1.1k Posts 105 Posters 796.0k Views 98 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    #597
    @chisight
    Well, node-red is powerful and you can do things without creating any new node-red nodes, but it makes life a lot easier (for me) when you can just pick an item from the palette, and hey-presto you have decoded the (serial/mqtt) mysensors message. Or pick another one, and you have a controller added, that can respond to ID requests.
    Btw. the the github repository that you link to, was a bit outdated.. :) A lot of things have happened since I pushed last time.. (just pushed current node-red flow for reference)
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      So I finally finished my motion sensor project and it works :)
      It will be published on OpenHardware.io soon :)
      5_1532270542366_IMG_20180707_142708.jpg 4_1532270542366_IMG_20180707_142805.jpg 3_1532270542366_IMG_20180707_143013.jpg 2_1532270542366_IMG_20180707_143056.jpg 1_1532270542365_IMG_20180707_143127.jpg 0_1532270542364_IMG_20180708_110438.jpg
      • rozpruwaczR
        rozpruwaczR
        rozpruwacz
        And also finished my toolkit library for MySensors for faster code developement (https://github.com/mczerski/MySensorsToolkit). Example projects (https://github.com/mczerski/MyMultiSensor).
        • rozpruwaczR rozpruwacz
          @rozpruwacz nice & small motion sensor, good work!
          Where did you get the swivel to mount it to the wall?
          • rozpruwaczR
            rozpruwaczR
            rozpruwacz
            @Yveaux I get it from the polish suplier (https://hurtowniaimport.pl/291-bb1-uchwyt-magnetyczny-samochodowy-do-telefonu-gps.html) but if you google for "magnetic phone holder 360" You wil get similar mounts.
            • rozpruwaczR
              rozpruwaczR
              rozpruwacz
              I found one on aliexpress: https://pl.aliexpress.com/item/GETIHU-360-Car-Magnetic-Phone-Holder-For-Phone-in-Car-Mount-Magnet-Universial-Mobile-Cell-Phone/32879720933.html?spm=a2g17.search0104.3.244.101611774LZhtS&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10151_10065_10344_10068_10342_10343_10340_10341_10696_10084_10083_10618_10304_10307_10820_10821_10301_10843_10059_100031_10103_10624_10623_10622_10621_10620,searchweb201603_1,ppcSwitch_2&algo_expid=17a12b56-7a20-49df-aab1-45b5519746f0-29&algo_pvid=17a12b56-7a20-49df-aab1-45b5519746f0&priceBeautifyAB=0
              • mfalkviddM
                Today I soldered the Velleman EDU09 oscilloscope kit. The kit is quite cheap (~50 EUR in local store). The specs aren't impressive (max 200kHz and min 100mV/division) but hopefully it can help me learn how to use a scope before I buy a real one.
                alexsh1A 1 Reply Last reply
                • tbowmoT
                  tbowmoT
                  tbowmo
                  Not at all mysensors related, but I have been busy building a bartop mame cabinet the last week or so.. Still mis a couple of details, but it is in a "playable" state right now.
                  The setup is using an old 19" lcd monitor that I had in surplus with a RPI-3B on the back, a couple of cheap Chinese arcade controllers, a partly homebuild audio hat for the rpi (adafruit i2s 3W amplifiers), and a switchmode capable of 5V @8A (if I remember right), and 12V @3A. So I have power for the marque lighting as well..
                  Only game available right now is Bubble Bobble, and the kids loves it (as seen in the video linked to below).
                  https://youtu.be/h_6FebqefcQ
                  • bjacobseB
                    bjacobseB
                    bjacobse
                    @tbowmo
                    Quite impressive arcade game
                      For this project box that I'm making (actually printing it as I type this), I found an easy way to add ventilation: use a hex infill and turn off the upper and bottom layers.
                      As you can see, it can still have standoffs for screwing down a PCB and for securing a lid.
                        Here's the finished unit:
                        What it does is completely eliminate the audible PWM noise from the fan on the Prusa I3 MK3. Now it can run practically silent. :)
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @mfalkvidd Just a tip. You may be better of buying this one:
                          https://www.amazon.co.uk/KKmoon-Portable-Digital-Oscilloscope-Interface/dp/B07C4RTXF6/ref=sr_1_3?ie=UTF8&qid=1534094879&sr=8-3&keywords=oscilloscope+portable
                          Much better spec and the price is the same. AND you can save tons of time as it does not require soldering.
                          • tbowmoT tbowmo
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @tbowmo Now I want to build one :-)))
                            tbowmoT 1 Reply Last reply
                            • alexsh1A alexsh1
                              @alexsh1 thanks for the tip. I guess I'll have a hard time getting my money and time back now that the kit is soldered, but it might be interesting for someone else.
                              • alexsh1A alexsh1
                                tbowmoT
                                tbowmoT
                                tbowmo
                                @alexsh1
                                I used this as a base for my own build: https://www.instructables.com/id/2-Player-Bartop-Arcade-Machine-Powered-by-Pi/
                                • kalinaK
                                  kalinaK
                                  kalina
                                  LED backlight for my CNC machine....
                                  • mfalkviddM
                                    #613
                                    Today I've been trying to get a MS5803_05BA sensor working. This is a pressure sensor that is commonly used in dive computers.
                                    The sensor is tiny and handles 0-5 bar. So far I've not been able to communicate with it though. I use i2c and have tried two libraries, but none of them work (or maybe I killed the sensor when I soldered the cable).
                                    • mfalkviddM
                                      At first I had a 25m cable. Turns out i2c isn't designed for that. It is designed for ~1m at 100kHz and ~10m at 10kHz. ESP8266 defaults to 400kHz and can't go lower than 50kHz without modifying the ESP8266 core files.
                                      I got my first use case for the oscilloscope I built.
                                      This was the signal at the start of the cable:
                                      This was the signal at the end of the cable:
                                      So no surprise that the communication didn't work.
                                      I tried with a 2k pullup:
                                      Much better! But still not very good.
                                      I modified the library to use 7.5kHz:
                                      Better again, but still not great. I lowered the speed to 0.75kHz:
                                      Nice and clean!
                                      But communication still didn't work so I decided to cut the cable (to the 10cm length seen above) and restore all my changes. But communication still doesn't work.
                                      I bought the sensor from a reputable distributor in UK so I don't think I got a faulty sensor. But I don't seem to get any life signs at all from it. I tried an i2c scan sketch and it found nothing.
                                        Nice and clean!
                                        @mfalkvidd shot in the dark ; do you pull the PS pin high to select i2c protocol?
                                        • YveauxY Yveaux
                                          #616
                                          @yveaux yes I do. I took the easy way: soldered the 3.3V wire to pads 5 and 6 at the same time.
                                          And I have tried putting a 104 ceramic capacitor between 3V3 and GND right next to the sensor.
                                          CSB is connected to GND.
                                          My next step is either to see if I can get SPI working (instead of i2c), or order a new sensor. But first sleep.
