  3. 💬 Sensebender Micro mk2
temperaturesensebendersamdhumidity
37 Posts 11 Posters 16.6k Views 12 Watching
  • bjornhallbergB
    bjornhallbergB
    bjornhallberg
    Could we do what Moteino has done and drop support for HW/W radios and opt for HCW/CW/RFM95/96/RFM12 using double sets of pads?
    https://lowpowerlab.com/shop/product/99
    Would be great if the community could settle on just one radio or a common way of doing things.
    • tbowmoT
      tbowmoT
      tbowmo
      @bjornhallberg it is on the todo list.. First pcb are using the RFM69(H)W footprint.. As I already have samples of that pcb.. (still need to assemble though)
      • E
        E
        evs
        Hi Thomas,
        I like this design! Can you please tell the status and your future plans for this design?
        EVS
        • tbowmoT
          tbowmoT
          tbowmo
          @evs
          Currently I have the first prototype pcbs without components, so need to make an order at mouser/digikey. This has been on my task list for the last couple of months though, as wife / kids have a lot of other projects for me during the summer time :)
          E 1 Reply Last reply
          • tbowmoT tbowmo
            @evs
            E
            E
            evs
            @tbowmo
            Thanks for the update. But without the time frame. what needs to be done to finish. Is there software for the SAMD processor?
            • tbowmoT
              tbowmoT
              tbowmo
              MySensors is already ported to samd21 so I expect things to be minor in order to get it up and running on samd20.
              I will probably change footprint for the rfm69 module to use one that is compatible with rfm95 as well. And some other minor changes as well
              • tbowmoT
                tbowmoT
                tbowmo
                A small update on this project, which I admit is taking longer than it should be (A lot of other projects has higher priority according to the wife)
                I finally got the first prototype assembled saturday evening, I can upload firmware (via jtag/swd), and I have a semi hacked arduino core, that can build. But when programming the samd20e with this core, and a simple sketch toggling an output pin, nothing happens.
                It seems that arduino halts in its initialization routine, waiting for some hardware to become ready after a reset, however I have not identified which part of the hardware yet.
                alexsh1A 1 Reply Last reply
                • tbowmoT tbowmo
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @tbowmo
                  Hi, any update on this please?
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    Sorry, I got caught up in a couple of other projects, so still haven't got the first prototype up and run nok :(
                    • tbowmoT tbowmo
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @tbowmo said in 💬 Sensebender Micro mk2:
                      Any luck with that at all? I really like they way the node is very small and with SAMD21
                      tbowmoT 1 Reply Last reply
                      • alexsh1A alexsh1
                        tbowmoT
                        tbowmoT
                        tbowmo
                        @alexsh1 bugger, I knew there where something that I had to do. The wife says that I have to finish the chicken coop automation first (opening / closing gates etc.).
                        • tbowmoT tbowmo
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @tbowmo ha ha ha - at least you are still married :)
                          12.5k
