  3. About DS18B20 onewire.
dallasone wireonewireds18b20
48 Posts 5 Posters 19.0k Views 10 Watching
  • pepsonP pepson
    @mfalkvidd
    OK but also must add defined description to all address. But how add also description?
    rejoe2R
    rejoe2R
    rejoe2
    @pepson said in About DS18B20 onewire.:
    @mfalkvidd
    Don't know, if that really works, because I never tested it since my controller sw supports comments: https://github.com/rejoe2/MySensors-Dallas-Address-ChildID-Consistency/blob/master/DallasTemperatureSimple/DallasTemperatureSimple.ino
    pepsonP 1 Reply Last reply
    • rejoe2R rejoe2
      @mfalkvidd
      pepsonP
      pepsonP
      pepson
      @rejoe2
      But where in sketch you define address and description ?
      rejoe2R 1 Reply Last reply
      • pepsonP pepson
        @rejoe2
        rejoe2R
        rejoe2R
        rejoe2
        @pepson That's not necessary: The sketch reads the bus to get all the necessary info and will just send whatever is found.
        If you want a "hardcoded version", you'd have to addopt the sketch for something in between these variants: if you use an array for the 1-wire addresses like https://github.com/rejoe2/MySensors-Dallas-Address-ChildID-Consistency/blob/master/Dallas_Addresses_Array_Solution/Dallas_Addresses_Array_Solution.ino does, just built the comment char-array based on that info.
        • rejoe2R rejoe2
          pepsonP
          pepsonP
          pepson
          @rejoe2 said in About DS18B20 onewire.:
          Ok i know how add to present description , but still dont know how add description to each sensors.... as in sketch for relay as i show as example.
          • pepsonP pepson
            rejoe2R
            rejoe2R
            rejoe2
            @pepson I'd suggest you make a test with the "simple" variant of the sketches. Then we could lateron discuss how to deal with an array containing the hardcoded addresses.
            Pls. make also a test with the hardcoded version. Afai remember, it will print the needed array to serial, as long as #define PRINT_ARRAY isn't commented.
              @pepson yes. Just change the present call, just like in your sketch.
              Example: change
              present(i, S_HEATER);
              to
              present(i, S_HEATER, "Description goes here");
              pepsonP
              pepsonP
              pepson
              @mfalkvidd Can you help me... or change it ?
              • F flopp
                 * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
                 * http://www.mysensors.org/build/temp
                #define MY_NODE_ID 14
                #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
                #define ATTACHED_DS18B20 40
                unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                byte D[ATTACHED_DS18B20][8] = {
                { 0x10, 0x04, 0xB8, 0x3F, 0x02, 0x08, 0x00, 0xBD }, //KökTbx
                { 0x10, 0xF4, 0xD7, 0x3F, 0x02, 0x08, 0x00, 0xB1 }, //UppTbx
                { 0x10, 0x92, 0x9F, 0x3E, 0x02, 0x08, 0x00, 0x98 }, //KökUt
                { 0x10, 0x4E, 0xE4, 0x3E, 0x02, 0x08, 0x00, 0x3C }, //ToaUt
                { 0x10, 0x1E, 0xE8, 0x3E, 0x02, 0x08, 0x00, 0x33 }, //EfterPump
                { 0x10, 0x09, 0xA1, 0x3E, 0x02, 0x08, 0x00, 0xF7 }, //HallTbx
                { 0x10, 0x59, 0xCB, 0x3F, 0x02, 0x08, 0x00, 0xFA }, //UppUt
                { 0x10, 0x07, 0x1B, 0x3F, 0x02, 0x08, 0x00, 0x99 }, //ToaTbx
                { 0x28, 0xFF, 0xB1, 0xAA, 0x63, 0x15, 0x03, 0xC8 }, //Kök
                { 0x10, 0x80, 0xB6, 0x3F, 0x02, 0x08, 0x00, 0x29 }, //Panna komp
                { 0x10, 0x3C, 0x9C, 0x3E, 0x02, 0x08, 0x00, 0x99 }, //Hall ut
                { 0x10, 0x42, 0xE0, 0x3F, 0x02, 0x08, 0x00, 0xD1 }, //Tvätt
                { 0x10, 0xCE, 0xE9, 0x3E, 0x02, 0x08, 0x00, 0x3A }, //T12
                { 0x10, 0x99, 0xAC, 0x3F, 0x02, 0x08, 0x00, 0x25 }, //V mellan
                { 0x10, 0x15, 0xDB, 0x3E, 0x02, 0x08, 0x00, 0x01 }, //Hallen
                { 0x10, 0xF3, 0xD7, 0x3F, 0x02, 0x08, 0x00, 0x34 }, //Panna El
                { 0x10, 0xFB, 0xCB, 0x3F, 0x02, 0x08, 0x00, 0xC8 }, //Toa Nere
                { 0x10, 0x97, 0x23, 0x3F, 0x02, 0x08, 0x00, 0x92 }, //Varmvatten
                { 0x10, 0x0F, 0xE6, 0x3E, 0x02, 0x08, 0x00, 0xFD }, //Carport
                { 0x10, 0xF3, 0xC6, 0x3F, 0x02, 0x08, 0x00, 0x85 }, //Förrådet
                { 0x10, 0x9C, 0x3B, 0x52, 0x02, 0x08, 0x00, 0x25 }, //Mark 60
                { 0x10, 0xF2, 0x24, 0x3F, 0x02, 0x08, 0x00, 0xEB }, //Vrum V
                { 0x10, 0x6A, 0x5E, 0x52, 0x02, 0x08, 0x00, 0x26 }, //Mark 30
                { 0x10, 0x76, 0xCE, 0x3F, 0x02, 0x08, 0x00, 0xBA }, //Plattan
                { 0x10, 0x0E, 0x7B, 0x13, 0x02, 0x08, 0x00, 0x7C }, //Utetemp
                { 0x10, 0xEE, 0xEB, 0x3E, 0x02, 0x08, 0x00, 0x0F }, //Uterum
                { 0x28, 0x8C, 0x2D, 0xB4, 0x04, 0x00, 0x00, 0x9C }, //Kyl uppe
                { 0x28, 0xFF, 0xB2, 0x74, 0x63, 0x15, 0x02, 0xCC }, //Kyl mitten
                { 0x28, 0xFF, 0x08, 0x07, 0x52, 0x04, 0x00, 0xFF }, //Kyl nere
                { 0x28, 0xFF, 0xE6, 0x06, 0x52, 0x04, 0x00, 0x08 }, //Frys uppe
                { 0x28, 0xFF, 0xB4, 0x07, 0x55, 0x04, 0x00, 0xEB }, //Kyl bakom
                { 0x10, 0x1C, 0xA8, 0x3F, 0x02, 0x08, 0x00, 0x3B }, //Lucas
                { 0x10, 0x83, 0x3C, 0x3F, 0x02, 0x08, 0x00, 0x06 }, //Allrum
                { 0x10, 0xA3, 0xE8, 0x3E, 0x02, 0x08, 0x00, 0x7E }, //Theo
                { 0x10, 0x33, 0x3C, 0x3F, 0x02, 0x08, 0x00, 0x01 }, //Sovrum
                { 0x28, 0xFF, 0xFB, 0x3D, 0xC3, 0x16, 0x03, 0x58 }, //Panna luft in(varm)
                { 0x28, 0xFF, 0xD4, 0x1C, 0x00, 0x17, 0x03, 0x43 }, //Dränering
                { 0x28, 0xFF, 0x97, 0x11, 0x01, 0x15, 0x04, 0xC0 } // Poolvatten
                float lastTemperature[ATTACHED_DS18B20];
                MyMessage msg(0,V_TEMP);
                MyMessage heat(0,V_STATUS);
                  sensors.begin();
                  sendSketchInfo("OneWire Temp+Heating LED", "20180709");
                  //numSensors = sensors.getDeviceCount();
                  for (int i=0; i<ATTACHED_DS18B20; i++) {
                     present(i, S_TEMP);
                  for (int i=ATTACHED_DS18B20; i<ATTACHED_DS18B20+5; i++) {
                  sleep(conversionTime);
                  //Serial.println(sensors.getResolution(D[i]), DEC);
                 //   float temperature = static_cast<float>(static_cast<int>((sensors.requestTemperaturesByAddress(D[i])) * 10.)) / 10.;
                      float temperature = sensors.getTempC(D[i]);
                    #if COMPARE_TEMP == 1
                    if (temperature != -127.00 && temperature <= 85.00) {
                   for (int i=0; i<5;i++){
                    int value = analogRead(i);
                    /*Serial.print("Pin");
                    Serial.print(i);
                    Serial.print("=");
                    Serial.println(value);
                    int j=i+ATTACHED_DS18B20;
                    if (value>150) {
                      send(heat.setSensor(j).set(1));
                    else {
                      send(heat.setSensor(j).set(0));
                  sleep(SLEEP_TIME);
                pepsonP
                pepsonP
                pepson
                @flopp said in About DS18B20 onewire.:
                  sensors.begin();
                     present(i, S_TEMP);
                    Serial.print(i);
                    Serial.print("=");
                    if (value>150) {
                    else {
                  sleep(SLEEP_TIME);
                When i try compile this sketch it get me error:
                C:\Users\Piotrek\Desktop\Temp dallas\Arduino_dallas_18B20_with_desc\Arduino_dallas_18B20_with_desc.ino: In function 'void presentation()':
                Arduino_dallas_18B20_with_desc:117:3: error: expected initializer before 'sensors'
                exit status 1
                • pepsonP pepson
                    sensors.begin();
                       present(i, S_TEMP);
                      Serial.print(i);
                      Serial.print("=");
                      if (value>150) {
                      else {
                    sleep(SLEEP_TIME);
                  exit status 1
                  #43
                  @pepson you have a stray } after setWaitForConversion
                  Tip: use ctrl+t in the editor to easier see this type of mistake
                    pepsonP
                    pepsonP
                    pepson
                    @mfalkvidd
                    Still is problem after use CTRL+T
                       DESCRIPTION
                    #define MY_GATEWAY_SERIAL
                    MyMessage msg(0, V_TEMP);
                    MyMessage heat(0, V_STATUS);
                      sensors.begin();
                      for (int i = 0; i < ATTACHED_DS18B20; i++) {
                        present(i, S_TEMP);
                      for (int i = ATTACHED_DS18B20; i < ATTACHED_DS18B20 + 5; i++) {
                          send(msg.setSensor(i).set(temperature, 1));
                          lastTemperature[i] = temperature;
                      for (int i = 0; i < 5; i++) {
                          Serial.print(i);
                          Serial.print("=");
                        int j = i + ATTACHED_DS18B20;
                        if (value > 150) {
                        else {
                      sleep(SLEEP_TIME);
                    exit status 1
                    • pepsonP pepson
                      @mfalkvidd
                         DESCRIPTION
                        sensors.begin();
                          present(i, S_TEMP);
                            Serial.print(i);
                            Serial.print("=");
                          if (value > 150) {
                          else {
                        sleep(SLEEP_TIME);
                      exit status 1
                      @pepson you’re missing a } before start of loop.
                        pepsonP
                        pepsonP
                        pepson
                        @mfalkvidd
                        Where ? please show me more.... :( i am beginner
                        • pepsonP pepson
                          @mfalkvidd
                          pepsonP
                          pepsonP
                          pepson
                          @pepson ok fixed it :)
                          • pepsonP
                            pepsonP
                            pepson
                            But.... Can you also help me to add to this sketch option to send to example to Home Assistant also DESCRIPTION to each sensors ? And description will be get from sketch from name about address sensor ?
                            As in this sketch which i have for relay:
                            #define USE_EXPANDER
                            #ifdef USE_EXPANDER
                              #include <Wire.h>    // Required for I2C communication
                              #include "PCF8574.h"
                              uint8_t expanderAddresses[] = {0x20};
                              const int numberOfExpanders = sizeof(expanderAddresses);
                              PCF8574 expander[numberOfExpanders];
                              #define E(expanderNo, ExpanderPin) (((expanderNo+1)<<8) | (ExpanderPin))
                            // No Button Constant
                            #define NOB -1
                            #define MULTI_RELAY_VERSION 9
                            #define RELAY_STATE_STORAGE 1
                            const uint8_t RELAY_TRIGGER_LOW  = 0;
                            const uint8_t RELAY_TRIGGER_HIGH = 1;
                            const uint8_t RELAY_STARTUP_ON   = 2;
                            const uint8_t RELAY_STARTUP_OFF  = 4;
                            const uint8_t RELAY_STARTUP_MASK = RELAY_STARTUP_ON | RELAY_STARTUP_OFF;
                            enum ButtonType {
                              MONO_STABLE = 0,
                              BI_STABLE = 1,
                              DING_DONG = 2 // HIGH state immediatly after push, LOW state after release
                            typedef struct {
                              int sensorId;
                              int relay;
                              int button;
                              uint8_t relayOptions;
                              ButtonType buttonType;
                              const char * relayDescription;
                            } RelayButton;
                            // CONFIGURE ONLY THIS ARRAY!
                            // Row params: sensor ID - sensor ID reported on MySensor Gateway
                            //             relay pin - Expander supported
                            //             button pin - <0 for virtual buttons (only available in MySensor Gateway); no support for Expander
                            //             relay options - [RELAY_TRIGGER_LOW|RELAY_TRIGGER_HIGH] {RELAY_STARTUP_ON|RELAY_STARTUP_OFF}
                            //             button type - [MONO_STABLE|BI_STABLE|DING_DONG]
                            //             relay description - reported on MySensor Gateway, can help identify device on initial configuration in Home Automation App, can be empty ("")
                            RelayButton myRelayButtons[] = {
                              {0, 2, A0, RELAY_TRIGGER_LOW, MONO_STABLE, "Ł2 - kinkiet [C10]"},  // WŁ: Ł2
                              {1, 16, A1, RELAY_TRIGGER_LOW, BI_STABLE, "Salon 2 [A9]"},  // WŁ: Salon 2
                              {2, 15, A2, RELAY_TRIGGER_LOW, BI_STABLE, "Salon 1 [A10]"},  // WŁ: Salon 1
                              {3, E(0,1), A3, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, BI_STABLE, "Halogen - Taras [B8]"},  // WŁ: Taras
                              {4, 22, A4, RELAY_TRIGGER_LOW, BI_STABLE, "Kuchnia [B2]"},  // WŁ: Kuchnia 1
                              {5, 23, A5, RELAY_TRIGGER_LOW, BI_STABLE, "Kuchnia - Kinkiet [B3]"},  // WŁ: Kuchnia 2
                              {6, 28, A6, RELAY_TRIGGER_LOW, BI_STABLE, "Jadalnia 2 [A4]"},  // WŁ: Hall I/Jadalnia prawy
                              {17, 17, A7, RELAY_TRIGGER_LOW, BI_STABLE, "Ł1 - Kinkiet [A11]"},  // WŁ: Hall I/Ł1 prawy
                              {8, 31, A8, RELAY_TRIGGER_LOW, MONO_STABLE, "Garaż [A7]"},  // WŁ: Kotłownia/Garaż
                              {8, 31, A9, RELAY_TRIGGER_LOW, MONO_STABLE, "Garaż [A7]"},  // WŁ: Garaż
                              {10, 14, A10, RELAY_TRIGGER_LOW | RELAY_STARTUP_ON, BI_STABLE, "Halogen - wejście [B4]"},  // WŁ: Drzwi wejściowe
                              {11, E(0,7), A11, RELAY_TRIGGER_LOW, DING_DONG, "Dzwonek [?]"},  // WŁ: Dzwonek
                              {12, 29, A12, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 1 [A5]"},  // WŁ: Hall I/Jadalnia lewy
                              {12, 29, A13, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 1 [A5]"},  // WŁ: Hall I/Wiatrołap
                              {14, 32, A14, RELAY_TRIGGER_LOW, BI_STABLE, "Wiatrołap [A8]"},  // WŁ: Wiatrołap/Hall I
                              {15, 19, A15, RELAY_TRIGGER_LOW, MONO_STABLE, "Kotłownia [B1]"},  // WŁ: Kotłownia/Hall I
                              {16, 24, 53, RELAY_TRIGGER_LOW, BI_STABLE, "Ł1 - Taśma LED [C1]"},  // WŁ: Hall I/Ł1 środek
                              {17, 17, 52, RELAY_TRIGGER_LOW, MONO_STABLE, "Ł1 - Kinkiet [A11]"},  // WŁ: Ł1
                              {18, 18, 51, RELAY_TRIGGER_LOW, BI_STABLE, "Ł1 [A12]"},  // WŁ: Hall I/Ł1 lewy
                              {19, 6, 50, RELAY_TRIGGER_LOW, BI_STABLE, "Klatka Schodowa [B7]"},  // WŁ: Hall I/Schody 1
                              {12, 29, 49, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 1 [A5]"},  // WŁ: Hall I/Schody 2
                              {21, 26, 48, RELAY_TRIGGER_LOW, BI_STABLE, "Gabinet [A2]"},  // WŁ: Gabinet
                              {22, 7, 47, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 2 [B5]"},  // WŁ: Hall II/Schody 1
                              {19, 6, 46, RELAY_TRIGGER_LOW, BI_STABLE, "Klatka Schodowa [B7]"},  // WŁ: Hall II/Schody 2
                              {24, 10, 45, RELAY_TRIGGER_LOW, BI_STABLE, "Garderoba [C12]"},  // WŁ: Garderoba
                              {25, 4, 44, RELAY_TRIGGER_LOW, MONO_STABLE, "Pok. nad kuchnią 2 [B10]"},  // WŁ: Pok. nad kuchnią 2
                              {26, 5, 43, RELAY_TRIGGER_LOW, BI_STABLE, "Pok. nad kuchnią 1 [B9]"},  // WŁ: Pok. nad kuchnią 1
                              {27, 8, 42, RELAY_TRIGGER_LOW, BI_STABLE, "Pok. nad salonem 2 [B12]"},  // WŁ: Pok. nad salonem 2
                              {28, 9, 41, RELAY_TRIGGER_LOW, MONO_STABLE, "Pok. nad salonem 1 [B11]"},  // WŁ: Pok. nad salonem 1
                              {29, 3, 40, RELAY_TRIGGER_LOW, BI_STABLE, "Ł2 [C7]"},  // WŁ: Hall II/Ł2 1
                              {30, E(0,3), 39, RELAY_TRIGGER_LOW, BI_STABLE, "Ł2 - Taśma LED [?]"},  // WŁ: Hall II/Ł2 2
                              {22, 7, 38, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 2 [B5]"},  // WŁ: Hall II/Sypialnia
                              {32, 11, 37, RELAY_TRIGGER_LOW, BI_STABLE, "Sypialnia 2 [C9]"},  // WŁ: Sypialnia 2
                              {33, 12, 36, RELAY_TRIGGER_LOW, BI_STABLE, "Sypialnia 1 [C8]"},  // WŁ: Sypialnia 1
                              {34, 25, -1, RELAY_TRIGGER_LOW | RELAY_STARTUP_ON, MONO_STABLE, "Halogen - Garaż [A1]"},  // WŁ: Virtual Button 1
                              {35, 30, -2, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, MONO_STABLE, "Ł1 - Wentylator [A3]"},  // WŁ: Virtual Button 2
                              {36, E(0,2), -3, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, MONO_STABLE, "Halogen - wschód [B6]"},  // WŁ: Virtual Button 3
                              {37, E(0,4), -4, RELAY_TRIGGER_LOW, MONO_STABLE, "Lampki schodowe [C6]"},  // WŁ: Virtual Button 4
                              {38, E(0,5), -5, RELAY_TRIGGER_LOW, MONO_STABLE, "Lampki podłogowe I [C4]"},  // WŁ: Virtual Button 5
                              {39, E(0,6), -6, RELAY_TRIGGER_LOW, MONO_STABLE, "Lampki podłogowe II [C2]"},  // WŁ: Virtual Button 6
                              {40, E(0,0), -7, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, MONO_STABLE, "Ł2 - wentylator [C11]"},  // WŁ: Virtual Button 7
                            const int numberOfRelayButtons = sizeof(myRelayButtons) / sizeof(RelayButton);
                            typedef struct {
                              int firstButton;
                              int nextButton;
                            } RelayMultiButtons;
                            RelayMultiButtons relayMultiButtons[numberOfRelayButtons];
                            uint8_t myRelayState[numberOfRelayButtons];
                            // MySensors - Sending Data
                            // To send data you have to create a MyMessage container to hold the information.
                            MyMessage msgs[numberOfRelayButtons];
                            Bounce myButtonDebouncer[numberOfRelayButtons];
                            //Function Declaration
                            uint8_t loadRelayState(int relayNum, uint8_t forceEeprom = 0);
                            void saveRelayState(int relayNum, uint8_t state, uint8_t useEeprom);
                            void saveRelayState(int relayNum, uint8_t state);
                            void changeRelayState(int relayNum, uint8_t relayState);
                            // MySensors - This will execute before MySensors starts up
                            void before() {
                              #ifdef USE_EXPANDER
                                /* Start I2C bus and PCF8574 instance */
                                for(int i = 0; i < numberOfExpanders; i++) {
                                  expander[i].begin(expanderAddresses[i]);
                              // initialize multiple buttons list structure
                              for (int i = 0; i < numberOfRelayButtons; i++) {
                                relayMultiButtons[i].firstButton = -1;
                                relayMultiButtons[i].nextButton = -1;
                              // find multiple buttons for the same relay (uni-directional list)
                              for (int i = 0; i < numberOfRelayButtons-1; i++) {
                                if (relayMultiButtons[i].firstButton == -1) {
                                  int prevRelayButton = i;
                                  for (int j = i+1; j < numberOfRelayButtons; j++) {
                                    if (myRelayButtons[i].relay == myRelayButtons[j].relay) {
                                      relayMultiButtons[prevRelayButton].firstButton = i;
                                      relayMultiButtons[prevRelayButton].nextButton = j;
                                      relayMultiButtons[j].firstButton = i;
                                      prevRelayButton = j;
                              // if version has changed, reset state of all relays
                              int versionChangeResetState = (MULTI_RELAY_VERSION == loadState(0) ) ? 0 : 1;
                                // if this relay has multiple buttons, load only first
                                if (relayMultiButtons[i].firstButton == -1 || relayMultiButtons[i].firstButton == i) {
                                  #ifdef USE_EXPANDER
                                    if ( myRelayButtons[i].relay & 0xff00 ) {
                                      // EXPANDER
                                      int expanderNo = (myRelayButtons[i].relay >> 8) - 1;
                                      int expanderPin = myRelayButtons[i].relay & 0xff;
                                      expander[expanderNo].pinMode(expanderPin, OUTPUT);
                                      pinMode(myRelayButtons[i].relay, OUTPUT);
                                  #ifdef USE_EXPANDER
                                  uint8_t isTurnedOn = 0;
                                  if (myRelayButtons[i].relayOptions & RELAY_STARTUP_ON) {
                                    isTurnedOn = 1;
                                  } else if (myRelayButtons[i].relayOptions & RELAY_STARTUP_OFF) {
                                    isTurnedOn = loadRelayState(i, 1); // 1 - true, 0 - false
                                    if (versionChangeResetState && isTurnedOn) {
                                      saveRelayState(i, 0, 1);
                                      isTurnedOn = 0;
                                  changeRelayState(i, isTurnedOn);
                                  myRelayState[i] = isTurnedOn;
                              if (versionChangeResetState) {
                                // version has changed, so store new version in eeporom
                                saveState(0, MULTI_RELAY_VERSION);
                            // executed AFTER mysensors has been initialised
                              for(int i = 0; i < numberOfRelayButtons; i++) {
                                if (myRelayButtons[i].button >= 0) {
                                  // No Expander support for buttons (de-bouncing)
                                  pinMode(myRelayButtons[i].button, INPUT_PULLUP); // HIGH state when button is not pushed
                              delay(5000);
                              // Send state to MySensor Gateway
                                // if this relay has multiple buttons, send only first
                                  msgs[i] = MyMessage(myRelayButtons[i].sensorId, V_LIGHT);
                                  uint8_t relayState;
                                    relayState = 1;
                                    relayState = 0;
                                    relayState = loadRelayState(i);
                                  send(msgs[i].set(relayState)); // send current state
                              // Setup buttons
                                  // setup debouncer
                                  myButtonDebouncer[i] = Bounce();
                                  myButtonDebouncer[i].attach(myRelayButtons[i].button);
                                  myButtonDebouncer[i].interval(50);
                                if (myRelayButtons[i].button >= 0 && myButtonDebouncer[i].update()) {
                                  int buttonState = myButtonDebouncer[i].read();
                                  #ifdef MY_DEBUG
                                    Serial.print("# Button ");
                                    Serial.print(i);
                                    Serial.print(" changed to: ");
                                    Serial.println(buttonState);
                                  int relayNum = (relayMultiButtons[i].firstButton == -1) ? i : relayMultiButtons[i].firstButton;
                                  if (myRelayButtons[i].buttonType == DING_DONG) {
                                    if (buttonState == LOW) { // button pressed
                                      changeRelayState(relayNum, 1);
                                      send(msgs[relayNum].set(1));
                                    } else { // button released
                                      changeRelayState(relayNum, 0);
                                      send(msgs[relayNum].set(0));
                                  } else if (myRelayButtons[i].buttonType == BI_STABLE || buttonState == HIGH) {
                                    // If button type is BI_STABLE, any change will toggle relay state
                                    // For MONO_STABLE, button must be pushed and released (HIGH)
                                    uint8_t isTurnedOn = ! loadRelayState(relayNum); // 1 - true, 0 - false
                                    changeRelayState(relayNum, isTurnedOn);
                                    send(msgs[relayNum].set(isTurnedOn));
                                    saveRelayState(relayNum, isTurnedOn);
                            // MySensors - Presentation
                            // Your sensor must first present itself to the controller.
                            // The presentation is a hint to allow controller prepare for the sensor data that eventually will come.
                            // Executed after "before()" and before "setup()" in: _begin (MySensorsCore.cpp) > gatewayTransportInit() > presentNode()
                              sendSketchInfo("Multi Relay", "1.2");
                              // Register every relay as separate sensor
                                // if this relay has multiple buttons, register only first
                                  // void present(uint8_t childSensorId, uint8_t sensorType, const char *description, bool ack);
                                  //   childSensorId - The unique child id you want to choose for the sensor connected to this Arduino. Range 0-254.
                                  //   sensorType - The sensor type you want to create.
                                  //   description An optional textual description of the attached sensor.
                                  //   ack - Set this to true if you want destination node to send ack back to this node. Default is not to request any ack.
                                  present(myRelayButtons[i].sensorId, S_BINARY, myRelayButtons[i].relayDescription);
                            // MySensors - Handling incoming messages
                            // Nodes that expects incoming data, such as an actuator or repeating nodes,
                            // must implement the receive() - function to handle the incoming messages.
                            // Do not sleep a node where you expect incoming data or you will lose messages.
                                uint8_t isTurnedOn = message.getBool(); // 1 - true, 0 - false
                                changeRelayState(message.sensor, isTurnedOn);
                                // Store state in eeprom if changed
                                if (loadRelayState(message.sensor) != isTurnedOn) {
                                  saveRelayState(message.sensor, isTurnedOn);
                                send(msgs[message.sensor].set(isTurnedOn)); // support for OPTIMISTIC=FALSE (Home Asistant)
                                #ifdef MY_DEBUG
                                  Serial.print("# Incoming change for sensor: " + message.sensor);
                                  Serial.println(", New status: " + isTurnedOn);
                            uint8_t loadRelayState(int relayNum, uint8_t forceEeprom) {
                              uint8_t relayState;
                              if (forceEeprom) {
                                relayState = loadState(RELAY_STATE_STORAGE + relayNum);
                                relayState = myRelayState[relayNum];
                              #ifdef MY_DEBUG
                                Serial.print("# loadRelayState: ");
                                Serial.print(relayNum);
                                if (forceEeprom) {
                                  Serial.print("(byte ");
                                  Serial.print(RELAY_STATE_STORAGE + relayNum);
                                  Serial.print(")");
                                Serial.print(" = ");
                                Serial.println(relayState);
                              return(relayState);
                            void saveRelayState(int relayNum, uint8_t state, uint8_t useEeprom) {
                              int mainRelayNum = (relayMultiButtons[relayNum].firstButton == -1) ? relayNum : relayMultiButtons[relayNum].firstButton;
                              myRelayState[mainRelayNum] = state;
                              if (useEeprom && (relayNum == mainRelayNum)) {
                                saveState(RELAY_STATE_STORAGE + mainRelayNum, state);
                              int nextButton = mainRelayNum;
                              // update all buttons
                              while ((nextButton = relayMultiButtons[nextButton].nextButton) != -1) {
                                myRelayState[nextButton] = state;
                            void saveRelayState(int relayNum, uint8_t state) {
                              uint8_t useEeprom = ((myRelayButtons[relayNum].relayOptions & RELAY_STARTUP_MASK) == 0);
                              saveRelayState(relayNum, state, useEeprom);
                            void changeRelayState(int relayNum, uint8_t relayState) {
                              uint8_t relayTrigger = myRelayButtons[relayNum].relayOptions & RELAY_TRIGGER_HIGH;
                              uint8_t digitalOutState = relayState ? relayTrigger : ! relayTrigger;
                              #ifdef USE_EXPANDER
                                if ( myRelayButtons[relayNum].relay & 0xff00 ) {
                                  int expanderNo = (myRelayButtons[relayNum].relay >> 8) - 1;
                                  int expanderPin = myRelayButtons[relayNum].relay & 0xff;
                                  expander[expanderNo].digitalWrite(expanderPin, digitalOutState);
                                digitalWrite(myRelayButtons[relayNum].relay, digitalOutState);
                              #ifdef USE_EXPANDER
                            And in Home assistant show example decription: Ł2 - kinkiet [C10] or for second Salon 2 [A9] etc.
                            Please help me... because it will be good to identify sensors when add to Controller.
