  3. CDEBYTE's new NRF24 modules are great! (and cheap)
36 Posts 8 Posters 12.3k Views 7 Watching
  • alowhumA Offline
    alowhumA Offline
    alowhum
    I bought and tested one of these new small modules:
    https://www.aliexpress.com/item/E01-ML01D-small-size-SPI-nRF24L01P-2-4Ghz-1mW-PCB-antenna-IOT-uhf-wireless-transceiver-transmitter/32803704874.html
    • Smaller
    • Thinner
    • Works at full power
    • Claim to use real imported NRF chips
    • $1,25
    I've also ordered a shielded version that I'm still waiting for.
    Perhaps the website can reflect some of the newer options?
    • These small parts (but perhaps the shielded alternative will be even better)
    • Shielded NRF24 PA high power version. Very nice too. No need to wrap aluminium foil around them :-)
    mfalkviddM ร 2 Replies Last reply
    • alowhumA alowhum
      • Smaller
      • Thinner
      • $1,25
      @alowhum said in CDEBYTE's new NRF24 modules are great! (and cheap):
      Thanks for verifying that they work. Could you clarify what you mean by reflecting the newer options?
      The link you provided has been listed on https://www.mysensors.org/build/connect_radio for some time already. Is there anything else we can do?
      Y 1 Reply Last reply
        Y Offline
        Y Offline
        @mfalkvidd from my own experience with ebyte modules I would say they are superior compared to the no-name ones.
        The nrf signature (power, inverted ack bit, rf spectrum) compares to genuine nordic modules so the ebyte claim that they use original nordic modules looks to be valid.
        Furthermore the red modules referred to by @alowhum are very small, have good build quality and a low power resonator which makes them a perfect fit for battery powered applications.
        The mySensors community would profit from a supplier offering good radios at a decent price. IMHO Ebyte currently is the best (only?) supplier matching these criteria, so I would vote to only mention their modules in the build section.
        Hopefully this will help (new) users to start using high quality modules and prevent a lot of frustration caused by poor quality hardware.
        • alowhumA Offline
          alowhumA Offline
          alowhum
          @mfalkvidd Ah, I didn't realise they were already on the website. Great!
          Perhaps you could also add these wonderful boards to the build page, and mention them as the preferred solution for beginners? I build everything with these now.
          • No fiddling with 8 cables when you want to connect the radio
          • Stable power for the radio
          • No more soldering on extra 5v and ground pins to the nano
          https://www.aliexpress.com/item/Nano-328P-IO-Wireless-Sensor-Expansion-Board-for-XBEE-and-NRF24L01-Socket-for-arduino-Diy-Kit/32264665470.html
          • skywatchS Offline
            skywatchS Offline
            skywatch
            I have many "CDEBYTE" modules, the red ones,smd ones and the pa/lna ones.
            They all work very well, no problems at all (even the one that got 5V for 30 seconds by mistake ;-) ).
            But as far as I can tell they don't claim that their boards contain nordic manufactured chips - they say that their designs are 'based on' original nordic chips, but not 'using' them per se.
            Maybe they are just superior clones, but they are working well and cheap, so I am not too worried :)
            • alowhumA Offline
              alowhumA Offline
              alowhum
              @skywatch I could have sworn that I read "imported chips" on their website the other day.
              @mfalkvidd
              I've also ordered this board:
              https://www.aliexpress.com/item/Wireless-Rapspberry-Pie-Rpi-Shield-Board-For-Raspberry-Pi-Support-Zigbee-Xbee-NRF24L01-NRF24L01-RFM12B-D/32858434375.html
              Once I've tested it I'll let you know. It might then also be useful to mention on the Raspberry Pi Controller page, ideally as the 'default' option.
              • alowhumA alowhum
                @alowhum which "build page" are you referring to?
                • skywatchS Offline
                  skywatchS Offline
                  skywatch
                  @alowhum You may be correct on this as they have changed the photos and description in the last month or so - it now says components "Imported from Japan, USA & Germany" and then 'original nordic imported' - So that is clearer than it was before.
                  • S Offline
                    And for those who likes ebay: https://www.ebay.com/itm/Ebyte-E01-ML01D-100m-nRF24L01-2-4GHz-SPI-wireless-transmitter-receiver-module/191974998709?hash=item2cb29a02b5:g:gzcAAOSwKflZN7Al
                    skywatchS 1 Reply Last reply
                    • S sundberg84
                      skywatchS Offline
                      skywatchS Offline
                      skywatch
                      @sundberg84 That's nearly twice the price of ali!
                      FWIW I checked my orders, earlier this year they were $2.24each. They had the ML01D screen printed on them.
                      Now they are $1.42 each, they are a different colour red and have no screen printing on the back.
                      • skywatchS skywatch
                        @skywatch using a smd capacitor like that is a clever and clean solution to placing the capacitor close to the chip. Thanks for sharing! I'll do that in the future instead of messing with the big electrolycic cans.
                        skywatchS S 2 Replies Last reply
                          skywatchS Offline
                          skywatchS Offline
                          skywatch
                          @mfalkvidd Thank you! - If I had known I would have used one with better soldering for the photo It was just to show that the newer cheaper ones were not identical to the original ones they sold a few months ago.
                          I use either 1206 or 0805 ceramic multilayer capacitors, 47uF, 6.3V. All nrf's get this treatment before use. A jewellers eyepiece is good for checking the joints and I solder them by hand but it needs a pair of tweezers or fine pliers.
                            @mfalkvidd would be interesting which perform best, smd cheramic or electrolytic cap... now when you are thinking about a new oscilloscope ;)
                            • nitroburnN Offline
                              nitroburnN Offline
                              nitroburn
                              There are two stores that manufacturer the same modules. Often the prices will differ between the two so you're best off comparing which one is less expensive. CDSNET
                              https://www.aliexpress.com/store/product/omg-a-few-cents/2798183_32807273986.html
                              store link: https://www.aliexpress.com/store/2798183
                              Same board, 2c less right now. It is too bad they no longer do their insane, I have no idea why they were so low, price sales anymore. Happened the same time as an EBates 10% back Not that I need any more of their products. I have way too many modules from them already (100s), but 75% off was hard to pass up. items quantities were limited but they seem to reset the sale so often I just placed a ton of orders whenever it let me. Many NRF52832 modules were acquired this way.
                              but if your already shopping AliExpress, I hope you're using eBates on top of that.
                              USA eBates (note, I use this from Canada if greater cashback before or after exchange. ie, both are 3% right now, but USD>CAD): http://bit.ly/eBatesDotCom
                              Canada eBates: http://bit.ly/eBatesDotCa
                              There are often 10% back offered.
                              • alowhumA Offline
                                alowhumA Offline
                                alowhum
                                Too bad they're not so cheap anymore..
                                • alowhumA alowhum
                                  skywatchS Offline
                                  skywatchS Offline
                                  skywatch
                                  @alowhum You are right! - That is some inflation they have in China! ;)
                                  I got a load in August for $1.42 each. Now $3.50 - $3.89. What the .....?
                                    at that price it is worth to switch to rfm69
                                    • alowhumA alowhum
                                      • Smaller
                                      • Thinner
                                      • $1,25
                                      ร Offline
                                      ร Offline
                                      รอเรือ
                                      Today, I've tried the unshielded one and the few that I've tried seem to work.
                                      However, I haven't been able to make the shielded one work on a IO Shield for Arduino Nano. I've used antennas from older traditional NRF24L01+PA+LNA Antenna version. No way. I will try different decoupling-Capacitors tomorrow.
                                      I feel I'm stuck in the NRF24-hell...
                                      • ร รอเรือ
                                        Y Offline
                                        Y Offline
                                        @รอเร-อ said in CDEBYTE's new NRF24 modules are great! (and cheap):
                                        What's the issue? Is the module not responding to arduino commands or are transmissions /receptions failing?
                                        • Y Yveaux
                                          ร Offline
                                          ร Offline
                                          รอเรือ
                                          @yveaux I'll investigate further today and report here afterwards. Thanks.
