  3. OTA flash types for MySensors
64 Posts 23 Posters 36.4k Views 20 Watching
  • S Samuel235
    @mardah said in OTA flash types for MySensors:
    Would AT45DB041E be a good choice as a OTA flash? I see it's in the schematics for the new Sensebender Micro mk2.
    Did you ever figure out if this works with Optiboot for OTA flashing?
    I must admit that i'm very confused at this thread, it was setup to advise of other Flash IC's for us to use but there seems to be no 'solid' alternatives that you guys have suggested. For me, living in the UK, its near impossible to grab any of the AT25DF512C-SSHN-B without paying through the roof for shipping.
    I can see that AT45DB041E is JEDEC compliant but that is as far as i can go with knowing if it will work. Flash architecture is way out of my depth right now.
    KoreshK
    KoreshK
    Koresh
    wrote on last edited by Koresh
    #43
    @Samuel235 said in OTA flash types for MySensors:
    AT45DB041E
    Hello. This chip (AT45DB041E) has no erase 32kb command (0x52), status read command has a strange opcode too (D7h). So it is no trivial task to use this chip.
    I can suggest Micron M25P40 as widespread IC. But it requires one trick and I will try to describe it. This chip has no erase 32kb command (0x52) too. It means OTA code will not erase memory and update will be failed. We (me and Yury) bumped into this problem when we started intensive tests of my nodes before production (we use micron M25P40). Moreover, when I try to investigate inexpensive avaliable chips I find an interesting thing. Chips with 64kb erase option (0xD8 opcode) are more common than chips with 32kb erase option (which support 64kb erase option too). So it can be worth adapting mysensors for use of any flash chip which supports 64kb erase option. To adapt your sketches you should do only two things
    1. Add this code into your sketch after including mysensors.h
    #define SPIFLASH_BLOCKERASE_32K   0xD8
    So OTA library will call erase 64kb command instead of erase 32kb command. It is very easy.
    2) You should use Bootloader which calls erase 64kb command instead of 32kb command.
    Bad news. It is not an easy task and you should recompile dual optiboot and burn it. :anguished:
    Good news. I've recompliled dual optiboot and all my nodes will burn with it by default. :yum:
    My changes in bootloader are very simple but it sutable for my boards. We update it many many times and the process is absolutely bulletproof (especially after Tekka's update :+1: ).
    But how about a more universal solution? I think it is not too hard to modify dual optiboot to check flash first 10 bytes (OTA flag) after 32kb erase command call and try another command? I will try this idea later but may be someone will do it faster :smiley:
    S alexsh1A 2 Replies Last reply
    • KoreshK Koresh
      AT45DB041E
      Samuel235
      @Koresh - Thank you for explaining this to me. I think i understand this a little more clearly now. Like i said, i've never dealt with flash so its all a grey area for myself.
      I'm currently looking at recompiling MYSBootloader for use with an 8Mhz crystal instead of this work around. The whole reasoning behind me asking this question is simply because i wanted OTA updates on a battery powered node. Now, this means i need OTA updates on 3.3v, but my MYSBootloader nodes require 16Mhz crystal to work. So its either use 16Mhz on 3.3v (while it works, its not the correct solution) OR to get a bootloader working with an 8Mhz crystal setup. I chose the later, and therefor its either recompile MYSBootloader to work with 8Mhz OR to get a flash IC on the board to allow for Dual Optiboot.
      At the moment i'm toying with the idea of going the software issue route and attempting to recompile MYSBootloader for 8Mhz (just need to workout what to change for the recompiled version). Seems a little easier and cheaper than going the route of flash considering my location and not being able to get my hands on the recommended/mostly used flash IC.
      MySensors 2.1.1
      • KoreshK Koresh
        AT45DB041E
        alexsh1A
        alexsh1A
        alexsh1
        @Koresh what about Winbond W25X40CLSNIG - the same used by Moteino? It seems to me this could be a good match?
        https://www.winbond.com/resource-files/w25x40cl_e01.pdf
        @tbowmo Thomas, what do you think?
        KoreshK 1 Reply Last reply
        • alexsh1A alexsh1
          KoreshK
          KoreshK
          Koresh
          #46
          @alexsh1 It seems suitable at first sight :wink:
          alexsh1A 1 Reply Last reply
          • KoreshK Koresh
            alexsh1A
            alexsh1A
            alexsh1
            #47
            @Koresh I have just tried it and it works nicely.
            Start...Init OK!
            DeviceID: EF30
            Flash content:
            FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.
            WriteByte(1)
            WriteByte(2)
            WriteByte(3)
            WriteByte(4)
            WriteByte(5)Flash content:
            FF.BB.BB.BB.AA.BB.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.
            Erasing Flash chip ... DONE
            The only disadvantage to me is voltage given that nrf24l01+ can run down to 1.9V
            Features
            • 2.3V to 3.6V supply
            • 1mA active current,
            • <1μA Power-down
            Aliexpress: $0.25 a piece + postage ($2.50 to Europe)
              manutremo
              wrote on last edited by manutremo
              #48
              I found the following one which is now offered in a breakout board.
              http://www.ebay.es/itm/2Pcs-W25q32b-Module-De-Memoire-Haute-Capacite-Module-De-Memoire-Interface-Spi-W-/132248126492?hash=item1eca9a441c:g:EukAAOSw4GVYI2CY
              I read the datasheet and compared the characteristics and instruction set with the ones for W25X40CLSNIG. I also checked against the SPIFlash.h file in github.
              Datasheet: http://www.elinux.org/images/f/f5/Winbond-w25q32.pdf
              To me everything seems consistent and am planning to order one to check. Does anyone see something what might prevent it from working?
              I'll report on what I find - it will be in some weeks since the delivery time is long.
              Nca78N 1 Reply Last reply
                What do you think would be the best solution to fit a flash chip on the easypcb board?
                • M manutremo
                  @manutremo you can save nearly 40% of your money on AliExpress for those:
                  https://www.aliexpress.com/item/Memory-Module-W25Q32B-High-Capacity-SPI-Interface-Flash-Memory-32M/32767512974.html
                  • Nca78N Nca78
                    manutremo
                    @Nca78 Thanks for the hint. I actually purchased from this seller who is chaper:
                    http://www.ebay.es/itm/Module-De-Memoire-Dinterface-1Pcs-Spi-W25q32b-Haute-Capacite-Ic-Nouveau-K-/162656857086?hash=item25df1aabfe:g:1Z8AAOSwSblZqs0q
                    While the ebay seller shipped for free, Aliexpress would charge me 1.24€ for shipping to my country so the total price would be 2.63, significantly more expensive.
                    Many thanks anyways!
                    J 1 Reply Last reply
                      @gohan said in OTA flash types for MySensors:
                      The best solution IMHO is to use MYSBootloader so you don't need a flash chip ;)
                      gohanG 1 Reply Last reply
                      • Nca78N Nca78
                        @Nca78 I thought about that, but there are quite some limitations like no encryption and signing support
                        AnticimexA 1 Reply Last reply
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @gohan I do believe mysbooloader has signing support.
                          • AnticimexA Anticimex
                            @Anticimex does it? How about encryption?
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @gohan not sure. Better ask the author of the bootloader for that. Ping @tekka
                                #57
                                also note:
                                so far MysBootloader is available for nrf24 only.
                                And for rfm69 FOTA, it's dualoptiboot bootloader based (from Lowpowerlab) which needs a flash ic.
                                It has been answered by tekka in another thread, but I don't think there is an eta for rfm69 MysBootloader yet..as the todolist isn't short !
                                • M manutremo
                                  J
                                  J
                                  jkandasa
                                  wrote on last edited by jkandasa
                                  #58
                                  @manutremo said in OTA flash types for MySensors:
                                  @manutremo I am getting trouble with W25Q32B. Can you help me to get success? I am struggling to get jedec id for this chip.
                                  UPDATE: I included the following lines on the sketch it works,
                                  //Enable OTA feature
                                  #define MY_OTA_FIRMWARE_FEATURE
                                  #define MY_OTA_FLASH_JDECID 0x00
                                  • J jkandasa
                                    manutremo
                                    @jkandasa happy to see that you solved it. In case it matters, I didn't need to add the second line.
                                    • scalzS scalz
                                      @tbowmo I thought same things...
                                      @ahmedadelhosni : translation roughly done ;) Here http://forum.mysensors.org/topic/3503/sensebender-dualoptiboot-ota-howto-in-mysensors
                                      P
                                      P
                                      p359
                                      Hi, old thread but I hope a question not too far off the mark. I'm using Easy PCB nodes and looking to use OTA on the reverse side. I'm having some issues finding a source in Australia for the SPI chip mentioned, I am seeing this one very easily available. From the data sheet on the page, it appears to be pretty much the same, just the lower end of the acceptable voltage is up to 2.6V. Any thoughts welcome if you can see if it would/wouldn't work, my tech knowledge is limited on this sort of thing.
                                      https://au.rs-online.com/web/p/flash-memory/8228477
                                      Cheers!
                                      • P p359
                                        Cheers!
                                        sundberg84S
                                        sundberg84S
                                        #61
                                        @p359 - not really good at these external flash either... but as you said its a 2.8-3.6v chip meaning you limit the EasyPCB to a regulated 3.3v 8mhz Pro mini. Battery operations will be hard to achieve (not impossible though). But since you are aiming for OTA i guess you wont be using sleep/battery.
                                        for how to write to the chip, im not the person to ask/answer since this is quite new to me but it seems like a fair price so maybe worth a shot.
                                        P 1 Reply Last reply
                                          It is possible to use battery, just use smartsleep instead of sleep to allow a little extra time for the controller to send the OTA update command and you can also use LiFePO4 batteries that work exactly in that voltage range.
