  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 33.9k Views 2 Watching
    samppa
    wrote on last edited by samppa
    I have been searching for the easiest graphing solution to see how sensor data behaves and I think I have found it - at least it looks promising.
    After creating plot.ly account create API key in https://plot.ly/settings/api
    Then create scene with following luup that makes the REST API request to upload new the value into the plot.
    So the example here is that I record time series one data point at a time and trigger the scene with 5 minute interval schedule,
    Replace <username>, <APIKey>, <nameForGraph> and <graphTitle> below with your (hard coded) values and the datavelue is of course the sensor data that you want to plot (I plot humidity).
    LUUP CODE:
    local datavalue = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1", "CurrentLevel", 83)
    local http = require("socket.http")
    http.TIMEOUT = 5
    local ts = os.date("%Y-%m-%d %X")
    result, status = http.request("https://plot.ly/clientresp",'un=<username>&key=<APIKey>&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..datavalue..']}]&kwargs={"filename":"<nameForGraph>","fileopt":"extend","style":{"type":"scatter"},"traces":[0],"layout":{"title":"<graphTitle>"},"world_readable":false}')
    S 1 Reply Last reply
    • S samppa
      LUUP CODE:
      http.TIMEOUT = 5
      samppa
      Next I would like to plot a value from PLEG condition. But can those be accessed from scene luup code?
      • NuubiN
        NuubiN
        Nuubi
        Excellent, thanks! This is much needed.
        For some reason, can't get this to work...LUA error.
        I'm trying to send MySensors data to Plotly...
        Anyway, does e.g. <username> mean that you write username, or <username> to the script? (Oh yeah, username referring to the actual username :-) )
        • NuubiN Nuubi
          samppa
          @Nuubi
          Yes, the username and API key are shown on the plot.ly api settings page.
          Here is my code that works for 5 lines in one graph and appends data every 5 minutes:
          -- Get variables
          local BRHum = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1", "CurrentLevel", 83)
          local BRTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 84)
          local ACBoost = 100 * luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 106)
          local ACMech = 100 * luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 107)
          local ACEff = luup.variable_get("urn:upnp-org:serviceId:Dimming1", "LoadLevelStatus", 88    )
          -- Send to plot
          http.TIMEOUT = 5
          result, status = http.request("https://plot.ly/clientresp",'un=<username>&key= <APIKey>&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..BRHum..'],"name":"Humidity"},{"x":["'..ts..'"],"y": ['..ACBoost..'],"name":"AC Boost"},{"x":["'..ts..'"],"y":['..BRTemp..'],"name":"Temperature"},{"x":["'..ts..'"],"y":['..ACMech..'],"name":"Mech Sensor"},{"x":["'..ts..'"],"y":['..ACEff..'],"name":"AC Efficiency"}]&kwargs={"filename":"BathroomHumidity","fileopt":"extend","style":{"type":"scatter"},"traces":[0,1,2,3,4],"layout":{"title":"Bathroom Humidity"},"world_readable":false}')
          I know the JSON syntax is cryptic in one line without pretty formatting..
          • korttomaK
            korttomaK
            korttoma
            @samppa this is sweet :+1: . Thank you so much for sharing this!
            • Tomas
            • NuubiN
              NuubiN
              Nuubi
              Uh...oh...still.. do you need to initialize the graph or what? Still not getting this to work, sorry for being such a dummie :-E
              • korttomaK
                korttomaK
                korttoma
                You should use username and not <username>. The same goes for the API key.
                In UI5 you can test your Lua in Vera from APPS -> Develop Apps -> Test Luup code
                Here is a few more examples of variable_get:
                local InAirHum = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1", "CurrentLevel", 347)
                local OutTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 229)
                local InAirTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 346)
                local InAirQ = luup.variable_get("urn:upnp-org:serviceId:VContainer1", "Variable1", 348)
                • Tomas
                • korttomaK
                  korttomaK
                  korttoma
                  I'm having trouble with one variable to. I would like to have the status of a qubino switch in the same graph.
                  I tried this:
                  local VentOn = 100 luup.variable_get("urn:upnp-org:serviceId:BinaryLight1", "Status", 356)
                  It gives me the value 100 in the graph. Please let me know what this 100 in front of the luup.variable_get does. If I remove it the Luup code fails.
                  • Tomas
                  • korttomaK korttoma
                    I tried this:
                    samppa
                    I tried this:
                    Actually there should be asterisk character between 100 and the luup.variable_get and the (forum editor does not show that) since the returned value 1 or 0 is scaled to 100 so try:
                    local VentOn = 100 * luup.variable_get("urn:upnp-org:serviceId:BinaryLight1", "Status", 356)
                    Then you get 100 if binary light is on. Remove the 100 if you like it to be 1 or 0.
                    korttomaK 1 Reply Last reply
                    • NuubiN Nuubi
                      samppa
                      You just send the data and the graph named with "filename":"xxxx" gets created if not yet existing.
                      NuubiN 1 Reply Last reply
                      • S samppa
                        I tried this:
                        korttomaK
                        korttomaK
                        korttoma
                        I thought it was a multiplier of some kind. Anyhow the code fails allso if I add the asterisk so I thik it has a problem with:
                        Any suggestions what I should try instead? Tried also this but no luck:
                        luup.variable_get("urn:micasaverde-com:serviceId:BinaryLight1", "Status", 356)
                        • Tomas
                        • korttomaK
                          korttomaK
                          korttoma
                          Had a chat with @BulldogLowell and he taught me that you can hover the mouse on a variable to check the complete variable name so it turned out I had to use the following:
                          luup.variable_get("urn:micasaverde-com:serviceId:SwitchPower1", "Status", 356)
                          • Tomas
                          • S samppa
                            NuubiN
                            NuubiN
                            Nuubi
                            @samppa Yep, works now, thanks!
                            The problem turned out to be the actual value I wanted to send. Need to figure out how to read MySensors based values in LUA...
                            • NuubiN Nuubi
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              @Nuubi
                              have you tried luup.inet.wget( )
                              local brightness = luup.variable_get("urn:upnp-org:serviceId:Dimming1", "LoadLevelStatus", 118)
                              luup.inet.wget("192.168.1.50//?brightLevel="..brightness.."&", 1)
                              • korttomaK
                                korttomaK
                                korttoma
                                Anyone figured out a way to add another variable to an old graph without deleting the file from plot.ly? Seems like it does not include the new variable unless you delete and create a new file.
                                • Tomas
                                  samppa
                                  I have noticed the same thing; If you want to add a trace you need to delete the file..
                                  So perhaps it is wise to be prepared and add a few extra traces for some future use.
                                  • S samppa
                                    korttomaK
                                    korttomaK
                                    korttoma
                                    Good suggestion for a workaround but it does not seem to pick up name changes for the trace either. Tried also to edit one of the plots on the website but when I wanted to save I could not save the changes to the file used by "Vera". I had to save the file with a different name so no editing seems to be possible.
                                    • Tomas
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      Since the nightly heal at 2 in the morning no data is transferred to plot.ly any more :( anyone else see this and know how to solv it?
                                      • Tomas
                                      DwaltD 1 Reply Last reply
                                        DwaltD
                                        DwaltD
                                        Dwalt
                                        @korttoma
                                        My plots stopped last night as well, last data point transmitted was at 12:03am GMT, but not after a nightly heal.
                                        -Dwalt
                                        • korttomaK
                                          korttomaK
                                          korttoma
                                          12 GMT is 2 in my timezone so I guess it was just a coincidence that it happened at the time of the heel. Maybe plot.ly blocked us for some reason.
                                          • Tomas
