  3. OTA flash types for MySensors
64 Posts 23 Posters 36.7k Views 20 Watching
  • Nca78N Nca78
    @manutremo you can save nearly 40% of your money on AliExpress for those:
    https://www.aliexpress.com/item/Memory-Module-W25Q32B-High-Capacity-SPI-Interface-Flash-Memory-32M/32767512974.html
    manutremo
    @Nca78 Thanks for the hint. I actually purchased from this seller who is chaper:
    http://www.ebay.es/itm/Module-De-Memoire-Dinterface-1Pcs-Spi-W25q32b-Haute-Capacite-Ic-Nouveau-K-/162656857086?hash=item25df1aabfe:g:1Z8AAOSwSblZqs0q
    While the ebay seller shipped for free, Aliexpress would charge me 1.24€ for shipping to my country so the total price would be 2.63, significantly more expensive.
    Many thanks anyways!
    J 1 Reply Last reply
      What do you think would be the best solution to fit a flash chip on the easypcb board?
      @gohan said in OTA flash types for MySensors:
      The best solution IMHO is to use MYSBootloader so you don't need a flash chip ;)
      gohanG 1 Reply Last reply
      • Nca78N Nca78
        @Nca78 I thought about that, but there are quite some limitations like no encryption and signing support
        AnticimexA 1 Reply Last reply
          AnticimexA
          AnticimexA
          Anticimex
          @gohan I do believe mysbooloader has signing support.
          • AnticimexA Anticimex
            @Anticimex does it? How about encryption?
              AnticimexA
              AnticimexA
              Anticimex
              @gohan not sure. Better ask the author of the bootloader for that. Ping @tekka
                #57
                also note:
                so far MysBootloader is available for nrf24 only.
                And for rfm69 FOTA, it's dualoptiboot bootloader based (from Lowpowerlab) which needs a flash ic.
                It has been answered by tekka in another thread, but I don't think there is an eta for rfm69 MysBootloader yet..as the todolist isn't short !
                • M manutremo
                  J
                  J
                  jkandasa
                  wrote on last edited by jkandasa
                  #58
                  @manutremo said in OTA flash types for MySensors:
                  @manutremo I am getting trouble with W25Q32B. Can you help me to get success? I am struggling to get jedec id for this chip.
                  UPDATE: I included the following lines on the sketch it works,
                  //Enable OTA feature
                  #define MY_OTA_FIRMWARE_FEATURE
                  #define MY_OTA_FLASH_JDECID 0x00
                  • J jkandasa
                    manutremo
                    @jkandasa happy to see that you solved it. In case it matters, I didn't need to add the second line.
                    • scalzS scalz
                      @tbowmo I thought same things...
                      @ahmedadelhosni : translation roughly done ;) Here http://forum.mysensors.org/topic/3503/sensebender-dualoptiboot-ota-howto-in-mysensors
                      P
                      P
                      p359
                      Hi, old thread but I hope a question not too far off the mark. I'm using Easy PCB nodes and looking to use OTA on the reverse side. I'm having some issues finding a source in Australia for the SPI chip mentioned, I am seeing this one very easily available. From the data sheet on the page, it appears to be pretty much the same, just the lower end of the acceptable voltage is up to 2.6V. Any thoughts welcome if you can see if it would/wouldn't work, my tech knowledge is limited on this sort of thing.
                      https://au.rs-online.com/web/p/flash-memory/8228477
                      Cheers!
                      • P p359
                        Cheers!
                        sundberg84S
                        sundberg84S
                        #61
                        @p359 - not really good at these external flash either... but as you said its a 2.8-3.6v chip meaning you limit the EasyPCB to a regulated 3.3v 8mhz Pro mini. Battery operations will be hard to achieve (not impossible though). But since you are aiming for OTA i guess you wont be using sleep/battery.
                        for how to write to the chip, im not the person to ask/answer since this is quite new to me but it seems like a fair price so maybe worth a shot.
                        P 1 Reply Last reply
                          It is possible to use battery, just use smartsleep instead of sleep to allow a little extra time for the controller to send the OTA update command and you can also use LiFePO4 batteries that work exactly in that voltage range.
                          • sundberg84S sundberg84
                            P
                            P
                            p359
                            @sundberg84 you raise an obvious point about upper voltage that I'd overlooked to to be honest. I'll make a 3.3v node up to test when the chips arrive to test. If it works, perhaps try to use on 5v node with a shifter. Will report back if they work or not. I see also in the code now, reference to using i2c eeproms. Plenty of options to try. Thanks
                            • P p359
                              P
                              P
                              p359
                              Not making too much headway with this. Chips arrived, soldered on the the reverse side of the easypcb. Not able to get any sign of the flash being seen. One odd thing, the physical solder pad for the flash chip, pin 6 on my boards isn't connected to sck of the arduino pin 13 at all, just a bare solder pad. I've bridged this with wire, still no luck. Hmmmm...! More experiments ahead, good fun!
                              12.5k
