1.1k Posts 105 Posters 796.0k Views 98 Watching
  • monteM monte
    @bjacobse but it actually seems that he HAS a ground plane on one side of PCB, if you look closer at the third photo ;)
    bjacobseB
    bjacobseB
    bjacobse
    @monte I didn't notice this, but you are right, "hidden" LCD :-)
    bjacobseB 1 Reply Last reply
    • FotoFieberF FotoFieber
      My actual project is a doorbell sensor with additional temperature and humidity sensors. Tried different ways to detect the ring:
      • hall sensor (failed)
      • microphone (FFT, ongoing research)
      • optocoupler to detect the 12V AC -> favorite solution
      As I was heavy prototyping, I tried wire wrapping and it is fun:
      bjacobseB
      bjacobseB
      bjacobse
      @fotofieber
      Wirewrapping is an "old" and well proven technology, remember to have extra cable in case you need to re-wire your cables. Not so popular by DIY as tools used to be fairly expensive as it was protected by patents...
      • bjacobseB bjacobse
        bjacobseB
        bjacobseB
        bjacobse
        #722
        @bjacobse
        Just to add a little more info about adding a GND plane to your PCB
        I work in a electronic company, not doing PCB layout there though.
        but we have a TV adapter which have 2.4GHz transmitter. and this PCB is GND on both sides and with plenty GND via's (all the small holes) to ensure good grounding
        In case you wonder what it is, then it's an Oticon TV adapter 3.0
        https://www.youtube.com/watch?v=r4bTIQPdCEo
        • alowhumA
          alowhumA
          alowhum
          A picture from the touch screen version of the universal 433Mhz signal cloner.
          • kalinaK
            kalinaK
            kalina
            I have finished an enclosure for the my MDMSPanel "Nextion" today.
            4_1550659232406_Panel_5.png 3_1550659232406_Panel_4.png 2_1550659232405_Panel_3.png 1_1550659232405_Panel_2.png 0_1550659232404_Panel_1.png
            dbemowskD bjacobseB 2 Replies Last reply
            • alowhumA
              alowhumA
              alowhum
              #725
              Wow, very cool! Can you share a bit more about the project? Is it MySensors based? Is there code available? What does the hardware inside look like? What processor is it base on?
              Ah, scrolling up answered some of my questions :-)
              kalinaK 1 Reply Last reply
              • alowhumA alowhum
                kalinaK
                kalinaK
                kalina
                @alowhum Yes of course. I am going to publish this project this week.
                • kalinaK kalina
                  dbemowskD
                  dbemowskD
                  @kalina Kudos on the case. Is that a case you designed, or is it a prefab case that you bought somewhere? I am assuming that from the markings inside the case that it is a prefab.I do like the design though and love it's underlying project. Is that just a thermostat, or is it a multi option controller?
                  • dbemowskD dbemowsk
                    kalinaK
                    kalinaK
                    kalina
                    @dbemowsk Yes, it is a factory case, and before the changing it looked like this :
                    At the moment this is termostat, but I will not limit myself to this)) The purpose of the panel will be determined by the software project loaded into it. I will describe this in more detail when I publish the project.
                    dbemowskD 1 Reply Last reply
                    • kalinaK kalina
                      bjacobseB
                      bjacobseB
                      bjacobse
                      @kalina
                      Yes it's very impressing what you have achieved
                      • kalinaK kalina
                        dbemowskD
                        dbemowskD
                        @kalina I like that case design so much that I may design one like it in OpenSCAD and post it on thingiverse.
                          @kalina
                          kalinaK
                          kalinaK
                          kalina
                          #731
                          @bjacobse said in What did you build today (Pictures) ?:
                          Thanks, the project is published already.
                          https://www.openhardware.io/view/676/MDMSPanel-Nextion
                          • FotoFieberF
                            FotoFieberF
                            FotoFieber
                            Building a (xenon) flash to notify alarms. Flashes every 5 seconds if activated.
                            • sundberg84S
                              sundberg84S
                              O 1 Reply Last reply
                              • sundberg84S
                                sundberg84S
                                Today I made a iscp pogo pin adapter... Great for uploading bootloaders.
                                • berkseoB
                                  berkseoB
                                  berkseo
                                  Almost finished one of my projects. The test sketch showed that HW works as it should. Now i need to make good software.
                                  https://youtu.be/dfhDseDaGiA
                                  • sundberg84S sundberg84
                                    O
                                    O
                                    Omemanti
                                    @sundberg84 that board looks nice and crisp 👍
                                    • berkseoB
                                      berkseoB
                                      berkseo
                                      Birth of water leakage sensor:) on mysensors..
                                      https://youtu.be/xsoeffaGAG0
                                      • O
                                        O
                                        Omemanti
                                        wrote on last edited by Omemanti
                                        #738
                                        After months of slow painstaking work (day job is somewhat busy, o and the kids ;) ) I finally completed my Domoticz server(case) with Dashticz as frontend.
                                        The Endgame; when my new house is finished every room is monitored for motion, RH and Temperature using my MySensors PCB's. (Jung AS500 Node)
                                        Everything is monitored using a raspberry with a MySensors serial gateway (NRF52) and an RFLink controller for my KAKU switches.
                                        To make everything nice and shiny I use Dasticz to interface the data in a proper way using a tablet that somehow will be mounted on a wall or something.
                                        So far the introduction;
                                        To put everything away nice and tidy I used a box to install everything using 2 pieces of din-rail.
                                        It has a 230V inlet that is converted to 5V using an off the shelf (safety sake) MeanWell RS-15-5 converter. This powers everything using a couple of din-Rail terminals.
                                        • Terminal => USB-micro => Raspberry
                                        • Terminal => just a couple of wires => old nrf52 prototype => FTDI => Raspberry
                                        • Raspberry => RF-link (ard. Mega +433mhz)
                                        Since the Raspberry has Wifi no other cable then power is needed to operate
                                        Second part: the 2 screenshots of dasthicsz.
                                        The best part, it took some work, but the WAF incread big time, because everything looks clean :)
                                        • O Omemanti
                                          dbemowskD
                                          dbemowskD
                                          @omemanti Nice DIN rail enclosure.
