  3. 💬 AM612 Passive Infrared Sensor Breakout Board
41 Posts 12 Posters 10.5k Views 9 Watching
  • W waspie
    @mfalkvidd
    yeah, I don't think that's working. I think I may understand better why not, so correct me if I'm wrong.
    The low power comparator only works on analog inputs and in the nrf51 board by @NeverDie the SCL marked pin on the board is tied to P0.10 which has no analog input on it.
    So, what I think I need to do is cut the trace and re-route it to the INT marked on the board which is tied to P0.03 which is analog 1 (AIN1). At that point then I think I only need to change the line in the sketch to use pin 3 instead of 2.
    @waspie sorry. I didn't realize you're using NRF5. I thought you wanted to connect it to a "regular" Arduino like Nano or Pro Mini.
    I don't have any experience with NRF5 unfortunately, but hopefully someone else can help.
    • W waspie
      does anyone have a sample sketch for this. i don't understand the whole pin assignment thing well enough to know what the heck i'm doing.
      I grabbed the sketch from the 10 year pir but this seems much more geared to the nrf52
      O
      O
      Omemanti
      wrote on last edited by Omemanti
      @waspie you might want to look at one of my projects on openhardware. It has a sketch on it. It also uses the am612
      • W
        W
        waspie
        I'm really not too good at writing arduino code but I did come across this library:
        https://github.com/mristau/Arduino_nRF5x_lowPower
        Is this something that could be incorporated into the sketch and then use "normal" interrupts?
        • nagelcN
          nagelcN
          nagelc
          wrote on last edited by nagelc
          Don't cut your trace just yet. You can use normal interrupts with MySensors and NRF5, at least if you are sleeping the node. I have used the normal Mysensors sleep statement, with interrupts for buttons, and not had to use the LPCOMP. The motion sensor should work similarly. I have used interrupts on P0.27 for a button interupt, which is regular GPIO pin and not an analog pin. I have also used 2 interrupts in the sleep statement, which means the MySensors NRF5 code probably uses GPIOTE instead of LPCOMP for interrupts. Might not be as low power as LPCOMP, but it seems to be more flexible.
          I used an NRF52832, haven't tried with a NRF51 board.
          O 1 Reply Last reply
          • nagelcN nagelc
            O
            O
            Omemanti
            @nagelc I also use normal interrupts. No problems here. Up to 22uA while sleeping, that's fine by me. (3 AAA will last a long time)
            • W
              W
              waspie
              yeah well i got a few nrf51822 which was evidently a big mistake
              • W waspie
                O
                O
                Omemanti
                @waspie why?
                • W
                  W
                  waspie
                  They don't seem to play well and seems like most or any of you guys messing with NRF5x are preferring nrf52.
                  I have however figured out one problem. Whenever my nrf51 was sleeping i was seeing 1ma current which is a deal killer. I accidentally discovered that disconnecting the st link and replugging it got sleep current to ~5ua. Something about uploading the program puts it in some state whereby it won't sleep properly.
                  So, I can get it to sleep all the way down now and I'm starting to understand the psel refsel stuff. And, I can make it trigger on p0.03 (an4 or 5, whatever) but its not particularly reliable. I need to get this section right:
                  void activateLpComp() {
                    NRF_LPCOMP->PSEL=4; // monitor AIN0 (i.e. pin P0.02 on nRF52832 PIR Motion Sensor v607).
                    while (!(NRF_LPCOMP->PSEL==4)) {} //wait until confirmed
                    NRF_LPCOMP->REFSEL=2;  // choose 1/2 VDD as the reference voltage
                    while (!(NRF_LPCOMP->REFSEL==2)) {} //wait until confirmed
                    NRF_LPCOMP->ANADETECT=0;  //detect CROSS events on PIR detection pin
                    while (NRF_LPCOMP->ANADETECT!=0) {} //wait until confirmed
                    NRF_LPCOMP->INTENSET=B1000;  //Enable interrupt for CROSS event
                    while (!(((NRF_LPCOMP->INTENSET)&B1000)==B1000)) {} //wait until confirmed
                    NVIC_EnableIRQ(LPCOMP_IRQn);
                  • W
                    W
                    waspie
                    It's looking more and more like the code is fine and its the sensors i'm using that are the problem.
                    I got some BM612 (cheaper) from ali supposedly the same as am612 but they don't seem to work right. It's like they trigger once and then never again. Can't find a data sheet for them...
                    I hooked up a 312 just for kicks and it seems to be working. I doubt I'll deploy any 312s due to what seems to be a VERY narrow range and plus it doesn't match the profile of the round board etc...
                    Anyway, wanted to say that i think this is all working as its supposed to I just got a bad batch of sensors or they're slightly different in some way
                    • W
                      W
                      waspie
                      For anyone looking to use @NeverDie 's nrf51 circular board (v9) with this breakout - I'm using the sketch as linked from @Nca78 in this post: https://forum.mysensors.org/topic/6961/nrf5-action/1542
                      in conjunction with the edit to the file as described in this post:
                      https://forum.mysensors.org/topic/6961/nrf5-action/1514 (the edit to WInterrupt.c and I'm using version 0.6.0 from sandeep)
                      with just a few minor edits to the sketch from Nca (setting the pin to 10 (sda marked on the circular board).
                      14ua idle current btw, working like a charm. so far i'm just using a 2032. Trying to figure out a way to strap a cr2450 or 2477 on the back :)
                      nithinoN 1 Reply Last reply
                      • W waspie
                        nithinoN
                        nithinoN
                        nithino
                        @waspie Apologies for resurrecting this thread after two years. I have quite a few NRF51822 boards with me. I would like to put it to use. Can you please share your code as following these links did not help me compile the sketch. Too many errors. Thanks in advance.
                        • G
                          G
                          gulsimsur
                          Banned
                          G 1 Reply Last reply
                          • G gulsimsur
                            G
                            G
                            gulsimsur
                            Banned
                            #28
                            @gulsimsur said in 💬 AM612 Passive Infrared Sensor Breakout Board:
                            E 1 Reply Last reply
                            • G gulsimsur
                              E
                              E
                              ejlane
                              @gulsimsur Why are there links to surveyzop in your reply?
                                MasterCATZ
                                Thanks for the breakout board, but would it be too much to ask for a revision that can have potentiometers mounted?
                                so resistors do not need to be changed when tinkering with 15x settings? either SMD or Through-Hole Trimmer
                                0-300k None?,0-1M
                                  MasterCATZ
                                  Or a 12x DIP switch and a Jumper
                                  Jumper for the shortest and longest Time settings
                                  Then pads for installing the 12 Resistors for Time in Seconds the LED / Relay etc is activated for ?
                                  also, how were you mounting these boards with no screw holes? just something for the lens cover to clip into
                                  • M MasterCATZ
                                    #32
                                    @MasterCATZ That's a reasonable request. In the future whenever I post a board to openhardware.io, I'll endeavor to include the complete set of KiCAD 6 files needed to make simple changes like this, so then I'm not the bottleneck. However, I did this work, and most of my other work to date, in Diptrace, which AFAIK doesn't allow that kind of easy change by other people.
                                    Meanwhile, if anyone wants to re-do the board and post it with the asked-for change, feel free. Because I don't have that need myself, I won't be doing it, because it involves also spending time finding files in some forgotten archive from 5 years ago in order to resurrect it even before making the change.
                                    In any case, I'm glad that at least some people have found it useful, which is why I posted it in the first place. :-)
                                      MasterCATZ
                                      all good at least I can steal your sensor hole placements and can stumble along modding in KiCAD
                                      tho unsure why the board size is smaller when I converted it it seems to trim along where the cover's holes are and not leaving any meat behind
                                      did you come across any other sensors better than this for the price?
                                      • W waspie
                                        MasterCATZ
                                        @waspie
                                        https://robu.in/wp-content/uploads/2020/09/Pir-BM612.pdf
                                        planning on switching over to these as well
                                        sensitivity setting and better times
                                        • M MasterCATZ
                                          #35
                                          @MasterCATZ said in 💬 AM612 Passive Infrared Sensor Breakout Board:
                                          I vaguely recollect having since come across a newer aliexpress sensor with an even lower power consumption, but I can't say for sure. If that matters to you, it may be worth checking. It wouldn't surprise me, as there is constant progress, and 5 years is a long time.
                                          12.5k
