716 Posts 111 Posters 703.1k Views 93 Watching
  • Z
    Z
    zelen
    I ordered 10 PCBs using "Order from PCBWay" button. It only asked me about PayPal card and din't require any registration on PCBWay. So, everything looks good, PayPal transaction is completed. Can somebody tell me please how can I track it? Probably I'm missing tracking option somewhere... Thank you!
    P.S.
    Cant wait to try it out. :)
    • Z zelen
      P.S.
      sundberg84S
      sundberg84S
      @zelen I'm not sure. You didn't receive any email? I normally get a email once they are finished and shipped with tracking.
      Z 1 Reply Last reply
      • Z
        Z
        zelen
        • sundberg84S sundberg84
          Z
          Z
          zelen
          @sundberg84 thank you for clarification. I expected email right after making an order. So, I will wait for finishing production and shipment.
          • H
            H
            Harrdy
            I use some of old rev8 boards. I have noticed that I use a ceramic capacitor instead of an electric capacitor compared to the images for the battery measurement. Does it matter? Or should I replace the ceramic capacitor (104) with an electric capacitor?
            sundberg84S gohanG 2 Replies Last reply
            • H Harrdy
              sundberg84S
              sundberg84S
              @harrdy should work just fine.
              • H Harrdy
                @harrdy remember to take a few readings and average out the battery value
                • manosM
                  manosM
                  manos
                  Hello @sundberg84, I would like to buy the Easy/Newbie PCB for MySensors but I have a few questions
                  I want to use it the 5V Arduino Pro mini not the 3V version
                  I also want to use the battery monitor
                  Is it ok or should I modify "something"
                  Also all the pcbs have the battery "expansion: or not?
                  Thanks, Emmanuel
                    Why would you want to use the 5v arduino on batteries?
                    • manosM manos
                      Thanks, Emmanuel
                      sundberg84S
                      sundberg84S
                      @manos
                      Then you need to use the nrf24l01+ version, that works fine - the RFM69 version needs a 3.3v Pro Mini only.
                      As @gohan said - don't use batteries on a 5v node. Use a 3.3v because it will use up your batteries very quickly. See the guides i have on openhardware for different modes on my PCB.
                      "something" is hard to understand, you can modify i many different ways depending on what you want to do. All the basic "modifications" can be found if you read the project page on openhardware.io
                      manosM 1 Reply Last reply
                        @manos
                        manosM
                        manosM
                        manos
                        @sundberg84 thanks for your response
                        If I don't care about battery consumption can I still view and use the battery monitor to be alarmed when battery is empty?
                        • manosM manos
                          sundberg84S
                          sundberg84S
                          @manos yes you can.
                          • T
                            thorcyar
                              Mister_ik
                              Hello @sundberg84. I watched your video 9+ 'MySensors Battery Node 2xAA - EasyPCB (Nrf24l01+)and Temp Sensor' . I have two questions about this video:
                              • I noticed you connected the tempsensor to the extra prototype part of the board, but i could not see in the video how you connected signal pin of the sensor to the arduino.
                              • you added a resistor to D5 Temp/Hum, but you did not add the sensor to the mysX2.4 part of the board. Why is that?
                              • M Mister_ik
                                sundberg84S
                                sundberg84S
                                #603
                                @mister_ik said in 💬 Easy/Newbie PCB for MySensors:
                                I connect it on the back with a normal wire to D5 resistor input. So both of your observations above are correct.
                                  Mister_ik
                                  @sundberg84 yes i thought so, but i want to make sure. I have some Rev 10 boards and i was working on a node for my bathroom with a DHT11 sensor. I had some problems with it, therefore watching your video. But it looks like the step up booster was not working correctly. Unfortunately removing the booster i damaged the board because with a new booster the arduino won't get power any more. So this board only works without the booster (and reg jumper connected). Any idea how long this setup (with removed led on arduino) will last on batteries?
                                  • M Mister_ik
                                    sundberg84S
                                    sundberg84S
                                    #605
                                    @mister_ik - well, 2-4 weeks more or less unless you reprogram the fuses and bootloader.
                                      Mister_ik
                                      @sundberg84 ooh that is not very long ..i hoped for a couple of months....but then I should consider this board as depreciated and build a new one and use this for development. Thanks for your reaction.
                                      • M Mister_ik
                                        sundberg84S
                                        sundberg84S
                                        @mister_ik you can always use wired to repair the damaged tracks.
                                        • A
                                          ajay100
                                          wrote on last edited by ajay100
                                          #608
                                          @sundberg84, thanks so much for this board, I bought 10 of them. This has made my sensor projects much easier and they look better too! I think I will get some of the RFM69 version next.
                                          I have a lot of gel lead acid batteries (the 7.2AH type often used in UPSs), and I have been running an earlier prototype off that. I have now just changed over to your board and this is how I modified it to work the way I wanted:
                                          • Cut the track circled
                                          • Hard wired from the regulator side of the battery jumper to VCC on the Pro Mini
                                          • Bridged the booster In to Out
                                          • Changed the battery measuring resistors to 12k/180k for greater range
                                          This enabled me to run the board off 12V, keep an eye on the battery voltage, and run the rest from the LE33 regulator. It seems to be managing so far, with 3 x DS18B20 temperature sensors. I'm monitoring the fridge outside, inside and freezer temperatures with this module.
