  3. nRF5 action!
nRF5 action!
    #1662
    I guess maybe in your case the next best alternative would be the Fanstel nRF52840 modules, which should be drop-in upgrades to whatever PCB designs you may have had that used the Fanstel nRF52832 modules. I had previously posted a few:
    https://www.openhardware.io/view/499/10-years-wireless-PIR-Sensor-on-just-one-set-of-3-AAs
    https://www.openhardware.io/view/491/PA-LNA-nRF52832-ESP-LINK-Shield-for-Wemos-D1-Mini-ESP8266
    https://www.openhardware.io/view/489/BT832X-Power-Amplified-nRF52832-Remote-Control-with-LNA
    Fortunately, the remote control I posted would still consume zero current when not in use even with the nRF52840. :)
    I guess that PPI is unique to Nordic. I had previously supposed it was a part of the generic ARM chip design, but I didn't see it when I looked into the STM32 chips.
      #1663
      Come to think of it: with so much flash and RAM, I bet the nRF52840 could easily run micro Python. Now that would be interesting!
      U 1 Reply Last reply
        U
        U
        Uhrheber
        @neverdie
        In fact it can.
        Adafruit has a build of their Circuitpython (Micropython fork) for the nrf52832, and there's already an early alpha for the nrf52840.
        As the 52840 has native USB, they can use Micropython as it was originally intended to be, with a virtual USB drive that contains all the user code files.
        • U Uhrheber
          @neverdie
          In fact it can.
          #1665
          @uhrheber Can it run as a USB host? Because then (with a sex change) you could maybe plug it into a USB drive and have a nice little computer. :sunglasses:
            U
            U
            Uhrheber
            @neverdie No, device only.
            But another thought: This thing has USB, NFC, an AES and SHA accelerator, secure storage, secure boot, random number generator, and Bluetooth.
            So it would make a nice USB/NFC/Bluetooth FIDO/U2F security key!
              Anyone played around with Nordic's nRF52840 dongle? They're $10 each, and a few places have them in stock.
              https://www.nordicsemi.com/eng/Products/nRF52840-Dongle
              Nordic finally has a v1.0 product specification for the nRF52840, not just the silly v0.5 that they had posted for so long. http://infocenter.nordicsemi.com/pdf/nRF52840_PS_v1.0.pdf
              It has 256K RAM and 1MB of flash. I'm having difficulty imagining which applications would require that much of either one. If it were free, that would be great, but I'm afraid the large RAM becomes an energy drain. For instance, it consumes 3.16µA with System ON, full 256 kB RAM retention, and wake on RTC.
              On the other hand, it consumes 0.4uA of current if System OFF, no RAM retention, and wake on reset
              It consumes 16.4ma if transmitting at full power (8dBm) with DC-DC engaged.
              If compared to LoRa, it's going to lose on range. However, the question is: will it be good enough in a large or otherwise difficult home environment? The specs say it should be better than either nRF24L01 and nRF52832, which seem better suited to smaller dwellings. Maybe (?) the question can be answered with a couple of dongles.
              U
              U
              Uhrheber
              Bluetooth 5
              • JokgiJ Jokgi
                I would be interested in any range testing in regard to this dongle. For ground it has whatever it is that it is plugged into. (PC, SBC, USB extention cable, etc) There will be a nRF52840 based dongle out soon. See picture above. This dongle will need to be programed over the SWD lines. No Segger on board this one..!
                U
                U
                Uhrheber
                @jokgi Someone said 800 to 1000m.
                https://www.reddit.com/r/electronics/comments/9b3xhv/a_simple_nrf52840_breakout_board/
                  I suppose plugging the Nordic dongle into a Raspberry Pi via USB would potentially make a powerful gateway with a very easy setup. :)
                    #1670
                    Anyone know if the dongle has a USB bootloader on it so that you can upload a sketch over the USB?
                    [Edit: apparently, the answer is yes: http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.nrf52%2Fdita%2Fnrf52%2Fdevelopment%2Fnrf52840_dongle%2Fgetting_started.html ]
                    • alowhumA
                      alowhumA
                      alowhum
                      #1671
                      A plug and play dongle.. now there's something. A controller could theoretically take care of all the work - a user just has to plugin the dongle and it flashes it, installs mysensors..
                      I read it can also support Zigbee and Bluetooth. Could it support Zigbee, bluetooth and MySensors at the same time?
                      Wow, plug that into a Pi Zero and you have a capable controller for a smart home.
                      • alowhumA
                        alowhumA
                        alowhum
                        #1672
                        This looks like an Arduino-nano/pro-mini style device with an NRF51:
                        https://www.aliexpress.com/item/Nrf51822-LIS3DH-Bluetooth-Module-CJMCU-8223-Bluetooth-acceleration-module/32821873481.html
                        alowhumA 1 Reply Last reply
                          Maybe this is old news, but it looks like Adafruit put together a nice board and software for the nRF2832. https://www.adafruit.com/product/3406
                            #1674
                            I'd like to take a crack at prograamming the nRF52840. Has anyone here tried it? I'm not sure whether the software support for it is in place yet or not. How best to get started with it? As far as compiling and uploading code goes, do I just treat it the same as an nRF2832?
                            H 1 Reply Last reply
                              H
                              H
                              heinzv
                              wrote on last edited by heinzv
                              #1675
                              @neverdie I have ordered 10x nRF52832 and 2x nRF52840 from EBYTE (E73-xxxB/C). I will join you once I got them (they are on they way since 2 weeks). I'll also work together with ransyer to get new PCB's (the last we maybe together are for the ESP32).
                              I'm curious what distance I can get indoor with the BLE 4.2/5.0 (no extra radio) and if required, I will combine it with a LoRA RFM95 (that is also what our PCB's is made for RFM69/95 and CC1101).
                              I'm still working on the sensor with the 1,54" ePaper (where the ATMEGA328p is lost with its 32kB flash and even worse with the 2k RAM)
                              https://de.aliexpress.com/item/CDEBYTE-E73-2G4M04S-BLE-4-2-5-0-long-distance-100m-2-4GHz-SMD-ARM-Core/32820692238.html?spm=a2g0s.9042311.0.0.60a94c4dZdIUhQ
                              this one will be tricky to solder (I'm trying to get something better to solder)
                              https://de.aliexpress.com/item/NRF52840-Bluetooth-5-0-240-mhz-RF-Transceiver-CDSENET-E73-2G4M08S1C-8dbm-Keramik-Antenne-BLE-4/32906661666.html?spm=a2g0s.9042311.0.0.1d174c4dKW9mAo
                              • H heinzv
                                @heinzv Well, great, the more the merrier. :)
                                • Nca78N
                                  @heinzv said in nRF5 action!:
                                  Already out of stock it seems, it's not possible to order them any more.
                                  They seem to have both 32K crystal and inductances for DCDC, that's pretty convenient.
                                    #1678
                                    The answer I got on the Sandeep library made it sound rather iffy as to whether it would work for the nRF52840: https://github.com/sandeepmistry/arduino-nRF5/issues/310
                                    or that the coverage might be rather spotty.
                                    So, I think I may give mbed a try for programming the nRF52840, because mbed claims to support the nRF52840-DK. Also, I found what seems like a nice and simple youtube tutorial series for how to use mbed: https://www.youtube.com/watch?v=kP_zHbC_5eM
                                    If I have success with mbed, I may circle back to the Sandeep library and the mysensors implementation, but I'd like to start with something solid, and it appears that mbed might be.
                                    The other nice thing is that it appears mbed provides an abstraction layer which makes easy to program a whole range of different mcu's, incuding many of the stm32's.
                                    Anyone here familiar with or tried mbed before?
                                      #1679
                                      @neverdie I tried mbed briefly in a workshop on LoRaWAN FOTA. With the workshop instructions it was easy to use, but my impression is that Arduino has a much larger ecosystem with more libraries.
                                        #1680
                                        Update:
                                        I received some nRF52840 dongles. I confirmed with Nordic that the recommended way to program them over USB is to use nRF Connect v2.5.0 which contains the nRF Programmer v1.0.0-experimental.5 application. I tried that, but I may have somehow bricked my first dongle by not pressing reset first before the upload. Either that, or because my simple program didn't initialize the USB, maybe it can't be found for that reason (I suspect so).
                                        Luckily, I live not too far from Mouser. I should be receiving the nRF52840-DK today, so I figure that way I can unbrick the dongle.
                                        Yesterday I played around with mbed on an nucleo board. Seems to work well (no bricking). Unfortunately, the dongle isn't an mbed device, so the methods above are required unless you program it with a DK or similar. The good news, though, is that the DK is an mbed board, so hopefully that will be smooth sailing. It turns out that USB is built into the nRF52840 chip, so it doesn't require a separate chip like a CP2102 to communicate over USB. I guess that can be good or bad depending on how your write your code.
                                          #1681
                                          By the way, the nRF52840-DK is even easier to program thant the nRF52832-DK. When you attach it to your PC, it shows as an additional drive in your directory. Any hex file that you copy to that drive gets uploaded and programmed onto the nRF52840. Easy. :)
                                          mfalkviddM Nca78N 2 Replies Last reply
