  3. About DS18B20 onewire.
dallasone wireonewireds18b20
48 Posts 5 Posters 19.2k Views 10 Watching
  • F
    F
    flopp
    @pepson said in About DS18B20 onewire.:
    byte D[3][8] = {
    { 0x28, 0xFB, 0x8F, 0x77, 0x91, 0x15, 0x02, 0x32 },
    { 0x28, 0xFF, 0x37, 0x77, 0x91, 0x18, 0x02, 0x16 }
    D[3] means 3 attached DS18B20, but you only have address for 2
    • F
      F
      flopp
      I have a sketch where I have attached 40 pcs mixed both DS18B20 and DS18S20, works perfect, except that sometimes I recevied 0 as value for some of them. I am polling every minute, so I don't care if the value is 0 for a couple of minutes, it is not that very important
      pepsonP 1 Reply Last reply
      • F flopp
        pepsonP
        pepsonP
        pepson
        @flopp
        But for what is number 8 in this ?
        byte D[3][8] = {
        On what MySensors you use it ?
        Previous sketch your in this thread i can not compile. I convert it as i show. You mean that sketch with 2 pcs dallas should look like this:
         * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
         * http://www.mysensors.org/build/temp
        #define MY_GATEWAY_SERIAL
        #include <OneWire.h>
        unsigned long SLEEP_TIME = 3000; // Sleep time between reads (in milliseconds)
        byte D[2][8] = {
        { 0x28, 0xC5, 0xBF, 0x77, 0x91, 0x16, 0x02, 0x1D }
        //MySensor gw;
        int numSensors=0;
        boolean receivedConfig = false;
        boolean metric = true;
        MyMessage msg(0,V_TEMP);
        void before()
          sensors.begin();
          // Startup and initialize MySensors library. Set callback for incoming messages.
        //  begin();
          sendSketchInfo("Temp. Sensor", "1.1");
          for (int i=0; i<3 && i<MAX_ATTACHED_DS18B20; i++) {
             present(i, S_TEMP);
        Serial.println(millis());
          // Process incoming messages (like config from server)
          //process();
          sleep(conversionTime);
            //float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(D[i]):sensors.getTempFByIndex(D[i])) * 10.)) / 10.;
            //float temperature = static_cast<float>(static_cast<int>((sensors.requestTemperaturesByAddress(D[i])) * 10.)) / 10.;
            float temperature = sensors.getTempC(D[i]);
            #if COMPARE_TEMP == 1
          sleep(SLEEP_TIME);
        And what command in sketch should be use:
        1. float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(D[i]):sensors.getTempFByIndex(D[i])) * 10.)) / 10.;
        2. float temperature = static_cast<float>(static_cast<int>((sensors.requestTemperaturesByAddress(D[i])) * 10.)) / 10.;
        3. float temperature = sensors.getTempC(D[i]);
        In original sketch from Mysensors he use this :
        And please share me sketch which you use with MySensors 2.x and with how system controller you use it ? I want use with Home Assistant.
        • F
          F
          flopp
          #define MY_NODE_ID 14
          #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
          #define ATTACHED_DS18B20 40
          unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
          byte D[ATTACHED_DS18B20][8] = {
          { 0x10, 0x04, 0xB8, 0x3F, 0x02, 0x08, 0x00, 0xBD }, //KökTbx
          { 0x10, 0xF4, 0xD7, 0x3F, 0x02, 0x08, 0x00, 0xB1 }, //UppTbx
          { 0x10, 0x92, 0x9F, 0x3E, 0x02, 0x08, 0x00, 0x98 }, //KökUt
          { 0x10, 0x4E, 0xE4, 0x3E, 0x02, 0x08, 0x00, 0x3C }, //ToaUt
          { 0x10, 0x1E, 0xE8, 0x3E, 0x02, 0x08, 0x00, 0x33 }, //EfterPump
          { 0x10, 0x09, 0xA1, 0x3E, 0x02, 0x08, 0x00, 0xF7 }, //HallTbx
          { 0x10, 0x59, 0xCB, 0x3F, 0x02, 0x08, 0x00, 0xFA }, //UppUt
          { 0x10, 0x07, 0x1B, 0x3F, 0x02, 0x08, 0x00, 0x99 }, //ToaTbx
          { 0x28, 0xFF, 0xB1, 0xAA, 0x63, 0x15, 0x03, 0xC8 }, //Kök
          { 0x10, 0x80, 0xB6, 0x3F, 0x02, 0x08, 0x00, 0x29 }, //Panna komp
          { 0x10, 0x3C, 0x9C, 0x3E, 0x02, 0x08, 0x00, 0x99 }, //Hall ut
          { 0x10, 0x42, 0xE0, 0x3F, 0x02, 0x08, 0x00, 0xD1 }, //Tvätt
          { 0x10, 0xCE, 0xE9, 0x3E, 0x02, 0x08, 0x00, 0x3A }, //T12
          { 0x10, 0x99, 0xAC, 0x3F, 0x02, 0x08, 0x00, 0x25 }, //V mellan
          { 0x10, 0x15, 0xDB, 0x3E, 0x02, 0x08, 0x00, 0x01 }, //Hallen
          { 0x10, 0xF3, 0xD7, 0x3F, 0x02, 0x08, 0x00, 0x34 }, //Panna El
          { 0x10, 0xFB, 0xCB, 0x3F, 0x02, 0x08, 0x00, 0xC8 }, //Toa Nere
          { 0x10, 0x97, 0x23, 0x3F, 0x02, 0x08, 0x00, 0x92 }, //Varmvatten
          { 0x10, 0x0F, 0xE6, 0x3E, 0x02, 0x08, 0x00, 0xFD }, //Carport
          { 0x10, 0xF3, 0xC6, 0x3F, 0x02, 0x08, 0x00, 0x85 }, //Förrådet
          { 0x10, 0x9C, 0x3B, 0x52, 0x02, 0x08, 0x00, 0x25 }, //Mark 60
          { 0x10, 0xF2, 0x24, 0x3F, 0x02, 0x08, 0x00, 0xEB }, //Vrum V
          { 0x10, 0x6A, 0x5E, 0x52, 0x02, 0x08, 0x00, 0x26 }, //Mark 30
          { 0x10, 0x76, 0xCE, 0x3F, 0x02, 0x08, 0x00, 0xBA }, //Plattan
          { 0x10, 0x0E, 0x7B, 0x13, 0x02, 0x08, 0x00, 0x7C }, //Utetemp
          { 0x10, 0xEE, 0xEB, 0x3E, 0x02, 0x08, 0x00, 0x0F }, //Uterum
          { 0x28, 0x8C, 0x2D, 0xB4, 0x04, 0x00, 0x00, 0x9C }, //Kyl uppe
          { 0x28, 0xFF, 0xB2, 0x74, 0x63, 0x15, 0x02, 0xCC }, //Kyl mitten
          { 0x28, 0xFF, 0x08, 0x07, 0x52, 0x04, 0x00, 0xFF }, //Kyl nere
          { 0x28, 0xFF, 0xE6, 0x06, 0x52, 0x04, 0x00, 0x08 }, //Frys uppe
          { 0x28, 0xFF, 0xB4, 0x07, 0x55, 0x04, 0x00, 0xEB }, //Kyl bakom
          { 0x10, 0x1C, 0xA8, 0x3F, 0x02, 0x08, 0x00, 0x3B }, //Lucas
          { 0x10, 0x83, 0x3C, 0x3F, 0x02, 0x08, 0x00, 0x06 }, //Allrum
          { 0x10, 0xA3, 0xE8, 0x3E, 0x02, 0x08, 0x00, 0x7E }, //Theo
          { 0x10, 0x33, 0x3C, 0x3F, 0x02, 0x08, 0x00, 0x01 }, //Sovrum
          { 0x28, 0xFF, 0xFB, 0x3D, 0xC3, 0x16, 0x03, 0x58 }, //Panna luft in(varm)
          { 0x28, 0xFF, 0xD4, 0x1C, 0x00, 0x17, 0x03, 0x43 }, //Dränering
          { 0x28, 0xFF, 0x97, 0x11, 0x01, 0x15, 0x04, 0xC0 } // Poolvatten
          float lastTemperature[ATTACHED_DS18B20];
          MyMessage heat(0,V_STATUS);
            sensors.begin();
            sendSketchInfo("OneWire Temp+Heating LED", "20180709");
            //numSensors = sensors.getDeviceCount();
            for (int i=0; i<ATTACHED_DS18B20; i++) {
               present(i, S_TEMP);
            for (int i=ATTACHED_DS18B20; i<ATTACHED_DS18B20+5; i++) {
               present(i, S_HEATER);
            //Serial.println(sensors.getResolution(D[i]), DEC);
           //   float temperature = static_cast<float>(static_cast<int>((sensors.requestTemperaturesByAddress(D[i])) * 10.)) / 10.;
              if (temperature != -127.00 && temperature <= 85.00) {
             for (int i=0; i<5;i++){
              int value = analogRead(i);
              /*Serial.print("Pin");
              Serial.print(i);
              Serial.print("=");
              Serial.println(value);
              int j=i+ATTACHED_DS18B20;
              if (value>150) {
                send(heat.setSensor(j).set(1));
              else {
                send(heat.setSensor(j).set(0));
            sleep(SLEEP_TIME);
          • pepsonP
            pepsonP
            pepson
            And you dont use library onewire.h ?
            F 1 Reply Last reply
            • pepsonP pepson
              F
              F
              flopp
              I think it will be included in DallasTemperature.h.
              Doesn’t my sketch work for you?
              pepsonP 2 Replies Last reply
              • F flopp
                pepsonP
                pepsonP
                pepson
                wrote on last edited by pepson
                #32
                @flopp
                Probably tommorow I test your sketch and send you an info...
                And what you mean in sketch write Heat?
                And is any chance to modify this sketch and add value name "Description" to each sensor Dallas to send info to controller like Home Assistant to user can easily identify sensors in controller? What is what....
                • F flopp
                  pepsonP
                  pepsonP
                  pepson
                  #33
                  @flopp
                  Hi
                  Tell me... is any chance to add in sketch position to write description for sensor and to send this description to Home Assistant....? It is ok write in other sketch for relay and it works perfect:
                  https://github.com/lkankowski/arduino-multi-relay/blob/master/arduino-multi-relay.ino
                  It show in Home Assisnatn this information in description example: Ł2 - kinkiet [C10]
                  • pepsonP pepson
                    @flopp
                    Hi
                    @pepson yes. Just change the present call, just like in your sketch.
                    Example: change
                    to
                    present(i, S_HEATER, "Description goes here");
                      Example: change
                      to
                      pepsonP
                      pepsonP
                      pepson
                      @mfalkvidd
                      OK but also must add defined description to all address. But how add also description?
                      rejoe2R 1 Reply Last reply
                      • pepsonP pepson
                        @mfalkvidd
                        rejoe2R
                        rejoe2R
                        rejoe2
                        @mfalkvidd
                        Don't know, if that really works, because I never tested it since my controller sw supports comments: https://github.com/rejoe2/MySensors-Dallas-Address-ChildID-Consistency/blob/master/DallasTemperatureSimple/DallasTemperatureSimple.ino
                        • rejoe2R rejoe2
                          @mfalkvidd
                          pepsonP
                          pepsonP
                          pepson
                          @rejoe2
                          But where in sketch you define address and description ?
                          • pepsonP pepson
                            @rejoe2
                            rejoe2R
                            rejoe2R
                            rejoe2
                            @pepson That's not necessary: The sketch reads the bus to get all the necessary info and will just send whatever is found.
                            If you want a "hardcoded version", you'd have to addopt the sketch for something in between these variants: if you use an array for the 1-wire addresses like https://github.com/rejoe2/MySensors-Dallas-Address-ChildID-Consistency/blob/master/Dallas_Addresses_Array_Solution/Dallas_Addresses_Array_Solution.ino does, just built the comment char-array based on that info.
                            • rejoe2R rejoe2
                              pepsonP
                              pepsonP
                              pepson
                              @rejoe2 said in About DS18B20 onewire.:
                              Ok i know how add to present description , but still dont know how add description to each sensors.... as in sketch for relay as i show as example.
                              • pepsonP pepson
                                rejoe2R
                                rejoe2R
                                rejoe2
                                @pepson I'd suggest you make a test with the "simple" variant of the sketches. Then we could lateron discuss how to deal with an array containing the hardcoded addresses.
                                Pls. make also a test with the hardcoded version. Afai remember, it will print the needed array to serial, as long as #define PRINT_ARRAY isn't commented.
                                  Example: change
                                  to
                                  pepsonP
                                  pepsonP
                                  pepson
                                  @mfalkvidd Can you help me... or change it ?
                                  • F flopp
                                      sensors.begin();
                                         present(i, S_TEMP);
                                        Serial.print(i);
                                        Serial.print("=");
                                        if (value>150) {
                                        else {
                                      sleep(SLEEP_TIME);
                                    pepsonP
                                    pepsonP
                                    pepson
                                    @flopp said in About DS18B20 onewire.:
                                      sensors.begin();
                                         present(i, S_TEMP);
                                        Serial.print(i);
                                        Serial.print("=");
                                        if (value>150) {
                                        else {
                                      sleep(SLEEP_TIME);
                                    When i try compile this sketch it get me error:
                                    C:\Users\Piotrek\Desktop\Temp dallas\Arduino_dallas_18B20_with_desc\Arduino_dallas_18B20_with_desc.ino: In function 'void presentation()':
                                    Arduino_dallas_18B20_with_desc:117:3: error: expected initializer before 'sensors'
                                    exit status 1
                                    • pepsonP pepson
                                        sensors.begin();
                                           present(i, S_TEMP);
                                          Serial.print(i);
                                          Serial.print("=");
                                          if (value>150) {
                                          else {
                                        sleep(SLEEP_TIME);
                                      exit status 1
                                      #43
                                      @pepson you have a stray } after setWaitForConversion
                                      Tip: use ctrl+t in the editor to easier see this type of mistake
                                        pepsonP
                                        pepsonP
                                        pepson
                                        @mfalkvidd
                                        Still is problem after use CTRL+T
                                           DESCRIPTION
                                        MyMessage msg(0, V_TEMP);
                                        MyMessage heat(0, V_STATUS);
                                          sensors.begin();
                                          for (int i = 0; i < ATTACHED_DS18B20; i++) {
                                            present(i, S_TEMP);
                                          for (int i = ATTACHED_DS18B20; i < ATTACHED_DS18B20 + 5; i++) {
                                              send(msg.setSensor(i).set(temperature, 1));
                                              lastTemperature[i] = temperature;
                                          for (int i = 0; i < 5; i++) {
                                              Serial.print(i);
                                              Serial.print("=");
                                            int j = i + ATTACHED_DS18B20;
                                            if (value > 150) {
                                            else {
                                          sleep(SLEEP_TIME);
                                        exit status 1
                                        • pepsonP pepson
                                          @mfalkvidd
                                             DESCRIPTION
                                            sensors.begin();
                                              present(i, S_TEMP);
                                                Serial.print(i);
                                                Serial.print("=");
                                              if (value > 150) {
                                              else {
                                            sleep(SLEEP_TIME);
                                          exit status 1
                                          @pepson you’re missing a } before start of loop.
                                          12.5k
