the thing, I discovered that the DC motor that I had bought for this, couldn't lift the gate. So I had to go scrap hunting, to find a larger motor for it.. Luckily I had a 24V motor from a broken garageport opener which chould be used at 12V.
                    Control box above the door, includes a PIR sensor in the lid.
                    the gate, a sheet of 3mm black acrylic "glass". I had a couple of reed relays in the parts bin, so I use those to detect positions of the gate.
                    The motor on is placed on the inside of the wall.
                    Field update of the firmware.. Should probably reflash the bootloader, to mysboot, so I can do it OTA..
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      and of course a small video of the in action
                      https://youtu.be/ABd86RK-Z4E
                      YveauxY bjacobseB 2 Replies Last reply
                      • tbowmoT tbowmo
                        @tbowmo smooth! :+1:
                        That should keep the foxes out :fox_face:
                        • tbowmoT tbowmo
                          bjacobseB
                          bjacobseB
                          bjacobse
                          @tbowmo Looks good
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            "funny" thing, that you first find all bugs after a more advanced node is deployed.. But after a couple of days debugging, with frequent firmware updates (opening the box, plugging in cables, and sitting with a laptop between all the chickens). I think that it is done now..
                            Firmware is here (if anyone is curios) https://github.com/tbowmo/chickenCoopFirmware
                            • Z
                              Z
                              zelen
                              Hi all!
                              Today I eventually built my first MySensors device - Serial Gateway.
                              Now I'm testing it with OpenHab and working on first node - battery powered scene controller.
                              • tbowmoT tbowmo
                                @bjacobse
                                I have been using influxdb/grafana for the last year or so, for logging data and presenting it, so no need to use domoticz for that. Over a year ago I injected nodered into the stream, so it sits between mysensors and domoticz, and was used to route things around (And make some fake sensors for domoticz).
                                For the dashboard part I have been developing my own solution. First it was running within domoticz as a customized dashboard, but I moved it to Angular instead, with a strong dependency towards domoticz, as I could query that to get sensor values. Lately I had moved on to use MQTT for the dashboard (and internal node-red data routing). There I can get persistent data (retain) that keeps the latest data on a given topic. Then my need for domoticz went away there..
                                The last thing I then used domoticz for, was the automation rules for turning on / off my tv when the chromecast was activated, and control a couple of LED strips according to the state of the chromecast (playing / paused etc). With that moved to nodered, then domoticz could be turned off.
                                The complete software stack is a bit larger, than with domoticz for everything, but it is much more flexible, than what I could achieve with domoticz.
                                also it brought in a couple of needed updates for my node-red mysensors nodes, so that was a "bonus" as well :)
                                chisightC
                                chisightC
                                chisight
                                wrote on last edited by chisight
                                #593
                                @tbowmo I've also been using MQTT and NodeRed as the routing solution for my home automation. I found that there was no default handling of ID_REQUEST messages which made configuring new nodes a manual process but eventually added that to my flows and now new nodes don't have to be configured at the Arduino end.
                                It would be nice to see more about your setup, more specifically about the dependencies in nodered-mysensors-flow/package.json on your github.
                                See me on IRC at ircs://freenode:6697/##nodered and ircs://freenode:6697/#mysensors
                                tbowmoT 1 Reply Last reply
                                • chisightC chisight
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @chisight
                                  Have you seen this thread: https://forum.mysensors.org/topic/9296/node-red-contrib-mysensors-release-thread ?
                                  Basically these set of nodes includes a controller node, that handles mysensors ID assignments, and a couple of other basic controller features.
                                  chisightC 1 Reply Last reply
                                  • tbowmoT tbowmo
                                    @chisight
                                    chisightC
                                    chisightC
                                    chisight
                                    @tbowmo I had seen that thread. After importing your https://github.com/tbowmo/nodered-mysensors-flow, I think this is probably quite different from my approach, I've kept it all as flows without writing any new node types or adding dependencies beyond what is installed in Raspbian by default. At some point I'll get around to documenting and posting what I've done in NodeRed too, it's a pretty simple but surprisingly powerful tool.
                                      chisightC
                                      chisightC
                                      chisight
                                      My Node Red controller is closer to what FotoFieber did a couple years back but it's for 2.3.0 and MQTT. His project is at https://forum.mysensors.org/topic/700/node-red-as-controller/28 as well as various updates over time. It was good to see @FotoFieber's code as it showed me a few holes in what I've done so far.
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        #597
                                        @chisight
                                        Well, node-red is powerful and you can do things without creating any new node-red nodes, but it makes life a lot easier (for me) when you can just pick an item from the palette, and hey-presto you have decoded the (serial/mqtt) mysensors message. Or pick another one, and you have a controller added, that can respond to ID requests.
                                        Btw. the the github repository that you link to, was a bit outdated.. :) A lot of things have happened since I pushed last time.. (just pushed current node-red flow for reference)
                                        • rozpruwaczR
                                          rozpruwaczR
                                          rozpruwacz
                                          So I finally finished my motion sensor project and it works :)
                                          It will be published on OpenHardware.io soon :)
                                          5_1532270542366_IMG_20180707_142708.jpg 4_1532270542366_IMG_20180707_142805.jpg 3_1532270542366_IMG_20180707_143013.jpg 2_1532270542366_IMG_20180707_143056.jpg 1_1532270542365_IMG_20180707_143127.jpg 0_1532270542364_IMG_20180708_110438.jpg
