  3. Relay with ACS712
Relay with ACS712
relaynrf24l01+
18 Posts 11 Posters 13.3k Views 12 Watching
  • D Offline
    Dheeraj
    attempt over last week , circuit board with 2x relay actuator and hall current sensor ( acs712 ) and step down transformer. The most challenging part is how to pack your creation in a nice box. ;) 2015-01-27 20.21.35.jpg
    axillentA DidiD 2 Replies Last reply
    • D Offline
      doblanch
      Do you have the stetch ? I'm going to do the same :-) rgds
      D 1 Reply Last reply
      • D Dheeraj
        axillentA Offline
        axillentA Offline
        axillent
        @Dheeraj you are quite sufficient in packing all things together :)
        sense and drive
        • D doblanch
          Dheeraj
          @doblanch i'm in process of completing the sketch and will share it with you once finished.
          • D Offline
            Dheeraj
            wrote on last edited by Dheeraj
            here's the finished product :)
            IMG_20150212_223046.jpg IMG_20150212_224007.jpg IMG_20150213_153440.jpg IMG_20150213_153454.jpg IMG_20150213_153425.jpg
            • axillentA axillent
              Dheeraj
              thanks
              • epierreE Offline
                epierreE Offline
                epierre
                How far have you been with the ACS712 ?
                z-wave - Vera -> Domoticz
                • epierreE epierre
                  Dheeraj
                  @epierre said:
                  able to calculate the wattage of 2 loaded devices to a rough level.. p = v x i. ..still WIP.
                  • D Dheeraj
                    DidiD Offline
                    DidiD Offline
                    Didi
                    Nice work.Can you show how you wired this and maybe share your sketch ?
                    • epierreE Offline
                      epierreE Offline
                      epierre
                      @Dheeraj yes can you share more of what you did ? thanks !
                      • epierreE epierre
                        Dheeraj
                        @epierre .. nothing much .. used relay to control 2 devices and tried to calculate the power consumed ( in watts ) assume the input voltage is ~220v.
                        • Q Offline
                          Q Offline
                          Qu3Uk
                          Quick question but where did you get that enclosure from and the multi type plug sockets. They look modular?
                          • epierreE Offline
                            epierreE Offline
                            epierre
                            @Dheeraj have you something to share about the ACS712 and voltage consumption, I could help too by trying to make my own tests ? I already have the chip.
                            • T Offline
                              T Offline
                              tuspam
                              Hi, can You share your sketch? Thank You.
                              • nakorN Offline
                                nakorN Offline
                                nakor
                                hello,
                                thank for the picture.
                                As the others above, I would be very interested to know where you get that enclosure from and if you can share the sketch.
                                Romain
                                • nakorN nakor
                                  hello,
                                  Romain
                                  GertSandersG Offline
                                  GertSanders
                                  @nakor
                                  Seems to be a surface mount Crabtree box, which is a brand available in the UK.
                                  I found a reference to something like this on a FARNELL site:
                                  http://cpc.farnell.com/1/3/crabtree-electrical-switches
                                  • Shivanand ChanderballyS Offline
                                    From what I understand the ACS712 is affected by magnetic interference. Do you think the close proximity to the relay will skew the readings?
                                    Boots33B 1 Reply Last reply
                                    • Shivanand ChanderballyS Shivanand Chanderbally
                                      Boots33B Offline
                                      Boots33B Offline
                                      Boots33
                                      wrote on last edited by Boots33
                                      @Shivanand-Chanderbally I recently finished a node using the acs712 and found it to be very sensitive to nearby magnetic fields. It is best to have it as far away from these as you can.
                                      11.9k
                                      113.3k
