  3. 💬 Sensebender Micro mk2
temperaturesensebendersamdhumidity
37 Posts 11 Posters 16.6k Views 12 Watching
    @tbowmo from what I understand, they are pin compatible.
    C and "non-C" are not pin compatible, but H and "non-H" are.
    Older discussion on a similar topic: https://forum.mysensors.org/post/60304
    tbowmoT
    tbowmoT
    tbowmo
    @mfalkvidd
    Check the datasheets, RFM69HCW has 16 pins, while RFM69CW only has 14 pins.
    At least when I looked at the datasheets a couple of hours ago
    • L lafleur
      Well, that news to me. I've always use the HCW variant and did NOT noticed the pin change. My error for not looking at the detail... (This was not the case with the RFM69W and HW radios, both shared the same pin-out)
      but again, using the HCW allow one to also use the RFM95 radios, and if you keep power below +13, power consumption is about the same... also the new RFM69 radio driver in 2.2b use adaptive power control as an option, this keep power use to a minimum saving power.
      I just re-checked the data sheets, RFM95 and RFM69HCW do share the same pin-out.
      tbowmoT
      tbowmoT
      tbowmo
      @lafleur
      Seems that you are right about the power consumption.. According to the datasheets, they use the same in receive mode, and when transmitting 13dBm.. So in theory it shouldn't do any harm on battery life..
      Well I'll see if I can incorporate it in the second prototype..
      • tbowmoT tbowmo
        @mfalkvidd
        @tbowmo said in 💬 Sensebender Micro mk2:
        @mfalkvidd
        Yes you are right. Sorry for the confusion.
        • bjornhallbergB
          bjornhallbergB
          bjornhallberg
          Could we do what Moteino has done and drop support for HW/W radios and opt for HCW/CW/RFM95/96/RFM12 using double sets of pads?
          https://lowpowerlab.com/shop/product/99
          Would be great if the community could settle on just one radio or a common way of doing things.
          • tbowmoT
            tbowmoT
            tbowmo
            @bjornhallberg it is on the todo list.. First pcb are using the RFM69(H)W footprint.. As I already have samples of that pcb.. (still need to assemble though)
            • E
              E
              evs
              Hi Thomas,
              I like this design! Can you please tell the status and your future plans for this design?
              EVS
              • tbowmoT
                tbowmoT
                tbowmo
                @evs
                Currently I have the first prototype pcbs without components, so need to make an order at mouser/digikey. This has been on my task list for the last couple of months though, as wife / kids have a lot of other projects for me during the summer time :)
                E 1 Reply Last reply
                • tbowmoT tbowmo
                  @evs
                  E
                  E
                  evs
                  @tbowmo
                  Thanks for the update. But without the time frame. what needs to be done to finish. Is there software for the SAMD processor?
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    MySensors is already ported to samd21 so I expect things to be minor in order to get it up and running on samd20.
                    I will probably change footprint for the rfm69 module to use one that is compatible with rfm95 as well. And some other minor changes as well
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      A small update on this project, which I admit is taking longer than it should be (A lot of other projects has higher priority according to the wife)
                      I finally got the first prototype assembled saturday evening, I can upload firmware (via jtag/swd), and I have a semi hacked arduino core, that can build. But when programming the samd20e with this core, and a simple sketch toggling an output pin, nothing happens.
                      It seems that arduino halts in its initialization routine, waiting for some hardware to become ready after a reset, however I have not identified which part of the hardware yet.
                      alexsh1A 1 Reply Last reply
                      • tbowmoT tbowmo
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @tbowmo
                        Hi, any update on this please?
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          Sorry, I got caught up in a couple of other projects, so still haven't got the first prototype up and run nok :(
                          • tbowmoT tbowmo
                            alexsh1A
                            alexsh1A
                            alexsh1
                            Any luck with that at all? I really like they way the node is very small and with SAMD21
                            tbowmoT 1 Reply Last reply
                            • alexsh1A alexsh1
                              tbowmoT
                              tbowmoT
                              tbowmo
                              @alexsh1 bugger, I knew there where something that I had to do. The wife says that I have to finish the chicken coop automation first (opening / closing gates etc.).
                              • tbowmoT tbowmo
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @tbowmo ha ha ha - at least you are still married :)
                                12.5k
