  3. Relay with ACS712
Relay with ACS712
relaynrf24l01+
18 Posts 11 Posters 14.2k Views 12 Watching
  • D Offline
    Dheeraj
    attempt over last week , circuit board with 2x relay actuator and hall current sensor ( acs712 ) and step down transformer. The most challenging part is how to pack your creation in a nice box. ;) 2015-01-27 20.21.35.jpg
    A DidiD 2 Replies Last reply
    • D Offline
      doblanch
      Do you have the stetch ? I'm going to do the same :-) rgds
      D 1 Reply Last reply
      • D Dheeraj
        A Offline
        A Offline
        axillent
        @Dheeraj you are quite sufficient in packing all things together :)
        sense and drive
        • D doblanch
          Dheeraj
          @doblanch i'm in process of completing the sketch and will share it with you once finished.
          • D Offline
            Dheeraj
            wrote on last edited by Dheeraj
            here's the finished product :)
            IMG_20150212_223046.jpg IMG_20150212_224007.jpg IMG_20150213_153440.jpg IMG_20150213_153454.jpg IMG_20150213_153425.jpg
            • A axillent
              Dheeraj
              thanks
              • E Offline
                E Offline
                epierre
                How far have you been with the ACS712 ?
                z-wave - Vera -> Domoticz
                • E epierre
                  Dheeraj
                  @epierre said:
                  able to calculate the wattage of 2 loaded devices to a rough level.. p = v x i. ..still WIP.
                  • D Dheeraj
                    DidiD Offline
                    DidiD Offline
                    Didi
                    Nice work.Can you show how you wired this and maybe share your sketch ?
                    if (knowledge == 0) { use BRAIN; use GOOGLE;use SEARCH; } else {make POST;}
                    • E Offline
                      E Offline
                      epierre
                      @Dheeraj yes can you share more of what you did ? thanks !
                      • E epierre
                        Dheeraj
                        @epierre .. nothing much .. used relay to control 2 devices and tried to calculate the power consumed ( in watts ) assume the input voltage is ~220v.
                        • Q Offline
                          Q Offline
                          Qu3Uk
                          Quick question but where did you get that enclosure from and the multi type plug sockets. They look modular?
                          • E Offline
                            E Offline
                            epierre
                            @Dheeraj have you something to share about the ACS712 and voltage consumption, I could help too by trying to make my own tests ? I already have the chip.
                            • T Offline
                              T Offline
                              tuspam
                              Hi, can You share your sketch? Thank You.
                              • nakorN Offline
                                nakorN Offline
                                nakor
                                hello,
                                thank for the picture.
                                As the others above, I would be very interested to know where you get that enclosure from and if you can share the sketch.
                                Romain
                                G 1 Reply Last reply
                                • nakorN nakor
                                  hello,
                                  Romain
                                  G Offline
                                  G Offline
                                  GertSanders
                                  @nakor
                                  Seems to be a surface mount Crabtree box, which is a brand available in the UK.
                                  I found a reference to something like this on a FARNELL site:
                                  http://cpc.farnell.com/1/3/crabtree-electrical-switches
                                  • Shivanand ChanderballyS Offline
                                    From what I understand the ACS712 is affected by magnetic interference. Do you think the close proximity to the relay will skew the readings?
                                    Boots33B 1 Reply Last reply
                                    • Shivanand ChanderballyS Shivanand Chanderbally
                                      Boots33B Offline
                                      Boots33B Offline
                                      Boots33
                                      wrote on last edited by Boots33
                                      @Shivanand-Chanderbally I recently finished a node using the acs712 and found it to be very sensitive to nearby magnetic fields. It is best to have it as far away from these as you can.
                                      12.1k
