  3. Can't send message over arduino serial monitor
controlerarduinoserial
8 Posts 5 Posters 6.4k Views 2 Watching
  • B Offline
    B Offline
    botbite
    wrote on last edited by botbite
    Ok so I have got a few questions and a problem to solve
    I have two arduino unos hooked up with the nrf24l01+ one is running the (arduino button relay) and the other is running the (serial gateway) examples. Once I plug the sensors in I Ioad arduino running the gateway into the serial moniter and it gives me the normal "0;0;3;0;14;Gateway start up complete." then I turn on the (relay button arduino) and it gives me a confirming
    "105;255;0;0;18;1.4.1
    0;0;3;0;9;read: 105-105-0 s=255,c=3,t=6,pt=1,l=1:0
    105;255;3;0;6;0
    0;0;3;0;9;read: 105-105-0 s=255,c=3,t=11,pt=0,l=14:Relay & Button
    105;255;3;0;11;Relay & Button
    0;0;3;0;9;read: 105-105-0 s=255,c=3,t=12,pt=0,l=3:1.0
    105;255;3;0;12;1.0
    0;0;3;0;9;read: 105-105-0 s=1,c=0,t=3,pt=0,l=5:1.4.1
    105;1;0;0;3;1.4.1"
    So, I have good connection and the node is all set up. So then I try and give the node a command to turn on or off, so I type into the serial monitor
    105;1;1;1;2;1\n
    or 105;1;1;1;2;0\n
    or 105;1;0;1;2;1\n
    or 105;1;1;0;2;0\n
    or 105;0;1;1;2;1\n
    or 105;0;1;1;2;0\n
    just about every variation that you could imagine and nothing.
    The biggest question I have is, Am i supposed to type anything in before 105;1;1;1;2;1\n ?
    Is there a method that I am supposed to call up? I am writing directly into the serial monitor form the arduino ide, and am running the 1.4 library of Mysensors. Is there supposed to be anything else with the message"105;1;1;1;2;1\n" to help this message to compute to the relay?
    thanks?
    • K Offline
      K Offline
      kalle
      • B Offline
        B Offline
        botbite
        the funny thing is I know the everything is hooked up right because everything works through a controller? Has anyone else tried to get this to work just through the serial monitor?
        • hekH Online
          hekH Online
          wrote on last edited by hek
          What is you newline/cr setting in serial monitor?
          Are you actually typing \n ?
          \n == enter/carriage return
          • B Offline
            B Offline
            botbite
            The setting has been "No line Ending" And I tried typing it in both ways with the \n and without (105;1;1;1;2;1\n and 105;1;1;1;2;1). What setting should I be in in the serial monitor and what should I type into the serial monitor?
            Thank you so much for responding, I am really interested in all this and it looks like you guys have done such a great job! Thanks!
            • hekH Online
              hekH Online
              The serial monitor setting should be set to "with line ending".
              You should not typ "\n"!
              It means that you should press enter on your keyboard.
              • E Offline
                E Offline
                epierre
                2015-01-28 10:36:55 9 255 0 0 18 1.4.1
                2015-01-28 10:36:55 9 255 3 0 6 0
                2015-01-28 10:36:56 9 255 3 0 11 Relay
                2015-01-28 10:36:56 9 255 3 0 12 1.0
                2015-01-28 10:36:56 9 1 0 0 3 1.4.1
                I can send this:
                echo "9;3;1;0;2;1\n" >> /dev/ttyUSB0
                On the device serial line I see:
                read: 0-0-9 s=3,c=1,t=2,pt=0,l=3:1\n
                Incoming change for sensor:3, New status: 1
                z-wave - Vera -> Domoticz
                • D Offline
                  daulagari
                  On Linux I saw that I have to send "\r\n" instead of "\n".
                  "\r\n" (Carriage return, Line feed) is the Windows return, "\n" only the Linux return.
