  3. About DS18B20 onewire.
dallasone wireonewireds18b20
48 Posts 5 Posters 19.2k Views 10 Watching
  • pepsonP pepson
    @flopp
    Hi
    i try use your sketch but it is not working... I add in this to use serial gateway but also i get error why ?
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    #define MY_GATEWAY_SERIAL
    #include <OneWire.h>
    #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
    unsigned long SLEEP_TIME = 3000; // Sleep time between reads (in milliseconds)
    byte D[3][8] = {
    { 0x28, 0xC6, 0xCA, 0xA0, 0x05, 0x00, 0x00, 0x30 }
    int numSensors=0;
    boolean receivedConfig = false;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
      sensors.begin();
      // Startup and initialize MySensors library. Set callback for incoming messages.
      gw.begin();
      gw.sendSketchInfo("Temperature Sensor", "1.1");
      for (int i=0; i<3 && i<MAX_ATTACHED_DS18B20; i++) {
         gw.present(i, S_TEMP);
    Serial.println(millis());
      // Process incoming messages (like config from server)
      gw.sleep(conversionTime);
     //   float temperature = static_cast<float>(static_cast<int>((sensors.requestTemperaturesByAddress(D[i])) * 10.)) / 10.;
          float temperature = sensors.getTempC(D[i]);
        #if COMPARE_TEMP == 1
          gw.send(msg.setSensor(i).set(temperature,1));
      //gw.sleep(SLEEP_TIME);
    But when try compile i get error:
    dallas_with_address_ok:45:1: error: 'MySensor' does not name a type
    C:\Users\Piotrek\Desktop\Arduino\dallas_with_address_ok\dallas_with_address_ok.ino: In function 'void setup()':
    dallas_with_address_ok:61:3: error: 'gw' was not declared in this scope
       gw.begin();
    C:\Users\Piotrek\Desktop\Arduino\dallas_with_address_ok\dallas_with_address_ok.ino: In function 'void loop()':
    dallas_with_address_ok:81:3: error: 'gw' was not declared in this scope
    exit status 1
    Please help me...
    @pepson that sketch is for MySensors 1.x. It needs to be updated to work with 2.x. There is a guide, see if you can find it by searching (I’m on mobile now so I can’t search easily)
    pepsonP 1 Reply Last reply
    • pepsonP
      pepsonP
      pepson
      wrote on last edited by pepson
      #23
      I correct this sketch But for me dont read temp.....
      standard sketch from mysensors looks similary like this read with no problem.
      https://www.mysensors.org/build/temp
      byte D[3][8] = {
      { 0x28, 0xFB, 0x8F, 0x77, 0x91, 0x15, 0x02, 0x32 },
      { 0x28, 0xFF, 0x37, 0x77, 0x91, 0x18, 0x02, 0x16 }
      //MySensor gw;
      int numSensors=0;
      void before()
        sensors.begin();
      //  begin();
        sendSketchInfo("Temp. Sensor", "1.1");
           present(i, S_TEMP);
        //process();
        pepsonP
        pepsonP
        pepson
        @mfalkvidd
        Hi
        I am not programmer and i dont know how. Is any chance to you can help me convert it to working with MySensors 2.x ?
        This sketch looks similary as standard sketch from mysensors:
        Standard sketch works but i want use sketch with ID Dallas to write in my Home assistant to specify number child.... and when dallas destroy i replace ID in sketch write to arduino and in Home Assistant automaticaly replace it and show still correct temp to my room.
        • F
          F
          flopp
          wrote on last edited by flopp
          #25
          @pepson said in About DS18B20 onewire.:
          this should be how many DS18B20 you have attached
          • F
            F
            flopp
            byte D[3][8] = {
            D[3] means 3 attached DS18B20, but you only have address for 2
            • F
              F
              flopp
              I have a sketch where I have attached 40 pcs mixed both DS18B20 and DS18S20, works perfect, except that sometimes I recevied 0 as value for some of them. I am polling every minute, so I don't care if the value is 0 for a couple of minutes, it is not that very important
              • F flopp
                pepsonP
                pepsonP
                pepson
                @flopp
                But for what is number 8 in this ?
                byte D[3][8] = {
                On what MySensors you use it ?
                Previous sketch your in this thread i can not compile. I convert it as i show. You mean that sketch with 2 pcs dallas should look like this:
                byte D[2][8] = {
                { 0x28, 0xC5, 0xBF, 0x77, 0x91, 0x16, 0x02, 0x1D }
                //MySensor gw;
                int numSensors=0;
                void before()
                  sensors.begin();
                //  begin();
                     present(i, S_TEMP);
                  //process();
                    //float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(D[i]):sensors.getTempFByIndex(D[i])) * 10.)) / 10.;
                    //float temperature = static_cast<float>(static_cast<int>((sensors.requestTemperaturesByAddress(D[i])) * 10.)) / 10.;
                  sleep(SLEEP_TIME);
                And what command in sketch should be use:
                1. float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(D[i]):sensors.getTempFByIndex(D[i])) * 10.)) / 10.;
                2. float temperature = static_cast<float>(static_cast<int>((sensors.requestTemperaturesByAddress(D[i])) * 10.)) / 10.;
                3. float temperature = sensors.getTempC(D[i]);
                In original sketch from Mysensors he use this :
                And please share me sketch which you use with MySensors 2.x and with how system controller you use it ? I want use with Home Assistant.
                • F
                  F
                  flopp
                  #define MY_NODE_ID 14
                  #define ATTACHED_DS18B20 40
                  unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                  byte D[ATTACHED_DS18B20][8] = {
                  { 0x10, 0x04, 0xB8, 0x3F, 0x02, 0x08, 0x00, 0xBD }, //KökTbx
                  { 0x10, 0xF4, 0xD7, 0x3F, 0x02, 0x08, 0x00, 0xB1 }, //UppTbx
                  { 0x10, 0x92, 0x9F, 0x3E, 0x02, 0x08, 0x00, 0x98 }, //KökUt
                  { 0x10, 0x4E, 0xE4, 0x3E, 0x02, 0x08, 0x00, 0x3C }, //ToaUt
                  { 0x10, 0x1E, 0xE8, 0x3E, 0x02, 0x08, 0x00, 0x33 }, //EfterPump
                  { 0x10, 0x09, 0xA1, 0x3E, 0x02, 0x08, 0x00, 0xF7 }, //HallTbx
                  { 0x10, 0x59, 0xCB, 0x3F, 0x02, 0x08, 0x00, 0xFA }, //UppUt
                  { 0x10, 0x07, 0x1B, 0x3F, 0x02, 0x08, 0x00, 0x99 }, //ToaTbx
                  { 0x28, 0xFF, 0xB1, 0xAA, 0x63, 0x15, 0x03, 0xC8 }, //Kök
                  { 0x10, 0x80, 0xB6, 0x3F, 0x02, 0x08, 0x00, 0x29 }, //Panna komp
                  { 0x10, 0x3C, 0x9C, 0x3E, 0x02, 0x08, 0x00, 0x99 }, //Hall ut
                  { 0x10, 0x42, 0xE0, 0x3F, 0x02, 0x08, 0x00, 0xD1 }, //Tvätt
                  { 0x10, 0xCE, 0xE9, 0x3E, 0x02, 0x08, 0x00, 0x3A }, //T12
                  { 0x10, 0x99, 0xAC, 0x3F, 0x02, 0x08, 0x00, 0x25 }, //V mellan
                  { 0x10, 0x15, 0xDB, 0x3E, 0x02, 0x08, 0x00, 0x01 }, //Hallen
                  { 0x10, 0xF3, 0xD7, 0x3F, 0x02, 0x08, 0x00, 0x34 }, //Panna El
                  { 0x10, 0xFB, 0xCB, 0x3F, 0x02, 0x08, 0x00, 0xC8 }, //Toa Nere
                  { 0x10, 0x97, 0x23, 0x3F, 0x02, 0x08, 0x00, 0x92 }, //Varmvatten
                  { 0x10, 0x0F, 0xE6, 0x3E, 0x02, 0x08, 0x00, 0xFD }, //Carport
                  { 0x10, 0xF3, 0xC6, 0x3F, 0x02, 0x08, 0x00, 0x85 }, //Förrådet
                  { 0x10, 0x9C, 0x3B, 0x52, 0x02, 0x08, 0x00, 0x25 }, //Mark 60
                  { 0x10, 0xF2, 0x24, 0x3F, 0x02, 0x08, 0x00, 0xEB }, //Vrum V
                  { 0x10, 0x6A, 0x5E, 0x52, 0x02, 0x08, 0x00, 0x26 }, //Mark 30
                  { 0x10, 0x76, 0xCE, 0x3F, 0x02, 0x08, 0x00, 0xBA }, //Plattan
                  { 0x10, 0x0E, 0x7B, 0x13, 0x02, 0x08, 0x00, 0x7C }, //Utetemp
                  { 0x10, 0xEE, 0xEB, 0x3E, 0x02, 0x08, 0x00, 0x0F }, //Uterum
                  { 0x28, 0x8C, 0x2D, 0xB4, 0x04, 0x00, 0x00, 0x9C }, //Kyl uppe
                  { 0x28, 0xFF, 0xB2, 0x74, 0x63, 0x15, 0x02, 0xCC }, //Kyl mitten
                  { 0x28, 0xFF, 0x08, 0x07, 0x52, 0x04, 0x00, 0xFF }, //Kyl nere
                  { 0x28, 0xFF, 0xE6, 0x06, 0x52, 0x04, 0x00, 0x08 }, //Frys uppe
                  { 0x28, 0xFF, 0xB4, 0x07, 0x55, 0x04, 0x00, 0xEB }, //Kyl bakom
                  { 0x10, 0x1C, 0xA8, 0x3F, 0x02, 0x08, 0x00, 0x3B }, //Lucas
                  { 0x10, 0x83, 0x3C, 0x3F, 0x02, 0x08, 0x00, 0x06 }, //Allrum
                  { 0x10, 0xA3, 0xE8, 0x3E, 0x02, 0x08, 0x00, 0x7E }, //Theo
                  { 0x10, 0x33, 0x3C, 0x3F, 0x02, 0x08, 0x00, 0x01 }, //Sovrum
                  { 0x28, 0xFF, 0xFB, 0x3D, 0xC3, 0x16, 0x03, 0x58 }, //Panna luft in(varm)
                  { 0x28, 0xFF, 0xD4, 0x1C, 0x00, 0x17, 0x03, 0x43 }, //Dränering
                  { 0x28, 0xFF, 0x97, 0x11, 0x01, 0x15, 0x04, 0xC0 } // Poolvatten
                  float lastTemperature[ATTACHED_DS18B20];
                  MyMessage heat(0,V_STATUS);
                    sensors.begin();
                    sendSketchInfo("OneWire Temp+Heating LED", "20180709");
                    //numSensors = sensors.getDeviceCount();
                    for (int i=0; i<ATTACHED_DS18B20; i++) {
                       present(i, S_TEMP);
                    for (int i=ATTACHED_DS18B20; i<ATTACHED_DS18B20+5; i++) {
                       present(i, S_HEATER);
                    //Serial.println(sensors.getResolution(D[i]), DEC);
                      if (temperature != -127.00 && temperature <= 85.00) {
                     for (int i=0; i<5;i++){
                      int value = analogRead(i);
                      /*Serial.print("Pin");
                      Serial.print(i);
                      Serial.print("=");
                      Serial.println(value);
                      int j=i+ATTACHED_DS18B20;
                      if (value>150) {
                        send(heat.setSensor(j).set(1));
                      else {
                        send(heat.setSensor(j).set(0));
                    sleep(SLEEP_TIME);
                  • pepsonP
                    pepsonP
                    pepson
                    And you dont use library onewire.h ?
                    F 1 Reply Last reply
                    • pepsonP pepson
                      F
                      F
                      flopp
                      I think it will be included in DallasTemperature.h.
                      Doesn’t my sketch work for you?
                      pepsonP 2 Replies Last reply
                      • F flopp
                        pepsonP
                        pepsonP
                        pepson
                        #32
                        @flopp
                        Probably tommorow I test your sketch and send you an info...
                        And what you mean in sketch write Heat?
                        And is any chance to modify this sketch and add value name "Description" to each sensor Dallas to send info to controller like Home Assistant to user can easily identify sensors in controller? What is what....
                        • F flopp
                          pepsonP
                          pepsonP
                          pepson
                          #33
                          @flopp
                          Hi
                          Tell me... is any chance to add in sketch position to write description for sensor and to send this description to Home Assistant....? It is ok write in other sketch for relay and it works perfect:
                          https://github.com/lkankowski/arduino-multi-relay/blob/master/arduino-multi-relay.ino
                          It show in Home Assisnatn this information in description example: Ł2 - kinkiet [C10]
                          • pepsonP pepson
                            @flopp
                            Hi
                            @pepson yes. Just change the present call, just like in your sketch.
                            Example: change
                            to
                            present(i, S_HEATER, "Description goes here");
                              Example: change
                              to
                              pepsonP
                              pepsonP
                              pepson
                              @mfalkvidd
                              OK but also must add defined description to all address. But how add also description?
                              rejoe2R 1 Reply Last reply
                              • pepsonP pepson
                                @mfalkvidd
                                rejoe2R
                                rejoe2R
                                rejoe2
                                @mfalkvidd
                                Don't know, if that really works, because I never tested it since my controller sw supports comments: https://github.com/rejoe2/MySensors-Dallas-Address-ChildID-Consistency/blob/master/DallasTemperatureSimple/DallasTemperatureSimple.ino
                                • rejoe2R rejoe2
                                  @mfalkvidd
                                  pepsonP
                                  pepsonP
                                  pepson
                                  @rejoe2
                                  But where in sketch you define address and description ?
                                  • pepsonP pepson
                                    @rejoe2
                                    rejoe2R
                                    rejoe2R
                                    rejoe2
                                    @pepson That's not necessary: The sketch reads the bus to get all the necessary info and will just send whatever is found.
                                    If you want a "hardcoded version", you'd have to addopt the sketch for something in between these variants: if you use an array for the 1-wire addresses like https://github.com/rejoe2/MySensors-Dallas-Address-ChildID-Consistency/blob/master/Dallas_Addresses_Array_Solution/Dallas_Addresses_Array_Solution.ino does, just built the comment char-array based on that info.
                                    • rejoe2R rejoe2
                                      pepsonP
                                      pepsonP
                                      pepson
                                      @rejoe2 said in About DS18B20 onewire.:
                                      Ok i know how add to present description , but still dont know how add description to each sensors.... as in sketch for relay as i show as example.
                                      • pepsonP pepson
                                        rejoe2R
                                        rejoe2R
                                        rejoe2
                                        @pepson I'd suggest you make a test with the "simple" variant of the sketches. Then we could lateron discuss how to deal with an array containing the hardcoded addresses.
                                        Pls. make also a test with the hardcoded version. Afai remember, it will print the needed array to serial, as long as #define PRINT_ARRAY isn't commented.
                                          Example: change
                                          to
                                          pepsonP
                                          pepsonP
                                          pepson
                                          @mfalkvidd Can you help me... or change it ?
                                          12.5k
