716 Posts 111 Posters 703.1k Views 93 Watching
  • H Harrdy
    I use some of old rev8 boards. I have noticed that I use a ceramic capacitor instead of an electric capacitor compared to the images for the battery measurement. Does it matter? Or should I replace the ceramic capacitor (104) with an electric capacitor?
    sundberg84S
    sundberg84S
    @harrdy should work just fine.
    • H Harrdy
      @harrdy remember to take a few readings and average out the battery value
      • manosM
        manosM
        manos
        Hello @sundberg84, I would like to buy the Easy/Newbie PCB for MySensors but I have a few questions
        I want to use it the 5V Arduino Pro mini not the 3V version
        I also want to use the battery monitor
        Is it ok or should I modify "something"
        Also all the pcbs have the battery "expansion: or not?
        Thanks, Emmanuel
          Why would you want to use the 5v arduino on batteries?
          • manosM manos
            Thanks, Emmanuel
            sundberg84S
            sundberg84S
            @manos
            Then you need to use the nrf24l01+ version, that works fine - the RFM69 version needs a 3.3v Pro Mini only.
            As @gohan said - don't use batteries on a 5v node. Use a 3.3v because it will use up your batteries very quickly. See the guides i have on openhardware for different modes on my PCB.
            "something" is hard to understand, you can modify i many different ways depending on what you want to do. All the basic "modifications" can be found if you read the project page on openhardware.io
            manosM 1 Reply Last reply
            • sundberg84S sundberg84
              @manos
              manosM
              manosM
              manos
              @sundberg84 thanks for your response
              If I don't care about battery consumption can I still view and use the battery monitor to be alarmed when battery is empty?
              • manosM manos
                sundberg84S
                sundberg84S
                @manos yes you can.
                • T
                  thorcyar
                    Mister_ik
                    Hello @sundberg84. I watched your video 9+ 'MySensors Battery Node 2xAA - EasyPCB (Nrf24l01+)and Temp Sensor' . I have two questions about this video:
                    • I noticed you connected the tempsensor to the extra prototype part of the board, but i could not see in the video how you connected signal pin of the sensor to the arduino.
                    • you added a resistor to D5 Temp/Hum, but you did not add the sensor to the mysX2.4 part of the board. Why is that?
                    • M Mister_ik
                      sundberg84S
                      sundberg84S
                      #603
                      @mister_ik said in 💬 Easy/Newbie PCB for MySensors:
                      I connect it on the back with a normal wire to D5 resistor input. So both of your observations above are correct.
                        Mister_ik
                        @sundberg84 yes i thought so, but i want to make sure. I have some Rev 10 boards and i was working on a node for my bathroom with a DHT11 sensor. I had some problems with it, therefore watching your video. But it looks like the step up booster was not working correctly. Unfortunately removing the booster i damaged the board because with a new booster the arduino won't get power any more. So this board only works without the booster (and reg jumper connected). Any idea how long this setup (with removed led on arduino) will last on batteries?
                        • M Mister_ik
                          sundberg84S
                          sundberg84S
                          #605
                          @mister_ik - well, 2-4 weeks more or less unless you reprogram the fuses and bootloader.
                            Mister_ik
                            @sundberg84 ooh that is not very long ..i hoped for a couple of months....but then I should consider this board as depreciated and build a new one and use this for development. Thanks for your reaction.
                            • M Mister_ik
                              sundberg84S
                              sundberg84S
                              @mister_ik you can always use wired to repair the damaged tracks.
                              • A
                                ajay100
                                wrote on last edited by ajay100
                                #608
                                @sundberg84, thanks so much for this board, I bought 10 of them. This has made my sensor projects much easier and they look better too! I think I will get some of the RFM69 version next.
                                I have a lot of gel lead acid batteries (the 7.2AH type often used in UPSs), and I have been running an earlier prototype off that. I have now just changed over to your board and this is how I modified it to work the way I wanted:
                                • Cut the track circled
                                • Hard wired from the regulator side of the battery jumper to VCC on the Pro Mini
                                • Bridged the booster In to Out
                                • Changed the battery measuring resistors to 12k/180k for greater range
                                This enabled me to run the board off 12V, keep an eye on the battery voltage, and run the rest from the LE33 regulator. It seems to be managing so far, with 3 x DS18B20 temperature sensors. I'm monitoring the fridge outside, inside and freezer temperatures with this module.
                                • A
                                  ajay100
                                  • A ajay100
                                    sundberg84S
                                    sundberg84S
                                    #610
                                    @ajay100 - Hi!
                                    Really nice to see you found your way of using my PCB, its just the way I want it :)
                                    I tried to follow along here, are you using the LEd33 to convert 12v to 3.3v? I guess you tried RAW and the voltage regulator on your pro mini and found out it was bad due to cheap clones?
                                    If you cut the trace just above the volt.reg and put a jumper from REG to Vin on the Volt reg, and added a jumper from Bat (top) to Reg (top) you would also feed everything with whatever comes out from the LE33.
                                    A 1 Reply Last reply
                                      @ajay100 - Hi!
                                      ajay100
                                      @sundberg84, I've just tried it and that is a better solution than mine for running everything from the LE33. Thanks for taking the time to work that out!
                                      Cheers - Andrew
                                      • D
                                        dakipro
                                        Hey @sundberg84 I just saw the new rev.10, congratulations on the upgrade!
                                        I still have a bunch of rev 9, do you happen to have images/manual for previous version somewhere? link or a pdf?
                                        • D dakipro
                                          sundberg84S
                                          sundberg84S
                                          @dakipro - sorry, everything was saved here on oh.
                                          Is there something special you need? I can maybe send it to you, like schematics or what are you looking for?
